查看: 3833|回复: 0
[Patch补丁] NI VeriStand 2013f1Patch Win32Eng PC版完整版及运行版NIVS2013f1补丁
    8 小时前
  • 签到天数: 3849 天
    连续签到: 42 天
    发表于 2020-7-25 00:09:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    安装该补丁前请先安装VERISTAND2013
    NI VeriStand 2013 Win32Eng PC版完整版及运行版NIVS2013
    http://visionbbs.com/thread-24460-1-1.html
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    VS2013f1patch.txt (247 Bytes, 下载次数: 0, 售价: 1 圆)
    NI VeriStand 2013 Readme
    August 2013
    This file contains important information about NI VeriStand 2013, including system requirements and installation instructions.
    NI VeriStand is configuration-based testing software, allowing you to develop, prototype, and test control systems using hardware I/O and your simulation models. The NI VeriStand software framework enables you to perform real-time or PC-based test configuration and execution that can be easily customized and extended with LabVIEW, NI TestStand, and other software tools.
    NI VeriStand includes a run-time editable user interface as well as a test manager you can use to configure and implement triggered multi-file data logging, real-time test sequencing, stimulus generation and playback, and model calibration.
    The following sections describe support considerations for using NI VeriStand in various types of systems.
    Windows Systems1Real-Time Targets
    Operating System
    • Phar Lap ETS
    • VxWorks
    RAM/Processor
    • 2 GB of RAM
    • Multi-core processor
    • PXI controller/desktop PC—At least 256 MB of RAM2
    • CompactRIO/Single-Board RIO—At least 128 MB of RAM2
    Required Software
    • (Required) NI-DAQmx software 9.7.5 or later driver software
    • (Required) NI-VISA software 5.4.0 or later
    • (Recommended) NI-RIO 13.0 or later driver software, used by NI FPGA targets
    • (Recommended) NI-XNET 1.8.0 or later driver software, used by NI-XNET vehicle bus interface cards
    NI VeriStand software (install from MAX)
    1 The following considerations apply to using NI VeriStand on Windows:
    • NI VeriStand runs as a 32-bit application on all operating systems.
    • NI VeriStand does not support Windows 2000/NT/Me/98/95, Windows XP x64, Windows XP Service Pack 1 and 2, or the Windows Server non-R2 editions.
    • Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    2 You can achieve higher Primary Control Loop rates by using targets with higher-performance specifications.
    Note  The following sections describe system requirements that apply if you use models, LabVIEW functionality, and .NET APIs in your system.
    Simulation Models
    To configure and run a simulation using your existing compiled model, you need only NI VeriStand installed. You need additional software to perform other tasks with models, as the following list describes:
    • To develop a model using The MathWorks, Inc. Simulink® application software, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. MATLAB® software (32-bit or 64-bit versions) and The MathWorks, Inc. Simulink software.
      Note  NI VeriStand supports the 64-bit versions of the MATLAB or Simulink software starting in R2010b and continuing in the versions listed in the NI KnowledgeBase document titled NI VeriStand Version Compatibility on ni.com.
    • To compile a model developed using The MathWorks, Inc. Simulink software for use on a Microsoft Windows or LabVIEW real-time target, you must be a licensed user of and have the following software installed on the host computer: The MathWorks, Inc. Real-Time Workshop® (Simulink Coder®).
    • For deploying a compiled model to a LabVIEW real-time target, refer to the NI KnowledgeBase document titled NI VeriStand Version Compatibility on ni.com for a list of compilers that are tested and supported.
    If you use other modeling environments, contact your model vendor for requirements for developing a model and converting it into a compiled model.
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2013 or later. The LabVIEW functionality in NI VeriStand always requires like-numbered versions.
    .NET
    The NI VeriStand .NET APIs require the following Microsoft software:
    • Microsoft .NET Framework 4.0, which uses Microsoft .NET Common Language Runtime (CLR) 4.0.
    • A .NET environment capable of interacting with .NET Framework 4.0 based assemblies, such as Microsoft Visual Studio 2010 or LabVIEW 2013.
    Complete the following steps to install NI VeriStand.
    • Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • (Optional) To use LabVIEW with NI VeriStand, install the like-numbered version of LabVIEW on the host computer.
    • Insert the NI VeriStand installation media and follow the instructions that appear on the screen.
    • Install the NI-DAQmx driver software from the NI Device Drivers DVD or any NI DAQmx driver DVD.
      Note  The NI-DAQmx driver software is required to deploy a system definition to any platform, including the localhost running Windows.
    • (Optional) If using NI-XNET, insert the NI-XNET installation media and follow the instructions that appear on the screen.
    • (Optional) Activate NI VeriStand when prompted by the installer, or activate at a later time using the NI License Manager.
