查看: 3910|回复: 0
[NI软件产品] NI VeriStand 2014 Win32Eng PC版完整版及运行版NIVS2014
    8 小时前
  • 签到天数: 3849 天
    连续签到: 42 天
    发表于 2020-7-25 00:20:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    NI官方下载地址(可能无效或无法下载完成):下载地址1:
    请注册登录视觉论坛会员,购买附件查看
    下载地址2:
    请注册登录视觉论坛会员,购买附件查看
    VS2014.txt (353 Bytes, 下载次数: 0, 售价: 10 圆)
    NI VeriStand 2014 Readme
    August 2014
    This file contains important information about NI VeriStand 2014, including system requirements and installation instructions.
    Evaluating NI DIAdem
    Important Information
    NI VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and your simulation models. The NI VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be easily customized and extended with LabVIEW, NI TestStand, and other software tools.
    NI VeriStand includes a run-time editable user interface as well as a test manager you can use to configure and implement triggered multi-file data logging, real-time test sequencing, stimulus generation and playback, and model calibration.
    The following sections describe support considerations for using NI VeriStand in various types of systems.
    Windows Systems1Real-Time Targets
    Operating System
    • Windows 8.1/8/7/Vista (32-bit and 64-bit)
    • Phar Lap ETS
    • VxWorks
    RAM/Processor
    • 2 GB of RAM
    • Multi-core processor
    • PXI controller/desktop PC—At least 256 MB of RAM2
    • CompactRIO/Single-Board RIO—At least 128 MB of RAM2
    Required Software
    • (Required) NI-DAQmx software 9.7.5 or later driver software
    • (Required) NI-VISA software 5.4.0 or later
    • (Recommended) NI-RIO 13.0 or later driver software, used by NI FPGA targets
    • (Recommended) NI-XNET 14.0 or later driver software, used by NI-XNET vehicle bus interface cards
    NI VeriStand software (install from NI Measurement & Automation Explorer (MAX))
    1 The following considerations apply to using NI VeriStand on Windows:
    • NI VeriStand runs as a 32-bit application on all operating systems.
    • NI VeriStand does not support Windows 2000/NT/Me/98/95, Windows XP x64, Windows XP Service Pack 1 and 2, or the Windows Server non-R2 editions.
    • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    2 You can achieve higher Primary Control Loop rates by using targets with higher-performance specifications.
    Note  The following sections describe system requirements that apply if you use models, LabVIEW functionality, and .NET APIs in your system.
    Simulation Models
    To configure and run a simulation using your existing compiled model, you need only NI VeriStand installed. You need additional software to perform other tasks with models, as the following list describes:
    • To develop a model using The MathWorks, Inc. Simulink® application software, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. MATLAB® software (32-bit or 64-bit versions) and The MathWorks, Inc. Simulink software.
      Note  NI VeriStand supports the 64-bit versions of the MATLAB or Simulink software starting in R2010b. For compatibility information, visit ni.com/info and enter the Info Code exxymi.
    • To compile a model developed using The MathWorks, Inc. Simulink software for use on a Microsoft Windows or LabVIEW real-time target, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. Real-Time Workshop® (Simulink Coder®).
    • For deploying a compiled model to a LabVIEW real-time target, visit ni.com/info and enter the Info Code exxymi for a list of compilers that are tested and supported.
    If you use other modeling environments, contact your model vendor for requirements for developing a model and converting it into a compiled model.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2014. The LabVIEW functionality in NI VeriStand always requires like-numbered versions.
    .NET
    The NI VeriStand .NET APIs require the following Microsoft software:
    • Microsoft .NET Framework 4.0, which uses Microsoft .NET Common Language Runtime (CLR) 4.0.
    • A .NET environment capable of interacting with .NET Framework 4.0 based assemblies, such as Microsoft Visual Studio 2010 or LabVIEW 2014.
    Complete the following steps to install NI VeriStand.
    • Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • (Optional) To use LabVIEW with NI VeriStand, install the like-numbered version of LabVIEW on the host computer.
    • Insert the NI VeriStand installation media and follow the instructions that appear on the screen.
    • Install the NI-DAQmx driver software from the NI Device Drivers DVD or any NI-DAQmx driver DVD.
      Note  The NI-DAQmx driver software is required to deploy a system definition to any platform, including the localhost running Windows.
    • (Optional) If using NI-XNET, insert the NI-XNET installation media and follow the instructions that appear on the screen.
    • (Optional) Activate NI VeriStand when prompted by the installer, or activate at a later time using the NI License Manager.
    The NI VeriStand 2014 media kit includes an evaluation version of NI DIAdem. NI DIAdem is a software tool you can use to locate, load, visualize, analyze, and report measurement data from real-time tests. You can use NI VeriStand with DIAdem to automate the post-processing of data collected in NI VeriStand, view trend data across multiple files and file types, and generate custom reports.
    For a list of new features in NI VeriStand 2014, refer to the following topic in the NI VeriStand 2014 Help posted on ni.com or installed on disk: What's New in NI VeriStand 2014.
    The following sections describe issues to be aware of when you upgrade to NI VeriStand 2014.
