查看: 3450|回复: 0
[NI驱动程序] NI-Serial 19.0 Driver Win32/64Eng 美国国家仪器串口产品驱动ni-serial_19.0.0
    2 小时前
    发表于 2020-9-2 00:17:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Serial为使用NI串口产品的客户提供支持。
    NI-Serial驱动程序可最大限度提高CPU的利用率,无需改变波特率即可提高仪器的数据吞吐量。您也可使用较大型的先入先出存内存缓冲器(FIFO)来执行DMA传输,使NI-Serial接口以更高的速率发送和接收更大量的数据。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    serial19.0.txt (293 Bytes, 下载次数: 2, 售价: 10 圆)
    文件大小: 912148480 字节 (869.89 MB)
    修改日期: 2019-05-14 22:32
    MD5: 51d60ea977053e1d6eefc8c7a6a65086
    SHA1: cc2ad84c200ad1fc2425f8be551618773527b17d
    SHA256: 8a2ed0871de01d98d6b64fade23bfc3417d57dcd1cb61276e03986b352357043
    CRC32: 9c96f6e7
    NI-Serial for Windows, Version 19.0 Readme
    May 2019
    Thank you for using NI-Serial for Windows, Version 19.0.
    This file contains important information about NI-Serial for Windows, including installation instructions, new features, a partial list of bugs fixed for NI-Serial for Windows, and known issues.
    Parts of this document are relevant to only a full installation and do not apply to a runtime-only installation.
    This readme contains the following information:
    • System Requirements
    • Product Security and Critical Updates
    • Release Notes
    • Changes and Fixed Issues
    • Supported Interfaces
    • LabVIEW NXG Support and Considerations
    • Using NI Software with Microsoft Windows 10
    • Using NI Software with Microsoft Windows 8.1
    • NI-Serial Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    • Legal Information
    Tip  For optimal performance, update your operating system to the latest service pack and apply all security patches.
    • Supported Operating Systems
      • Windows 10 (32-bit and 64-bit)
      • Windows 8.1 (32-bit and 64-bit)
      • Windows Server 2008 R2 Service Pack 2 or later (64-bit)
    To download previous versions of NI-Serial drivers, refer to ni.com/updates and search for NI-Serial.
    Back to top
    Back to top
    Release NotesNew Firmware for USB and ExpressCard™ Hardware
    NI-Serial 3.5.1 included new firmware for USB and ExpressCard serial interfaces. If you are upgrading from a version older than NI-Serial 3.5.1, disconnect and reconnect your USB and ExpressCard devices to update to the latest firmware after finishing the NI-Serial installation process. In the case of the USB-485/4 hardware, also disconnect and reconnect the power cable.
    Port Enumeration Order on Windows 7 and later
    Serial ports on Windows 7 and later may not enumerate in numerical order. For more information, go to ni.com/kb and search for KnowledgeBase 51RBTPG2.
    Upgrading from Earlier Versions of Windows
    Microsoft often supports upgrading to newer versions of Windows, without a complete system reinstall. This can cause an improper version of NI-Serial to be installed on the system, which does not properly support the upgraded operating system. NI recommends uninstalling NI-Serial prior to upgrading Windows, then downloading and installing the appropriate version of NI-Serial for your new version of Windows.
    If you have already upgraded Windows without first uninstalling NI-Serial, it may be necessary to repair your NI-Serial installation. If the installed version does not support your operating system, you must uninstall it and install a supported version.
    Incorrect Serial Number Displayed in Measurement & Automation Explorer and the Device Manager
    If you swap one PCI-based (PCI, PCI Express, PXI, and PXI Express) serial card for another of the same model, the serial number shown in Measurement & Automation Explorer and the Device Manager may not change. This happens because Windows cannot distinguish the old hardware from the new. To fix this problem, uninstall the interface through Device Manager, then scan for new hardware or restart your computer. This forces Windows to reinstall your hardware and the correct serial number will be displayed.
