Embedded Control and Monitoring Software Suite 2026 Q1 Win11 64bitEn 嵌入式控制和监控软件套件2026Q1英文版ECMSS26.0.0
发布日期:2026/1/28
包含的版本:2026 Q1专业版,版本号26.0.0
Windows Server 2025
语言:英文English
文件大小: 30472828928 字节 (28.38 GB)
修改日期: 2026-02-06 17:28
MD5: c89d71f0bbaf465fa8a6bb92a836a5b7
SHA1: c62ef5154a1c228f2698a0f77c933dfa6d458fa2
SHA256: 27770a7c1d2d7f7df3258495696276a35d2283e2fd8d7a4b54dce44d1a9a24ff
SHA512: 7e3d36b77e0ca021c73f0c2c1262afd57d647c3c6d7183f8b7d0c9c011c0c0a8151a8cb89ceacd084bc06a771d87409f3945917af3807c7c398bfef48cc12d24
Embedded Control and Monitoring Software Suite 2026 Q1 X64En.txt
(823 Bytes, 下载次数: 0, 售价: 40 圆)
套件包含:
| 编程环境 | | | | Product | Version | Bitness | | LabVIEW | 2026 Q1 | 32-bit and 64-bit | | G Web Development Software | 2022 Q3 | 64-bit | | | | | 附加软件 | | | | Product | Version | Bitness | | LabVIEW Real-Time Module | 2026 Q1 | 32-bit and 64-bit | | LabVIEW FPGA Module | 2026 Q1 | 32-bit and 64-bit | | LabVIEW Datalogging and Supervisory Control Module | 2026 Q1 | 32-bit | | LabVIEW Datalogging and Supervisory Control Runtime | 2026 Q1 | 32-bit | | LabVIEW FPGA Compile Farm Toolkit | 2026 Q1 | 32-bit and 64-bit | | JKI VI Package Manager | 2026 Q1 | 32-bit and 64-bit | | Vision Development Module | 2025 Q4 | 32-bit and 64-bit | | LabVIEW FPGA Compilation Tool for Vivado 2021.1 | 2026 Q1 | 32-bit and 64-bit | | | | | 驱动程序 | | | | Product | Version | Bitness | | NI CompactRIO | 2026 Q1 | 32-bit and 64-bit | | NI-DAQmx | 2026 Q1 | 32-bit and 64-bit | | NI-Serial | 2025 Q4 | 32-bit and 64-bit | | NI-VISA | 2026 Q1 | 32-bit and 64-bit | | NI-XNET | 2026 Q1 | 32-bit and 64-bit | | FlexRIO with Modular I/O | 2026 Q1 | 32-bit and 64-bit | | FlexRIO with Integrated I/O | 2026 Q1 | 32-bit and 64-bit | | FPGA Interface C API | 20.0.0 | 32-bit and 64-bit | | NI-Sync | 2026 Q1 | 32-bit and 64-bit | | NI R系列多功能RIO | 2026 Q1 | 32-bit and 64-bit | | NI Vision Acquisition Software (包含IMAQ, IMAQdx, IMAQ I/O) | 2025 Q4 | 32-bit and 64-bit |
2026Q1未更新自述文件,参考2023Q1版
Embedded Control and Monitoring Software Suite 2023 Q1自述文件2023年1月 本文件包含Embedded Control and Monitoring Software Suite 2023 Q1的安装说明和兼容性信息。 您可以在ni.com上找到更多关于此次发行的信息。 - Embedded Control and Monitoring Software Suite发行说明:已知问题,自上一发行版以来已修复的错误以及关于此次发行的说明信息。
系统要求 操作系统支持 Embedded Control and Monitoring Software Suite中包含的产品 安装说明 产品安全及关键更新 支持的硬件 查找范例 自动安装NI产品 在Microsoft Windows 11中使用NI软件 不支持的Windows操作系统 NI不再支持Phar Lap ETS实时操作系统 系统要求系统要求见各产品的自述文件。 操作系统支持Embedded Control and Monitoring Software Suite 2023 Q1支持以下操作系统: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Embedded Control and Monitoring Software Suite中包含的产品Embedded Control and Monitoring Software Suite安装程序中包含以下产品。该表可能未包含可通过您的套件序列号激活的产品的完整列表。关于系统要求、产品安装、激活、已知问题和问题修正的更多信息,请参考具体产品的自述文件。 应用程序软件产品 | 版本 | 位数 | | LabVIEW | 2023 Q1 | 32位和64位 |