    Note  National Instruments recommends that you also review the Upgrade and Compatibility Issues in the readme files for each NI VeriStand version between the version from which you are upgrading and NI VeriStand 2014. To access the documents, refer to the National Instruments website at ni.com/info and enter the Info Code for the appropriate NI VeriStand version from the following list:
    • NI VeriStand 2010 readme—NIVeriStand2010RM
    • NI VeriStand 2011 readme—NIVeriStand2011RM
    • NI VeriStand 2011 SP1 readme—NIVeriStand2011SP1RM
    • NI VeriStand 2012 readme—NIVeriStand2012RM
    • NI VeriStand 2013 readme—NIVeriStand2013RM
    • NI VeriStand 2013 SP1 readme—NIVeriStand2013SP1RM
    Models compiled from LabVIEW VIs (.lvmodel files) using LabVIEW 2013 or earlier must be recompiled using LabVIEW 2014. The LabVIEW functionality in NI VeriStand always requires like-numbered versions.
    NI VeriStand Updates and Notifications
    NI VeriStand includes the following documentation resources:
    ResourceContentsAccess Instructions
    NI Veristand HelpConceptual, how-to, and reference information for using NI VeriStand.In software: Help»Search the NI VeriStand Help
    OR
    Windows Start menu: All Programs»National Instruments»NI VeriStand»VeriStand Help
    NI VeriStand .NET API HelpReference information for the .NET APIs included with NI VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including NI LabVIEW™ and NI TestStand™.Windows Start menu: All Programs»National Instruments»NI VeriStand»VeriStand .NET API Help.
    NI VeriStand Model Framework IntroductionInformation about how to use the NI VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in NI VeriStand.You can access this guide from the RootDrive:\VeriStand\xxxx\ModelInterface\custom directory, where RootDrive is the drive where NI software installs and xxxx is the NI VeriStand version number.
    Note  You must explicitly select NI VeriStand Model Framework when you run the NI VeriStand installer.
    Note  If you install NI VeriStand with the compatible version of LabVIEW, you also can access a subset of the NI VeriStand Help, including information about the NI VeriStand VIs and extending NI VeriStand functionality with LabVIEW, from the LabVIEW Help. From the pull-down menu in LabVIEW, select Help»LabVIEW Help.
    NI VeriStand includes several types of examples:
    • NI VeriStand Project—An example NI VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the <;Public Documents>\National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—NI VeriStand Stimulus Profile Editor examples are located in the <;Public Documents>\National Instruments\NI VeriStand\Examples directory.
      Tip  On Windows 7/Vista, the default location of the <;Public Documents> directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the NI VeriStand API are located in the <;Program Files>\National Instruments\LabVIEW 2014\examples\NI Veristand directory.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code NIVeriStand2014KI for an up-to-date list of known issues in NI VeriStand 2014.
    The following items are the IDs and titles of a subset of issues fixed in NI VeriStand 2014. This is not an exhaustive list of issues fixed in the current version of NI VeriStand. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    477085When you add a service for a custom VI and set the Execution Mode to Wait for This Item to Synchronize, NI VeriStand ignores the timeout condition
    477079If an NI VeriStand project contains a service for a custom VI and you click the Run button, the workspace launches immediately instead of waiting for the service to complete or synchronize
    473131Compilation of a The MathWorks, Inc. Simulink® model fails when using the Reusable function with an Integrator block
    461119When you use the RemoveNode method, channel mappings are not affected until you save the system definition file
    459404In the Channel Fault Manager tool, you cannot add a fault using the Add Fault button when viewing channels in list view
    458455Compilation of a The MathWorks, Inc. Simulink® model fails when using fixed-point data types
    455667Deleted XNET signals are not properly removed after refreshing a system definition file
    436569If two inlined XNET ports have two successive frames with the same signal values, the second frame will not always be written to the bus
    435683Error -307730 is incorrectly thrown when undeploying a system definition with an asynchronous custom device
    433376The VeriStand Engine does not properly reserve PXI TTL 0 when using single-point DAQ
    432811NI VeriStand returns fatal errors when mapping a large number of channels by folder
    431615Hardware Discovery Wizard does not return all DAQ devices if some invalid devices also exist in the system definition
    431553Multirate models with timing offset throw an error on deployment
    412719Counter output DAQ channels do not work with NI CompactDAQ and the NI 9401 module
    408582The ResolvedErrorMessage property for an error object does not resolve an error code to a message
    405872Running a host-side log session with the NI VeriStand Data Logging VIs or .NET Client API that logs data from multiple targets throws error 1556 when stopping the log session
    393231Stimulus Profile Editor crashes when calling large CSV files
    377336The NI VeriStand XNET Bus Monitor does not work in common network configurations
    316028Error -1 when adding FPGA files for PCIe-7853R and PCIe-7854
    241320When deploying a .lvmodel file to a target without LabVIEW Control Design and Simulation Module the model fails to initialize with error 1003
    Using NI Launcher
    Finding All Programs
    NI VeriStand Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments NI VeriStand will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI VeriStand that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2009-2014 National Instruments. All rights reserved.
    GMT+8, 2026-4-7 17:20