    CreateFile COM Name Issue
    The CreateFile function from the Microsoft Win32 API fails for port names COM10 and greater. To use these ports, and for the function to succeed, append the string "\\\\.\\" before the port name. For example, to open COM10, use the string "\\\\.\\COM10" for the port name. This is because the port's full name is actually \\.\COM10, and all "\" characters must be doubled per the C language syntax.
    Driver Version Naming Changes
    NI-Serial versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: NI-Serial 14.0. For example, NI-Serial 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-Serial 4.1. The first version released under the new numbering scheme is NI-Serial 14.0.
    Back to top
    • Version 19.0
    • Version 18.5
    • Version 17.5
    • Version 17.0
    • Version 15.0
    • Version 14.0
    • Version 4.1
    • Version 4.0
    • Version 3.9.1
    • Version 3.9
    • Version 3.8.1
    • Version 3.8
    • Version 3.7
    • Version 3.6
    • Version 3.5.1
    • Version 3.5
    • Version 3.4
    • Version 3.3
    • Version 3.2
    • Version 3.1
    • Version 3.0
    • Version 1.8
    Changes and Fixed Issues in Version 19.0Added LabVIEW NXG 3.1 Support
    NI-Serial 19.0 adds support for LabVIEW NXG 3.1.
    Removed Support for WinXP OS
    NI-Serial 19.0 removes support for WinXP OS.
    Changes and Fixed Issues in Version 18.5Added LabVIEW NXG 3.0 Support
    NI-Serial 18.5 adds support for LabVIEW NXG 3.0.
    Added Support for PCI Express Serial Hardware
    NI-Serial 18.5 adds support for National Instruments PCI Express serial interfaces. Refer to Supported Interfaces.
    Changes and Fixed Issues in Version 17.5Added LabVIEW NXG 2.0 Support and New Features in MAX and System Designer
    NI-Serial 17.5 adds support for LabVIEW NXG 2.0. It also adds support for the Recover Ports utility, Basic Serial Port Settings view and configuration, and Advanced Serial Port Settings view in System Designer. In addition, it adds Self-Test support in MAX and System Designer.
    Changes and Fixed Issues in Version 17.0Removed Support for Various PCI and PXI Interfaces
    NI-Serial 17.0 removes support for the PCI-232, PCI-232I, PCI-485, PCI-485I, PXI-8420, PXI-8421, PXI-8422, and PXI-8423 interfaces.
    Changes and Fixed Issues in Version 15.0Added Support for CVS-1458
    NI-Serial 15.0 adds support for the serial port on the CVS-1458 controller.
    Changes and Fixed Issues in Version 14.0Runtime Installer
    Starting with version 14.0, NI-Serial is available as a runtime installer. NI-Serial Runtime is a minimal installer which does not include utilities, documentation, or Measurement & Automation Explorer (MAX). When building an installer using National Instruments application development environments (ADEs) such as LabVIEW, have the option of including this subset of NI-Serial in your distribution.
    ENET-232 and ENET-485
    NI-Serial 14.0 removes support for all NI Serial ENET Interfaces (ENET-232/2, ENET-232/4, ENET-485/2 and ENET-485/4).
    Changes and Fixed Issues in Version 4.1
    NI-Serial 4.1 adds new hardware support and fixes for LabVIEW Real-Time. Refer to the NI-Serial for LabVIEW Real-Time Readme for more information.
    Changes and Fixed Issues in Version 4.0Improved Support for NI System Configuration API
    NI-Serial 4.0 adds the discovery of USB and ENET hardware through the NI System Configuration API.
    NI System Configuration Expert Name Change
    The NI System Configuration expert for NI-Serial has been renamed from "ni-serial" to "serial". This change allows for system configuration and MAX import/export operations to be accessed in a consistent manner. Existing applications using the old name must be updated.
