查看: 1023|回复: 0
[NI驱动程序] NI-Serial 2025 Q1 Win11 32/64bit多国语言 NI串口产品驱动ni-serial_25.0.0
     楼主| 发表于 2025-4-25 10:29:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-Serial为使用NI串口产品的客户提供支持。
    NI-Serial驱动程序可最大限度提高CPU的利用率,无需改变波特率即可提高仪器的数据吞吐量。您也可使用较大型的先入先出存内存缓冲器(FIFO)来执行DMA传输,使NI-Serial接口以更高的速率发送和接收更大量的数据。
    NI-Serial 2025 Q1
    发布日期:2025/1/23
    包含的版本:2025 Q1完整版,版本号25.0.0
    语言:中文Simplified Chinese/德语German/日语Japanese/法语French/英文English/韩语Korean
    文件大小: 1829457920 字节 (1.70 GB)
    修改日期: 2025-03-13 14:33
    MD5: f5daccd463054cf3abea3110de072cad
    SHA1: 4624135ec67d71debd95f6900d47586c9adf7672
    SHA256: 91a63c083aeccdc6cd8380552d8b6649c221ed258a4f2b4a778329bc4ac46f94
    CRC32: f1335a62
    请注册登录视觉论坛会员,购买附件查看下载地址,充值请联系在线客服
    Serial2025Q1.txt (518 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q1未更新自述文件,参考2023Q2版本
    NI-Serial 2023 Q2 Readme
    April 2023
    This file contains installation instructions and compatibility information for NI-Serial 2023 Q2.
    • NI-Serial Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Serial Documentation: Detailed documentation about how to use your product
    NI-Serial 2023 Q2 supports the following operating systems:
    NI-Serial 2023 Q2 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-Serial 2023 Q2
    LabVIEW Real-Time Module™2021 and later
    Download the NI-Serial installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    In Windows Device Manager the detected serial ports will not list the serial number of the NI-Serial device to which they are associated. In NI-Serial Troubleshooter the list of verified serial ports will not contain the serial number of the NI-Serial device in the Port Description. The user can still use NI-MAX to associate the COM port numbers with their NI-Serial devices.
    Refer to the NI-Serial documentation, accessible from ni.com/docs, for information about the NI-Serial.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-Serial are located in the labview\examples\Instrument IO\Serial directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. NI-VISA is required in order to run NI-Serial examples.
    NI-Serial no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-1-13 11:08
