查看: 1120|回复: 0
[NI驱动程序] NI RF Signal Generators 2024 Q2 Win11 32/64bitEng NI RF信号发生器NI-RFSG24.3.0
     楼主| 发表于 2024-6-3 11:15:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2024 Q2
    发布日期:2024/4/10
    包含的版本:2024 Q2完整版,版本号24.3.0
    文件大小: 4940679168 字节 (4.60 GB)
    修改日期: 2024-04-11 09:45
    MD5: 5e70ac26641cbe400dc393ea4f92e92f
    SHA1: 85068d0d613d90c9e5b8f9b0fcd082cdfab2b54d
    SHA256: 6548d2cd8a85fef0a1699c2f8c061f58fdbe2b121fa5179f93b0a5d7457c54fc
    CRC32: 157085b4
    RFSG2024Q2.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q2版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-4-23 09:15