    Improved Appearance in MAX
    NI-Serial 4.0 improves the way serial hardware is displayed in MAX. PXI and PXIe hardware are now displayed under their respective chassis in the tree, and ENET interfaces are now found under Network Devices. The port items which were previously shown in MAX have been removed, and VISA ASRL resources are now placed directly beneath the serial interface.
    Removal of NI-Serial Communicator
    NI-Serial Communicator has been obsoleted, and is no longer installed. Similar functionality can be found using NI-VISA Interactive Control, which can be opened by selecting a VISA ASRL resource in MAX, and clicking the Open VISA Test Panel button in the toolbar.
    Changes and Fixed Issues in Version 3.9.1Update shortcuts installed on Windows 8
    When installing on Windows 8, NI-Serial no longer pins shortcuts to the Start screen. Shortcuts which are available from the start menu on earlier versions of Windows may be accessed through the NI Launcher utility, or by searching from the Start screen.
    383662: Configuring ENET serial port to COM256 causes crash
    NI-Serial 3.9.1 resolves an issue where a system crash could occur after renaming an ENET-232 or ENET-485 serial port to COM256. This crash could occur either when opening the port, or immediately upon booting Windows.
    Changes and Fixed Issues in Version 3.9Adds support for Windows 8
    NI-Serial 3.9 adds support for Windows 8. Known issues exist regarding the accessibility of items which were previously accessible via the Windows Start Menu. This will be addressed in a future release of NI-Serial.
    NI-Serial 3.9 supports the discovery of PCI-based (PCI, PCIe, PXI, and PXIe) hardware through the NI System Configuration API.
    325477: Possible system crash after removing hardware during hibernation
    NI-Serial 3.9 resolves an issue where a system could crash after removing PCI-based hardware from a hibernated system. Depending on the system configuration, the crash could occur immediately upon resume, or at a later time.
    317971: Cannot use baud rates higher than 131072 from .NET and possibly other applications
    NI-Serial 3.9 resolves an issue which limited the usable baud rate from the .NET Serial Port interface to 131072 baud. This error occurred because NI-Serial improperly reported the maximum baud rate as BAUD_128K (The maximum constant supported by the API) when the port actually supported higher baud rates. This has been changed to report BAUD_USER, indicating that custom baud rates are supported. Other applications querying the maximum baud rate may have been impacted as well.
    Changes and Fixed Issues in Version 3.8.1305387: DRIVER_IRQL_NOT_LESS_OR_EQUAL caused by NI-Serial ENET driver
    NI-Serial 3.8.1 has resolved issues which occasionally resulted in DRIVER_IRQL_NOT_LESS_OR_EQUAL system crashes when using ENET-232 or ENET-485 ports.
    299891: IRQL_GT_ZERO_AT_SYSTEM_SERVICE caused by NI-Serial ENET driver
    NI-Serial 3.8.1 has resolved an issue which could result in a IRQL_GT_ZERO_AT_SYSTEM_SERVICE system crash when closing an ENET-232 or ENET-485 port.
    Changes and Fixed Issues in Version 3.8Added support for cRIO-908x Controllers
    NI-Serial 3.8 adds support for the RS-485 port of the cRIO-908x controllers running Windows.
    NI-Spy replaced by NI I/O Trace
    NI-Spy has been replaced by NI I/O Trace. All functionality previously found in NI-Spy is now found in NI I/O Trace.
    Changes impacting PCI, PCI Express, PXI, and PXI Express hardware:
    • Performance Optimizations for Small Transfers
      Several enhancements have been made to improve performance and decrease CPU overhead when performing small writes on all interfaces, and small reads on 843x series hardware.
    • ID 288089: Flow control may not disengage
      When using multiple forms of flow control simultaneously on a single port, it was possible for flow control to fail to disengage, preventing data transmission. This has been fixed.
