NI-SLSC 2025 Q1 Driver Win11 32/64bitEng NI开关负载信号调理设备驱动25.0.0版下载
NI-SLSC
NI-SLSC驱动用于支持在NI数据采集设备(如PXI和CompactRIO)上使用开关、负载和信号调理(SLSC)设备。
NI-SLSC是一种仪器驱动程序,为SLSC(开关、负载和信号调理)硬件提供支持。它集成了开关、负载和信号调理功能,可扩展基于PXI和C系列平台的系统功能。SLSC可将连接标准化,并提供模块化方法,适用于信号调理、故障插入和其他测试需求。NI-SLSC还包括一个开关路由API,使您能够在LabVIEW中控制和配置NI和第三方SLSC开关。
NI-SLSC 2025 Q1
发布日期:2025/1/23
包含的版本:2025 Q1完整版,版本号25.0.0
文件大小: 1738164224 字节 (1.62 GB)
修改日期: 2025-03-13 14:24
MD5: 0ca8c1ba0de7886d0db2279328b3917e
SHA1: a56d934317b7e6592f0ae163da35a76a3df11ed3
SHA256: 3fef9cc62442665447b8834466b8c2919e0fa6348ac3b85d9629c0a830827d17
CRC32: ebd05337
请注册登录视觉论坛账号,购买附件查看下载地址
SLSC2025Q1.txt
(510 Bytes, 下载次数: 0, 售价: 10 圆)
2025Q1未更新自述文件,参考2022Q4版
NI-SLSC 2022 Q4 ReadmeOctober 2022 This file contains installation instructions and compatibility information for NI-SLSC 2022 Q4. You can find more release information on ni.com. - NI-SLSC Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- NI-SLSC Documentation: New features, behavior changes, and other documentation
Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates New Features Supported Hardware Behavior Changes Accessing the Documentation Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 Unsupported Windows Operating Systems NI Software Drops Support for Phar Lap ETS Real-Time Operating System in 2022 Legal Information Supported Operating SystemsNI-SLSC 2022 Q4 supports the following operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
- NI Linux® Real-Time
Note Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes. Application Software SupportNI-SLSC 2022 Q4 supports the following application software versions, including service packs. Application Software | Versions Supported by NI-SLSC | LabVIEW | 2019 and later | LabVIEW Real-Time Module | 2019 and later | Installation InstructionsDownload the NI-SLSC installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager. After installing your software, you will need to activate it. Activating your software verifies the licenses associated with your NI account, so you can start using your software. You have different options for activation, based on your software and how it was purchased. Please visit ni.com/activate for more information on activation methods. Note If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue. Updated LabVIEW Compatibility PolicyThe "NI-SLSC Support for LabVIEW" package supports applications using NI-SLSC with LabVIEW 2023 or later. When installing NI-SLSC, this package will be recommended if you have already installed LabVIEW 2023 or later and installs to the LVAddons directory. LVAddons directory location: C:\Program Files\NI\LVAddons Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. Behavior ChangesThe default device reservation timeout for the SLSC Initialize and SLSC Reserve nodes has been increased to five seconds. This change improves the robustness of device reservation in typical scenarios. Previously, the default reservation timeout value was zero seconds. For existing code that does not explicitly wire a reservation timeout, this change could cause the program to stall for up to 5 seconds upon an attempted reservation (a stall will occur only if the device in question is already reserved). If desired, the previous behavior can be restored by explicitly setting the timeout to zero seconds. Accessing the DocumentationRefer to the NI-SLSC Help, accessible by navigating to the Start»National Instruments»NI-SLSC Documentation, for information about the NI-SLSC driver software. You can also refer to the NI-SLSC VI Reference Help, accessible by selecting Help»NI-SLSC VI Reference Help in LabVIEW, for information about SLSC VIs. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. Unsupported Windows Operating SystemsNI-SLSC no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport. NI No Longer Supports Phar Lap ETS Real-Time Operating SystemNI Software no longer supports Phar Lap ETS Real-Time Operating System. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi. Legal InformationCopyright © 2016–2022 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. |
