查看: 3908|回复: 0
[NI软件产品] NI VeriStand 2019 R3 Win64Eng PC版完整版及运行版NIVS2019R3 19.2.0不含驱动版6.3GB
    发表于 2020-7-25 01:53:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    VS2019R3-19.2.txt (253 Bytes, 下载次数: 8, 售价: 10 圆)
    VeriStand 2019
    July 2019
    This file contains important information about VeriStand 2019, including system requirements and installation instructions.
    VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and your simulation models. The VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be customized and extended with LabVIEW, NI TestStand, and other software tools.
    VeriStand includes a run-time editable user interface and a test manager you can use to configure and implement triggered multi-file data logging, stimulus generation and playback, and real-time test sequencing.
    Refer to the following list to learn what's new in VeriStand 2019.
    VeriStand Editor
    You can now use the VeriStand Editor to control aspects of your project. The UI Manager and Project Explorer windows from previous releases of VeriStand have been combined into one editor. Many of the features of the Project Explorer window can now be accessed through Project Files in the Navigation pane of the VeriStand Editor. The VeriStand Editor also contains the Mapping Diagram to help visualize channel mappings.
    Note  You can access the interface from previous versions of VeriStand by launching the VeriStand Project Explorer from the x86\NI\VeriStand 2019 directory.
    Mapping Diagram
    You can now visualize software mappable points within a VeriStand project with the Mapping Diagram. This graphical diagram allows you to see all VeriStand channels and the mappings between them.
    Groups of mappings between two nodes are automatically bundled into a single wire by default to reduce clutter. If a wire represents multiple mappings, you can select the bundle to see more information in the Configuration pane.
    Other features of the Mapping Diagram include the ability to:
    • Display aliases and user channels
    • Validate and debug mappings
    PXI NI Linux RT Support
    You can now deploy System Definition Files to PXI NI Linux RT targets similarly to previously supported targets. Benefits of supporting the NI Linux RTOS include:
    • Support for newer compilation tools and advance C++ features
    • Support for Linux and other libraries
    • Improvement of memory handling and computational power
    Custom Device Support
    VeriStand 2019 officially supports custom devices. The following table displays custom devices that are supported in VeriStand.
    Custom Device
    Description
    Engine Simulation ToolkitProvides a configuration-based experience for validating engine control units (ECUs).
    Scan Engine and EtherCATSupports easily read scanned I/O from C series modules in a CompactRIO or NI 914x EtherCAT chassis. This custom device also supports custom FPGA personalities to be used with a 914x chassis.
    SLSC 12201 DIO Module CustomIntegrates the SLSC-12201 33 V Digital I/O Conditioning Module into VeriStand.
    SLSC EDS Custom DeviceAllows any generic SLSC Capabilities file to be used in VeriStand.
    Synchronization Custom DeviceSynchronizes RT system time and PXI chassis clocks.
    These custom devices can be downloaded with VeriStand 2019 using NI Package Manager. Check NI GitHub for updates and other custom devices.
    CAN FD Support
    VeriStand 2019 supports XNET implementation for the Controller Area Network Flexible Data-Rate (CAN FD) protocol. With a XNET implementation, you can now use databases that support CAN FD and CAN FD with Baud Rate Switching I/O modes. This implementation also allows calculating and using custom baud rates for a CAN interface. For more information on CAN FD, see Understanding CAN with Flexible Data-Rate (CAN FD).
    FMI Support
    VeriStand now has limited support for the Functional Mockup Interface (FMI) API standard on Windows and PXI LinuxRT. Use the FMI standard to create tool agnostic, portable solutions between modeling and simulation environments. VeriStand enables the configuration and execution of FMI 2.0 CoSimulation models on host and National Instruments Real-Time Linux64 systems.
    Note  This support requires the Functional Mockup Units (FMUs) to have the proper executable binaries available.