注:本产品不再支持LabVIEW NXG。关于LabVIEW NXG生命周期日期和驱动程序版本支持的更多信息,请访问ni.com上的LabVIEW NXG。 附加软件产品 | 版本 | 位数 | | FPGA Interface C API | 2020 | 32位和64位 | | JKI VI Package Manager | 2023 Q1 | 32位和64位 | | LabVIEW FPGA Compilation Tool for Vivado 2021.1 | 2022 Q3 | 64位 | | LabVIEW FPGA Compile Farm工具包 | 2023 Q1 | 32位和64位 | | LabVIEW FPGA模块 | 2023 Q1 | 32位和64位 | | LabVIEW Real-Time模块 | 2023 Q1 | 32位和64位 | | Vision Development模块 | 2023 Q1 | 32位和64位 |
注:LabVIEW专业版开发系统将安装LabVIEW Advanced Signal Processing工具包、LabVIEW Desktop Execution Trace工具包、LabVIEW Digital Filter Design工具包、LabVIEW Unit Test Framework工具包、LabVIEW VI Analyzer工具包、LabVIEW Database Connectivity工具包和LabVIEW Report Generation工具包。labview\readme目录下可找到这些工具包的自述文件。 驱动程序产品 | 版本 | 位数 | | FlexRIO with Integrated I/O | 2023 Q1 | 32位和64位 | | FlexRIO with Modular I/O | 2023 Q1 | 32位和64位 | | NI CompactRIO | 2023 Q1 | 32位和64位 | | NI-DAQmx | 2023 Q1 | 32位和64位 | | NI-Industrial Communications for EtherNet/IP | 2022 Q3 | 32位和64位 | | NI-Serial | 21.5 | 32位和64位 | | NI-Sync | 2023 Q1 | 32位和64位 | | NI-VISA | 2022 Q3 | 32位和64位 | | NI-XNET | 2023 Q1 | 32位和64位 | | R系列 | 2023 Q1 | 32位和64位 |
注:本版本中不包含之前版本Embedded Control and Monitoring Software Suite中包含的部分驱动程序。如需最新驱动程序版本,请访问ni.com/downloads。 Microsoft Visual Studio支持如使用Embedded Control and Monitoring Software Suite .NET Class Library,至少需要.NET Framework 4.0。在面向.Net Framework 4.0或.NET Framework 4.5的Visual Studio版本中,Embedded Control and Monitoring Suite 2023 Q1 .NET Class Library可与Visual C#或Visual Basic .NET配合使用。 如要使用.NET API,除安装NI设备驱动程序外,还必须安装.NET类库或.NET包装器。关于.NET Framework和驱动程序支持的版本信息,及安装文件的下载地址,请访问NI软硬件的.NET资源。 安装说明从ni.com/downloads下载Embedded Control and Monitoring Software Suite。NI软件包含用于管理安装的NI Package Manager。关于使用Package Manager安装、移除、更新NI软件的详细信息,请参考NI Package Manager手册。 说明 - 如启用Windows更新,安装过程可能会由于Windows更新和安装Microsoft Visual C++ 2015运行引擎的冲突而挂起。关于解决该问题的详细步骤,请访问ni.com/r/exjq43。
- 使用软件附带的序列号激活Embedded Control and Monitoring Software Suite。关于Embedded Control and Monitoring Software Suite激活的更多信息,请参考激活产品。
产品安全及关键更新访问ni.com/security查看和订阅NI产品的安全通知。关于NI关键更新的信息,见NI软件的关键性和安全性更新。 支持的硬件请访问NI硬件与操作系统的兼容性查看各硬件设备的驱动程序、桌面操作系统和实时操作系统支持。 要查看设备信息: - 在页面的下拉列表中选择您的硬件型号以查看设备的兼容性信息。
- 在网页的下拉列表中输入您的硬件型号以筛选可用设备的列表。
注:某些兼容性信息可能仅在“NI硬件与操作系统的兼容性”页面所附的存档附件中可以找到。关于旧版本驱动程序和操作系统支持的信息,请参阅相关驱动程序版本的自述文件。 查找范例范例查找位置见各产品的自述文件。 自动安装NI产品大多数NI产品都可通过命令行自动安装,通过设置命令行参数完成安装程序用户界面或对话框的设置。 如待安装的NI产品依赖于Microsoft .NET 4.6.2,则安装NI软件之前,.NET安装程序会首先启动并在完成后提示重启。为了避免重启计算机,建议在安装NI软件之前单独安装.NET 4.6.2。 关于自动安装NI产品的详细信息,见NI Package Manager手册中的自动化安装程序主题。 在Microsoft Windows 11中使用NI软件Microsoft Windows 11是最新版本的Windows操作系统,与早期版本相比有重大改进。关于NI对Windows 11支持的详细信息,见NI产品对Microsoft Windows 11的兼容性。 不支持的Windows操作系统Embedded Control and Monitoring Software Suite不再支持Windows Vista/XP/7/8.x、Windows Server 2003/2008/2012或其他32位Windows操作系统。本产品在2021年5月1日以后发行的版本可能无法在这些操作系统上正常安装和运行。关于NI操作系统支持的详细信息,请访问 https://www.ni.com/r/win32bitsupport。 NI不再支持Phar Lap ETS实时操作系统NI软件不再支持Phar Lap ETS实时操作系统本产品在2022年5月1日以后发行的版本可能无法在这些操作系统上正常安装和运行。有关Phar Lap及其替代产品NI Linux Real-Time的支持路线图的高层信息,请访问ni.com/r/xf35k1。如需了解运行NI Linux Real-Time的PXI控制器支持的硬件信息,请访问ni.com/r/b7g5wi。 |