    • ID 287461: Possible loss of data preceding serial error
      Several bytes of valid data could be discarded immediately prior to the reception of a serial error, such as a parity or overrun error. This valid data is now properly received prior to handling the error condition.
    • ID 219314: Incorrect timeout behavior
      The special case where the Timeout Byte Interval and Timeout Multiplier are both -1 was handled incorrectly, resulting in serial calls failing to time out. This was most easily seen when using NI-Serial from .NET applications. This issue has been fixed.
    Changes and Fixed Issues in Version 3.7
    NI-Serial 3.7 adds new hardware support for LabVIEW Real-Time. Refer to the NI-Serial for LabVIEW Real-Time Readme for more information.
    Changes and Fixed Issues in Version 3.6Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 Support
    NI-Serial 3.6 adds support for Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2. Note that only the R2 versions are supported. Refer to Supported Interfaces for a list of supported hardware.
    Add support for PXI Express serial hardware
    NI-Serial 3.6 adds support for National Instruments PXI Express serial interfaces. Refer to Supported Interfaces for detailed model information.
    PXIe-8431 hardware adds support for higher baud rates
    For some applications, it may be possible to use a PXIe-8431 interface for communicating at up to 10 MBaud. For more information go to ni.com/kb and search for 58KEI82F.
    ID 201827: Incorrect RS-485 wire mode setting could be used when opening port
    Changing the RS-485 wire mode for PCI, PXI, and PCIe devices in Measurement& Automation Explorer and Device Manager had no effect. This has been fixed.
    Windows 2000
    Support for Windows 2000 is discontinued in this release.
    Changes and Fixed Issues in Version 3.5.1Windows 7 Support
    NI-Serial 3.5.1 adds support for Windows 7. Refer to Supported Interfaces for a list of supported hardware.
    Add support for PCI Express serial hardware
    NI-Serial 3.5.1 adds support for National Instruments PCI Express serial interfaces. Refer to Supported Interfaces for detailed model information.
    PCMCIA-232 and PCMCIA-485
    Support for PCMCIA-232 and PCMCIA-485 interfaces is discontinued in this release.
    ID 34931: Timeouts when reading from ENET Serial ports
    On some systems, every read attempt from an ENET Serial port would result ina timeout. This has been fixed.
    ID 167613: Incorrect RS-485 wire mode setting could be used when opening aport
    Changing the RS-485 wire mode for PCI, PXI, and PCIe devices in Measurement& Automation Explorer and the Device Manager had no effect on the port until the system was rebooted. This has been fixed.
    ID 163281: Baud rates for PCIe ports cannot be set to a non-standard baud rate
    It was not possible to set a PCIe serial port to a non-standard baud rate in Measurement & Automation Explorer and the Device Manager when using NI-Serial 3.5.0. This has been fixed.
    ID 189256: Renumbered COM ports not available until after reboot
    Renumbered COM ports could not be used until after a reboot on systems with Microsoft User Account Control (UAC) enabled. This has been fixed. Renumbering ports on an ENET interface still requires a reboot.
    Changes and Fixed Issues in Version 3.5Added support for PCI Express serial hardware
    NI-Serial 3.5 adds support for National Instrument PCI Express serial interfaces. Refer to Supported Interfaces for detailed model information.
    On-Chip Flow Control
    NI-Serial 3.5 adds support for on-chip flow control. Previous driver versions implemented flow control in the driver, which in some circumstances could allow data loss. All PCI, PXI, and PCI Express interfaces now utilize on-chip RTS/CTS and XON/XOFF flow control. 8430-series hardware also supports on-chip DTR/DSR flow control.
    ID 139396: Windows Direct Cable Connection
    Previous versions of NI-Serial could cause a system hang when initiating a Windows Direct Cable Connection. This issue has been resolved for PCI, PXI, and PCI Express interfaces. Issues may still exist when using Windows Direct Cable Connection with other interface types.
