查看: 2227|回复: 0
[LabVIEW] NI LabVIEW 2021 SP1 f6 x64Win10 32bitEng LV2021SP1Patch6英文版离线安装包下载-32位21.1.6
     楼主| 发表于 2024-7-13 10:29:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2021 SP1 f6
    发布日期:24-5-8
    包含的版本:2021 SP1 f6专业版,版本号21.1.6
    语言:英文
    程序位数:32位
    官方原版校验和:
    文件大小: 2455678976 字节 (2.29 GB)
    修改日期: 2024-07-12 15:12
    MD5: fd580ad6b812211a7e43db765ae04f6b
    SHA1: 36cd287bf0210044e8675e0be8157acb4c92f060
    SHA256: b51d4d807167ecf8fd989583e1bd0ef8c3fa78ff08a11e460ec503ff9229f2fe
    CRC32: b6bb59f6
    官方原版缺少一个文件ni-assistant-framework-labview-2021-codegen-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg,重新添加该文件打包后的修复版本:
    文件名: ni-labview-2021-x86_21.1.6_offline_Refixed.iso
    文件大小: 2456281088 字节 (2.29 GB)
    修改日期: 2025-03-31 17:47
    MD5: b799d555e9697188c5a5ad2261925f82
    SHA1: c17e180f4b2b51a950c165fc9b7bee6e5c7e6d8f
    SHA256: 3330bbbec254b9e375729c6cb3cd1832a14fde6770f73a0d888324cead162235
    CRC32: 55217129
    注册登录视觉论坛会员,购买附件查看
    LV2021SP1Patch6x86En.txt (1.1 KB, 下载次数: 2, 售价: 10 圆)
    x86En32bit官方版本中缺少ni-assistant-framework-labview-2021-codegen-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg,安装时会报错无法打开文件:
    无法打开文件
    解决方法:
    1、直接使用之前的版本,如LV2021SP1F2En、LV2021SP1F1En英文版本,或LV2021SP1F6Zh-cn中文版本。
    2、或者是将其他版本中的ni-assistant-framework-labview-2021-codegen-x86-support_21.0.0.49152-0+f0_windows_x64.nipkg文件得到到解压目录中再重新安装(是需要解压,不能直接装载,装载是打开DVD光驱模式,无法添加文件)
    ni-assistant-framework-labview-2021-codegen-x86-support_21.0.0.49152-0 f0_window.nipkg (930.91 KB, 下载次数: 0)
    LabVIEW 2021 SP1 Readme for Windows
    January 2022
    LabVIEW 2021 SP1 (64-bit)
    LabVIEW 2021 SP1 has the following requirements:
    Operating SystemWindows 10
    Windows Server 2019
    Windows Server 2016
    Windows 10
    Windows Server 2019
    Windows Server 2016
    Note  You cannot access LabVIEW using a Guest account on Windows.
    • Use the serial number that is included with your software to activate LabVIEW. For more information on LabVIEW activation, refer to Activating a Product.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2021 SP1.
    LabVIEW 2021 SP1 adds two Place VI Contents VIs to the Functions palette. OpenSSH Exec and PuTTY SSH Exec execute a system command on an SSH server specified by user@host with OpenSSH or PuTTY (plink) respectively.
    Use the LabVIEW Platform media to install modules and toolkits supported by LabVIEW 2021 SP1 (32-bit) and LabVIEW 2021 SP1 (64-bit). When run on Windows (64-bit), LabVIEW (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW (64-bit) is available in English only.
    Refer to the NI website for information about drivers compatible with LabVIEW 2021 SP1 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW (64-bit).
    LabVIEW 2021 SP1 (64-bit) supports a limited number of modules and toolkits. The following table compares the modules and toolkits supported by LabVIEW (32-bit) and LabVIEW (64-bit).
    ✓1
    Database Connectivity Toolkit
    Digital Filter Design Toolkit
    FPGA Module
    MathScript Module
    ✓2
    Real-Time Module
    Sound and Vibration Toolkit
    Unit Test Framework Toolkit
    VI Analyzer Toolkit
    Vision Development Module
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2021 SP1.
    LabVIEW no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    374715T-01
    GMT+8, 2026-4-23 09:14
