查看: 191|回复: 0
[NI软件产品] NI RFmx CDMA2000 2026 Q1 Full/Runtime Win11 64bitEn RFmxCDMA2K完整版运行版26.0.0下载
    6 小时前
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2026-3-19 09:25:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx CDMA2000
    发布日期:2026/1/28
    包含的版本:2026 Q1完整版/运行版,版本号26.0.0
    Windows Server 2025
    64位完整版校验和:
    文件大小: 1421531136 字节 (1.32 GB)
    修改日期: 2026-02-07 16:38
    MD5: 9ec4cd4354f4da434295b98598eb934d
    SHA1: aed0904c0df07be5be2f8858a415465d88cef0cf
    SHA256: 1b7088a15b447dfcf9d4db54cbb27a70399f048ad6193329584c148bd2f10bff
    SHA512: a95f2d214f3a55745132c204e1ae3a8a2e9567791a5271a1fb58e28c4f043af724198b617376d18a473ac9ab185ee68d3f2aa90df9093f41b72d8d497d8dbb01
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 2026 Q1.txt (685 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1030225920 字节 (982.50 MB)
    MD5: 32297167fb8337bfeb7fbb0b1b3fb4da
    SHA1: 0155fe4ad4b9356715c62e292e9b34f6b6914ad0
    SHA256: fdee668392022e39c3c969356ec10a648b5da65b8cc1c9ec4fb40028bb246102
    SHA512: 43ab112d1f02d1113d2cd6c41e1137ba16baa52ae21cc2925812c6a8fd3b8802885ca8fd720812dbab8af85b97857f63d4a34fa293327f1846397e301a7e4c62
    RFmx CDMA2000 2026 Q1RTE.txt (710 Bytes, 下载次数: 0, 售价: 5 圆)
    2026Q1版未更新自述文件,参考2023Q3版本
    RFmx CDMA2k 2023 Q3 Readme
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx CDMA2k 2023 Q2 includes the following new feature:
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx CDMA2k supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx CDMA2k. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx CDMA2k (64-bit only)
    Required Software
    Installed Software
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2023 Q3 from RFmx CDMA2k 2023 Q2
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    GMT+8, 2026-4-15 14:49