    VeriStand has the following requirements:
    Windows 64-bit Operating System
    Real-Time Targets
    RAM/Processor
    • 4 GB of RAM
    • PXI controller/desktop PC—At least 256 MB of RAM1 2
    • CompactRIO/Single-Board RIO—At least 128 MB of RAM1
    Required Software
    • (Required) NI-DAQmx software 19.1
    • (Required) NI-VISA software 19.0 or later
    • (Recommended) NI-RIO 19.1 or later driver software, used by NI FPGA targets
    • (Recommended) NI-XNET 19.1 or later driver software, used by NI-XNET vehicle bus interface cards
    VeriStand software, which you can install from NI Measurement & Automation Explorer (MAX)
    1 You can achieve higher Primary Control Loop rates by using targets with higher-performance specifications.
    2 Using custom devices, such as the Scan Engine Custom Device, will require at least 512MB of RAM.
    Note  The following sections describe system requirements that apply if you use models, LabVIEW functionality, and .NET APIs in your system.
    Simulation Models
    To configure and run a simulation using your existing compiled model, you need only VeriStand installed. You need additional software to perform other tasks with models, as the following list describes:
    • To develop a model using The MathWorks, Inc. Simulink® application software, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. MATLAB® software (32-bit or 64-bit version) and The MathWorks, Inc. Simulink software.
    • To compile a model developed using The MathWorks, Inc. Simulink software for use on a Microsoft Windows or LabVIEW real-time target, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. Real-Time Workshop® (Simulink Coder®). Refer to the NI website for a list of compilers that are tested and supported.
    • The VeriStand Model Framework supports only certain versions of The MathWorks, Inc. Simulink® software. If the VeriStand Model Framework is used with an unsupported version of The MathWorks, Inc. Simulink®, VeriStand cannot initialize it.
    If you use other modeling environments, contact your model vendor for requirements for developing a model and converting it into a compiled model.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2019 or later. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    • A .NET environment capable of interacting with .NET Framework 4.6.2-based assemblies, such as Microsoft Visual Studio 2015 or LabVIEW 2019.
    VeriStand supports the following operating systems:
    Windows Systems1
    Real-Time Targets
    • 64-bit version of Windows 10 (version 1809)/8.1 Update 11/7 SP12
    • Phar Lap ETS
    • NI Linux Real-Time
    Note  In 2016, VeriStand dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. VeriStand 2019 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use VeriStand 2019 to an unsupported OS. Additionally, after installing VeriStand 2019, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2019, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    To install VeriStand, you must log on as an administrator or as a user with administrator privileges. You can activate VeriStand when prompted by the installer or activate later using NI License Manager. To use LabVIEW with VeriStand, install the like-numbered version of LabVIEW on the host computer.
    You should also disable any automatic virus detection programs before you install. Some virus detection programs interfere with the installer. Be sure to check your computer for viruses and enable your virus detection programs after installing VeriStand.
    You can install VeriStand with either NI Package Manager or installation media.
    NI Package Manager
    Installation Media
    If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product. Insert the VeriStand installation media and follow the instructions that appear on the screen.
    The following sections describe issues to be aware of when you upgrade to VeriStand 2019.
    Note  NI recommends that you also review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2019. To access the documents, refer to the NI website at ni.com/info and enter the Info Code for the appropriate VeriStand version from the following list:
    • VeriStand 2018 SP1 readme—NIVeriStand2018SP1RM
    • VeriStand 2018 readme—NIVeriStand2018RM
    • VeriStand 2017 readme—NIVeriStand2017RM
    • VeriStand 2016 readme—NIVeriStand2016RM
    • VeriStand 2015 SP1 readme—NIVeriStand2015SP1RM
    • VeriStand 2015 readme—NIVeriStand2015RM
    • VeriStand 2014 readme—NIVeriStand2014RM
    Uncompiled Models
    VeriStand 2019 does not support communication with uncompiled models.
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2019. The LabVIEW functionality in VeriStand requires like-numbered versions.
    The VeriStand Model Framework contains changes to the files you use to develop and compile models in C/C++ and third-party modeling environments. If your system contains models compiled with previous versions of the Model Framework, choose from the following options to continue to use the models in VeriStand 2019:
    • If you do not need to update your model, you can continue to use the model as-is.
    • If you need to update functionality of your model that does not require the changes in the latest version of the Model Framework, you can recompile the model against the deprecated Model Framework files. These files are installed at \VeriStand\version\ModelInterface\custom\src\obsolete.
    Migrating Files from VeriStand 2009 and Earlier
    The mutation tool is not available in VeriStand 2019. All rig files and in4 files must be migrated using VeriStand 2014 or earlier.
