查看: 4276|回复: 0
[NI软件产品] NI VeriStand 2020R2 Win64Eng PC版完整版及运行版NIVS2020R2 20.2.0不含驱动版6.06GB
    发表于 2020-7-25 02:00:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2020R2
    文件大小: 6517817344 字节 (6.07 GB)
    修改日期: 2020-07-10 20:49
    MD5: 2d8fe6d8a490befdcb8b5832008a21d9(官方正确)
    SHA1: 2e452dd94015501b72a2fef7c7f2630d896266fe
    SHA256: 489378f6a71cfbd443514d4c82af3a40842dafc2f1db779e0d14c9e9110d0246
    CRC32: c6576520
    百度网盘下载和NI官方下载地址:
    请注册登录视觉论坛会员,购买附件查看
    VS2020R2-20.2.txt (289 Bytes, 下载次数: 3, 售价: 10 圆)
    VeriStand 2020
    May 2020
    This file contains important information about VeriStand 2020, including system requirements and installation instructions.
    VeriStand Drops Support for Windows 7 (32- and 64-Bit) Operating Systems in 2021
    VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and your simulation models. The VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be customized and extended with LabVIEW, NI TestStand, and other software tools.
    VeriStand includes a run-time editable user interface and a test manager you can use to configure and implement triggered multi-file data logging, stimulus generation and playback, and real-time test sequencing.
    VeriStand has the following requirements:
    Windows 64-bit Operating System
    Real-Time Targets
    RAM/Processor
    • 4 GB of RAM
    • PXI controller/desktop PC—At least 256 MB of RAM1 2
    • CompactRIO/Single-Board RIO—At least 128 MB of RAM1
    Required Software
    • (Required) NI-DAQmx 20.0
    • (Required) NI-VISA 20.0
    • (Required) NI-SLSC 20.0
    • (Recommended) NI-RIO 20.0, used by NI FPGA targets
    • (Recommended) NI-XNET 20.0, used by NI-XNET vehicle bus interface cards
    VeriStand software, which you can install from NI Measurement & Automation Explorer (MAX)
    1 You can achieve higher Primary Control Loop rates by using targets with higher-performance specifications.
    2 Using custom devices, such as the Scan Engine Custom Device, will require at least 512MB of RAM.
    Note  The following sections describe system requirements that apply if you use models, LabVIEW functionality, and .NET APIs in your system.
    Simulation Models
    To configure and run a simulation using your existing compiled model, you need only VeriStand installed. You need additional software to perform other tasks with models, as the following list describes:
    • To develop a model using The MathWorks, Inc. Simulink® application software, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. MATLAB® software (32-bit or 64-bit version) and The MathWorks, Inc. Simulink software.
    • To compile a model developed using The MathWorks, Inc. Simulink software for use on a Microsoft Windows or LabVIEW real-time target, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. Real-Time Workshop® (Simulink Coder®). Refer to the NI website for a list of compilers that are tested and supported.
    • The VeriStand Model Framework supports only certain versions of The MathWorks, Inc. Simulink® software. If the VeriStand Model Framework is used with an unsupported version of The MathWorks, Inc. Simulink®, VeriStand cannot initialize it.
    If you use other modeling environments, contact your model vendor for requirements for developing a model and converting it into a compiled model.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2020. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    • A .NET environment capable of interacting with .NET Framework 4.6.2-based assemblies, such as Microsoft Visual Studio 2015 or LabVIEW 2020.
    VeriStand supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • 64-bit version of Windows 10 (version 1909/8.1 Update 11/7 SP12
    • Phar Lap ETS
    • NI Linux Real-Time
    Note  In 2016, VeriStand dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. VeriStand 2020 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use VeriStand 2020 to an unsupported OS. Additionally, after installing VeriStand 2020, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2020, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    When formatting a disk with a PXI Linux RT system image for VeriStand 2020, select Linux RT System Image for Q1 2020 and enable support for the LabVIEW 2020 programming environment. This feed contains the same driver versions included with the VeriStand 2020 installer and avoids driver version conflicts while deploying XNET to a real-time target.
    VeriStand will drop support for the Windows 7 (32- and 64-bit) operating system starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on Windows 7. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    To install VeriStand, you must log on as an administrator or as a user with administrator privileges. You can activate VeriStand when prompted by the installer or activate later using NI License Manager. To use LabVIEW with VeriStand, install the like-numbered version of LabVIEW on the host computer.
    You should also disable any automatic virus detection programs before you install. Some virus detection programs interfere with the installer. Be sure to check your computer for viruses and enable your virus detection programs after installing VeriStand.
    You can install VeriStand with either NI Package Manager or installation media.