    For a list of new features in NI VeriStand 2013, refer to the following topic in the NI VeriStand 2013 Help posted on ni.com or installed on disk: What's New in NI VeriStand 2013.
    The following sections describe issues to be aware of when you upgrade to NI VeriStand 2013.
    Note  National Instruments recommends that you also review the Upgrade and Compatibility Issues in the readme files for each NI VeriStand version between the version from which you are upgrading and NI VeriStand 2013. To access the documents, refer to the National Instruments website at ni.com/info and enter the Info Code for the appropriate NI VeriStand version from the following list:
    • NI VeriStand 2010 readme—NIVeriStand2010RM
    • NI VeriStand 2011 readme—NIVeriStand2011RM
    • NI VeriStand 2011 SP1 readme—NIVeriStand2011SP1RM
    • NI VeriStand 2012 readme—NIVeriStand2012RM
    Models compiled from LabVIEW VIs (.lvmodel files) using LabVIEW 2012 or earlier must be recompiled using LabVIEW 2013. The LabVIEW functionality in NI VeriStand always requires like-numbered versions.
    NI VeriStand Updates and Notifications
    NI VeriStand includes the following documentation resources:
    ResourceContentsAccess Instructions
    NI Veristand HelpConceptual, how-to, and reference information for using NI VeriStand.In software: Help»Search the NI VeriStand Help
    OR
    Windows Start menu: All Programs»National Instruments»NI VeriStand»VeriStand Help
    NI VeriStand .NET API HelpReference information for the .NET APIs included with NI VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including NI LabVIEW™ and NI TestStand™.Windows Start menu: All Programs»National Instruments»NI VeriStand»VeriStand .NET API Help.
    NI VeriStand Model Framework IntroductionInformation about how to use the NI VeriStand Model Framework to compile your existing C and C++ model code so you can load your models in NI VeriStand.You can access this guide from the RootDrive:\VeriStand\xxxx\ModelInterface\custom directory, where RootDrive is the drive where NI software installs and xxxx is the NI VeriStand version number.
    Note  You must explicitly select NI VeriStand Model Framework when you run the NI VeriStand installer.
    Note  If you install NI VeriStand with the compatible version of LabVIEW, you also can access a subset of the NI VeriStand Help, including information about the NI VeriStand VIs and extending NI VeriStand functionality with LabVIEW, from the LabVIEW Help. From the pull-down menu in LabVIEW, select Help»LabVIEW Help.
    NI VeriStand includes several types of examples:
    • NI VeriStand Project—An example NI VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the <;Public Documents>\National Instruments\NI VeriStand\Projects\Example directory.
    • Stimulus Profile Editor—NI VeriStand Stimulus Profile Editor examples are located in the <;Public Documents>\National Instruments\NI VeriStand\Examples directory.
      Tip  On Windows 7/Vista, the default location of the <;Public Documents> directory is C:\Users\Public\Public Documents.
    • LabVIEW API—LabVIEW examples that use the NI VeriStand API are located in the <;Program Files>\National Instruments\LabVIEW 2013\examples\NI Veristand directory.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in NI VeriStand 2013.
    The following items are the IDs and titles of a subset of issues fixed in NI VeriStand 2013. This is not an exhaustive list of issues fixed in the current version of NI VeriStand. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    323762Deploying certain system definitions can cause several minute hang during deployment
    340234Deploying system definition with more than 64 models results in error
    381585Invalid Model C-Code Generation when Using For Each Block
    386561Error Dialog cannot be closed when Model is missing from System Explorer
    389940Search All Items by GUID does not work in stand alone VI
    396524Alarm API very slow when executing in large system definition files
    396534System Definition causes Project Explorer to take a long time to load and save
    400973Error -307673 - Another VeriStand Gateway already is connected to the execution host when multiple active network connections on the host
    404302NI VeriStand Lookup Table Scale import tool rounds all values to integers.
    409165VeriStand RT Engine requires DAQmx 9.6 on cDAQ 913x
    410975Cyclic CAN output does not send any data until a value change
    412576Waveform timestamps from multiplexing DAQ devices are wrong by the multiplex delay
    412727Model Rate for VxWorks models is not displayed correctly in NI VeriStand
    413046The Embedded Data Logger can lose all channel names if an error occurs during logging
    413452Automatic chassis master selection picks DAQ when only FPGA is added to new system definition
    414014System Definition API doesn't create MD5 or Alias properties upon creation of a new Database node
    417612PXIe 6612 and 6614 will error when used with NI VeriStand
    417696Model Parameter Manager performance is poor for large numbers of parameters
    422906Embedded Data Logger CD Log File List not updated when a log file is added
    423552Unable to compile Simulink C++ generated code (GCC and MSVC)
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI VeriStand Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments NI VeriStand will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI VeriStand that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2009-2013 National Instruments. All rights reserved.
    GMT+8, 2026-4-7 17:20