    Serial IO CTL AvailabilityNI-Serial no longer supports the following seldom-used Device I/O Control Codes:
    • IOCTL_SERIAL_SET_MODEM_CONTROL
    • IOCTL_SERIAL_GET_MODEM_CONTROL
    • IOCTL_SERIAL_SET_FIFO_CONTROL
    • IOCTL_SERIAL_XOFF_COUNTER
    • IOCTL_SERIAL_LSRMST_INSERT
    • IOCTL_SERIAL_GET_STATS
    • IOCTL_SERIAL_CLEAR_STATS
    Windows Management Instrumentation
    NI-Serial for Windows no longer provides support for Microsoft Windows Management Instrumentation.
    Changes and Fixed Issues in Version 3.4USB and ExpressCard Hardware
    NI-Serial 3.4 introduces improved functionality and performance for USB-232, USB-485, and NI ExpressCard-842x interfaces. This release also introduces support for all USB and ExpressCard interfaces on 64-bit Windows Vista.
    Measurement & Automation Explorer Fixed IssuesThe following issues for the Measurement & Automation Explorer (MAX) interface for serial devices have been fixed:
    • ID 56439—Users could not save changes for more than 9 ports using Save All Ports in MAX.
    • ID 56514—Under some circumstances, the serial port advanced tab did not appear in MAX.
    • ID 57115—Recover Unused COM Ports did not take effect until MAX was restarted.
    Windows 64-bit XP and Windows 64-bit Server 2003
    Support for Windows 64-bit XP and Windows 64-bit Server 2003 is discontinued in this release.
    Changes in Version 3.3
    NI-Serial 3.3 adds new hardware support for LabVIEW Real-Time. Refer to the NI-Serial for LabVIEW Real-Time Readme for more information.
    Changes in Version 3.2Add Support for Windows Vista
    NI-Serial 3.2 adds support for Windows Vista. Refer to Supported Interfaces for a list of supported hardware.
    ISA-232 and ISA-485
    Support for the obsolete ISA-232 and ISA-485 interfaces is discontinued in this release.
    Changes in Version 3.1
    NI-Serial 3.1 adds new hardware support for LabVIEW Real-Time. Refer to the NI-Serial for LabVIEW Real-Time Readme for more information.
    Changes in Version 3.0
    NI-Serial 3.0 adds new hardware support for LabVIEW Real-Time. Refer to the NI-Serial for LabVIEW Real-Time Readme for more information.
    Changes in Version 1.8Windows XP x64 and Windows Server 2003 x64
    NI-Serial 1.8 adds support for Microsoft Windows XP x64 and Windows Server 2003 x64 for all PCI, PXI, and PCMCIA interfaces.
    Baud Rates up to 3 Megabaud
    NI-Serial 1.8 adds support for custom baud rates up to 3 Mbaud on PCI/PXI-8431/8433 hardware. The two-wire auto control mode for RS-485 transceiver control has a maximum baud rate of 2 Mbaud.
    Communication Utility
    NI-Serial 1.8 includes a new serial communication utility. You can use the Serial Communicator to test serial hardware configuration and communication. The Serial Communicator is available in Measurement & Automation Explorer.