    NI Package Manager
    NI automates VeriStand installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installation Media
    If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product. Insert the VeriStand installation media and follow the instructions that appear on the screen.
    The following sections describe issues to be aware of when you upgrade to VeriStand 2020.
    Note  NI recommends that you also review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2020. To access the documents, refer to the NI website at ni.com/info and enter the Info Code for the appropriate VeriStand version from the following list:
    • VeriStand 2019 R3 f1 readme—NIVeriStand2019R3F1RM
    • VeriStand 2019 R3 readme—NIVeriStand2019R3RM
    • VeriStand 2019 R2 readme—NIVeriStand2019R2RM
    • VeriStand 2019 readme—NIVeriStand2019RM
    • VeriStand 2018 SP1 readme—NIVeriStand2018SP1RM
    • VeriStand 2018 readme—NIVeriStand2018RM
    • VeriStand 2017 readme—NIVeriStand2017RM
    • VeriStand 2016 readme—NIVeriStand2016RM
    • VeriStand 2015 SP1 readme—NIVeriStand2015SP1RM
    • VeriStand 2015 readme—NIVeriStand2015RM
    • VeriStand 2014 readme—NIVeriStand2014RM
    Uncompiled Models
    VeriStand 2020 does not support communication with uncompiled models.
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2020. The LabVIEW functionality in VeriStand requires like-numbered versions.
    The VeriStand Model Framework contains changes to the files you use to develop and compile models in C/C++ and third-party modeling environments. If your system contains models compiled with previous versions of the Model Framework, choose from the following options to continue to use the models in VeriStand 2020:
    • If you do not need to update your model, you can continue to use the model as-is.
    • If you need to update functionality of your model that does not require the changes in the latest version of the Model Framework, you can recompile the model against the deprecated Model Framework files. These files are installed at \VeriStand\version\ModelInterface\custom\src\obsolete.
    Migrating Files from VeriStand 2009 and Earlier
    The mutation tool is not available in VeriStand 2020. All rig files and in4 files must be migrated using VeriStand 2014 or earlier.
    Migrating Files from VeriStand 2010 and Later
    VeriStand 2020 can open projects from VeriStand 2010 and later using the Open Legacy Project option in the Welcome tab.
    VeriStand Custom Devices Not Included
    In VeriStand 2020 and later, built-in Custom Devices, including the Embedded Data Logger, are no longer included when installing from offline media. Use NI Package Manager to include all supported Custom Devices during installation. To install Custom Devices separately, see the release page for each Custom Device on the VeriStand Add-ons support page
    You cannot add new instances of the Lambda Genesys and Pickering custom devices. Refer to the NI website for details on how to access the source code for the Lambda Genesys and Pickering custom devices.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in VeriStand 2020.
    Known Conflict with .NET 4.6.2 and MSVC 2010
    To run the VeriStand editor, the .NET Framework 4.6.2 must be installed. However, installing the .NET Framework 4.6.2 can break the Microsoft Visual C++ 2010 compilers, which are used to compile models for PharLap VeriStand targets. Using broken compilers results in error LNK1123. To resolve this Microsoft compiler issue, apply all service packs and updates for your version of Microsoft Visual Studio or Windows SDK. Refer to Microsoft Support Article 2757355 for more information.
    For a complete list of the IDs and titles of the issues fixed in VeriStand 2020, see VeriStand 2020 Bug Fixes. If you have a Bug or Legacy ID, you can search the list to validate that the issue has been fixed.
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help...
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2020 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including NI LabVIEW™ and NI TestStand™.Windows Start menu: All Programs»National Instruments»VeriStand 2020 .NET API Help.
    VeriStand Model Framework IntroductionInformation about how to use the VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in VeriStand.You can access this guide from the \VeriStand\\ModelInterface\custom directory, where RootDrive is the drive where NI software installs and xxxx is the VeriStand version number.
    Note  You must explicitly select VeriStand Model Framework when you run the VeriStand installer.
    Note  If you install VeriStand with the compatible version of LabVIEW, you also can access a subset of the VeriStand Help, including information about the VeriStand VIs and extending VeriStand functionality with LabVIEW, from the LabVIEW Help. From LabVIEW, select Help»LabVIEW Help.
    • VeriStand Project—An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the <;Public Documents>\National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—NI VeriStand Stimulus Profile Editor examples are located in the <;Public Documents>\National Instruments\NI VeriStand\Examples directory.
      Tip  On Windows 7, the default location of the <;Public Documents> directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the VeriStand API are located in the <;Program Files>\National Instruments\LabVIEW 2020\examples\NI Veristand directory.
    © 2009–2020 National Instruments. All rights reserved.
    375380N-01
    GMT+8, 2026-4-23 09:13