    Migrating Files from VeriStand 2010 and Later
    VeriStand 2019 can open projects from VeriStand 2010 and later using the Open Legacy Project option in the Welcome tab.
    Select Built-In Custom Devices Not Included
    In VeriStand 2015 and later, you cannot add new instances of the Lambda Genesys and Pickering custom devices. Systems that already contain these custom devices can continue to use them.
    Refer to the NI website for details on how to access the source code for the Lambda Genesys and Pickering custom devices.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in VeriStand 2019.
    Known Conflict with .NET 4.6.2 and MSVC 2010
    To run the VeriStand editor, the .NET Framework 4.6.2 must be installed. However, installing the .NET Framework 4.6.2 can break the Microsoft Visual C++ 2010 compilers, which are used to compile models for Windows and PharLap VeriStand targets. Using broken compilers results in error LNK1123. To resolve this Microsoft compiler issue, apply all service packs and updates for your version of Microsoft Visual Studio or Windows SDK. Refer to Microsoft Support Article 2757355 for more information.
    The following items are the IDs and titles of a subset of issues fixed in VeriStand 2019. This is not an exhaustive list of issues fixed in the current version of VeriStand. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    581461Importing a large number of mappings with the Import Mappings window may cause a .NET exception and fail to import mappings.
    583754Running and stopping a Stimulus Profile via the LabVIEW API causes a memory leak.
    590854When UI Manager is used in a VeriStand project, both UI Manager and the Workspace are launched at execution time. There is currently no way to disable this.
    635055When displaying multiple channels on a Waveform Chart, the chart may update slowly and possibly lose data.
    651257When using the Model Parameter Manager or Channel Data Viewer with a large number of channels, UI Manager may hang.
    669410Opening the System Configuration Mappings window may cause Error 1172 and cause all mappings in the window to disappear.
    695368The VeriStand Engine may crash when a channel in a Real-Time Sequence is faulted.
    703244Model Parameter Manager shows incorrect initial values for all models except the first model loaded in VeriStand.
    703397Parameters from LabVIEW clusters do not update when mapped to a UI Manger control.
    704556When a target is disabled in the System Definition, UI Manager charts may not update with new data.
    712390UI Manager does not automatically connect to deployed VeriStand projects.
    717348Initial model parameter values loaded from a file are only applied to the first model loaded in VeriStand.
    717983The Model Parameter Manager in UI Manager cannot update parameter arrays.
    725381Using several Waveform Charts in the same UI Manager Project may cause a memory leak.
    726690The Scan Engine EtherCAT Add-On Scan Interface encoder measurement does not change the timebase when selected.
    728415CPU Usage may increase when UI Manager is not the software in focus.
    729116A UI Manager Waveform Chart may not display data when mapped to a waveform task.
    731368Models do not compile when data types are shared between reference models from The MathWorks, Inc. Simulink© software.
    735599When using a custom device, values set from the UI Manager may be registered twice.
    737393The VeriStand Engine will crash when running models compiled from the The MathWorks, Inc. Simulink R2017b software or later.
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help...
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2019 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including NI LabVIEW™ and NI TestStand™.Windows Start menu: All Programs»National Instruments»VeriStand 2019 .NET API Help.
    VeriStand Model Framework IntroductionInformation about how to use the VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in VeriStand.You can access this guide from the \VeriStand\\ModelInterface\custom directory, where RootDrive is the drive where NI software installs and xxxx is the VeriStand version number.
    Note  You must explicitly select VeriStand Model Framework when you run the VeriStand installer.
    Note  If you install VeriStand with the compatible version of LabVIEW, you also can access a subset of the VeriStand Help, including information about the VeriStand VIs and extending VeriStand functionality with LabVIEW, from the LabVIEW Help. From LabVIEW, select Help»LabVIEW Help.
    • VeriStand Project—An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the <;Public Documents>\National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—NI VeriStand Stimulus Profile Editor examples are located in the <;Public Documents>\National Instruments\NI VeriStand\Examples directory.
      Tip  On Windows 7, the default location of the <;Public Documents> directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the VeriStand API are located in the <;Program Files>\National Instruments\LabVIEW 2019\examples\NI Veristand directory.
    © 2009–2019 National Instruments. All rights reserved.
    375380J-01
    GMT+8, 2026-4-23 09:16