    Deprecated Serial I/O RequestsThe following Serial I/O requests were deprecated in NI-Serial 1.8:
    • Device I/O Control Request: SERIAL_IOCTL_SET_TRANSCEIVER_MODE
    • Major I/O Request: IRP_MJ_INTERNAL_DEVICE_CONTROL
    Back to top
    • PCI
    • PCI Express
    • PXI
    • PXI Express
    • USB
    • ExpressCard
    • Controllers
    PCI Interfaces
    Standard
    # Ports
    Isolated
    Max Baud (kbaud)
    PCI-8430/2RS-2322No1000.0
    PCI-8430/4RS-2324No1000.0
    PCI-8430/8RS-2328No1000.0
    PCI-8430/16RS-23216No1000.0
    PCI-8431/2RS-485/RS-4222No3000.01
    PCI-8431/4RS-485/RS-4224No3000.01
    PCI-8431/8RS-485/RS-4228No3000.01
    PCI-8432/2RS-2322Yes1000.0
    PCI-8432/4RS-2324Yes1000.0
    PCI-8433/2RS-485/RS-4222Yes3000.01
    PCI-8433/4RS-485/RS-4224Yes3000.01
    PCI Express Interfaces
    Standard
    # Ports
    Isolated
    Max Baud (kbaud)
    NI PCIe-8430/2RS-2322No1000.0
    NI PCIe-8430/8RS-2328No1000.0
    NI PCIe-8430/16RS-23216No1000.0
    NI PCIe-8431/2RS-485/RS-4222No3000.01
    NI PCIe-8431/8RS-485/RS-4228No3000.01
    NI PCIe-8431/16RS-485/RS-42216No3000.01
    NI PCIe-8432/2RS-2322Yes1000.01
    NI PCIe-8433/2RS-485/RS-4222Yes1000.01
    PXI Interfaces
    Standard
    # Ports
    Isolated
    Max Baud (kbaud)
    PXI-8430/2RS-2322No1000.0
    PXI-8430/4RS-2324No1000.0
    PXI-8430/8RS-2328No1000.0
    PXI-8430/16RS-23216No1000.0
    PXI-8431/2RS-485/RS-4222No3000.01
    PXI-8431/4RS-485/RS-4224No3000.01
    PXI-8431/8RS-485/RS-4228No3000.01
    PXI-8432/2RS-2322Yes1000.0
    PXI-8432/4RS-2324Yes1000.0
    PXI-8433/2RS-485/RS-4222Yes3000.01
    PXI-8433/4RS-485/RS-4224Yes3000.01
    PXI Express Interfaces
    Standard
    # Ports
    Isolated
    Max Baud (kbaud)
    NI PXIe-8430/8RS-2328No1000.0
    NI PXIe-8430/16RS-23216No1000.0
    NI PXIe-8431/8RS-485/RS-4228No3000.01, 2
    NI PXIe-8431/16RS-485/RS-42216No3000.01, 2
    USB Interfaces
    Standard
    # Ports
    Isolated
    Max Baud (kbaud)
    USB-232RS-2321No230.4
    USB-232/2RS-2322No230.4
    USB-232/4RS-2324No230.4
    USB-485RS-485/RS-4221No460.8
    USB-485/2RS-485/RS-4222No460.8
    USB-485/4RS-485/RS-4224No460.8
    ExpressCard Interfaces
    Standard
    # Ports
    Isolated
    Max Baud (kbaud)
    NI ExpressCard-8420/2RS-2322No230.4
    NI ExpressCard-8421/2RS-485/RS-4222No460.8
    Controllers
    # RS-485/422 Ports
    Isolated
    Max Baud (kbaud)
    NI-Serial software is required to use any RS-485/422 ports on the following controllers. Any RS-232 ports are supported by Microsoft's serial driver and do not require NI-Serial to be installed.
    cDAQ-913x13Yes230.4
    cRIO-908x13Yes230.4
    CVS-145813No115.2
    1The two-wire auto control mode for RS-485 transceiver control has a maximum baud rate of 2 Mbaud.
    2For possible use with higher baud rates, refer to ni.com/kb and search for KnowledgeBase 58KEI82F.
    3This port supplies connections only for transmit, receive, and ground.
    Back to top
    The following sections detail considerations for using LabVIEW NXG 3.1 with NI-Serial.
    LabVIEW NXG Hardware Support
    Refer to the Supported Interfaces section for a list of hardware supported in LabVIEW NXG.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    Back to top
    NI-Serial will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    Back to top
    © 1996–2019 National Instruments. All rights reserved.
    375395E-01
    GMT+8, 2026-4-23 10:36
