查看: 2007|回复: 0
[NI软件套件] LabVIEW myRIO Software Bundle 2015 Win32Eng LabVIEW myRIO软件套件2015
    6 小时前
  • 签到天数: 3849 天
    连续签到: 42 天
     楼主| 发表于 2023-5-14 15:12:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW myRIO软件套件
    LabVIEW myRIO软件套件为myRIO学生嵌入式设备提供LabVIEW myRIO工具包和附加软件。
    LabVIEW myRIO软件套件包含了LabVIEW编程环境和其他LabVIEW软件附件和驱动软件,用于在myRIO学生嵌入式设备上开发和部署应用程序。
    myRIO软件套件包含以下内容:
    • Required Software
      • LabVIEW Development System
      • LabVIEW Real-Time Module
      • LabVIEW myRIO Toolkit
      Optional Software
      • VI Package Manager
      • LabVIEW FPGA Module
      • Compilation Tools for Vivado
      • Vision Development Module
      • Vision Acquisition Software
      • LabVIEW Control Design and Simulation Module
        • Control Design Assistant
      • LabVIEW MathScript RT Module
      • LabVIEW Robotics Module for myRIO and roboRIO
    通常包含两个DVD文件,2015套件包含DVD1+DVD2,源于DVD实体光盘。
    发布日期:2015/10/30
    包含的版本:2015完整版
    Windows Server 2003 R2 32-bit
    Windows XP (SP3) 32-bit
    Windows Vista
    Windows 8
    Windows 7
    Windows Server 2012 R2 64-bit
    Windows 8.1
    Windows Server 2008 R2 64-bit
    应用程序位数:32
    语言:英文English
    文件名: myRIO Software Bundle 2015.zip
    文件大小: 11322633101 字节 (10.55 GB)
    修改日期: 2023-05-09 19:12
    MD5: dec9de3c13a800d18707d42b8d37a863
    SHA1: 5fd7beb32f289ddec73f8d3aef90b2a6fd56a0f6
    SHA256: c8608a9ebf45b79c74f9bbaf97d5a0c090832f0975d700551647fa6ff77ade42
    CRC32: 064f3128
    请注册登录机器视觉论坛会员,购买附件查看下载地址,充值请联系在线客服
    myRIO Software Bundle 2015.txt (430 Bytes, 下载次数: 2, 售价: 40 圆)
    LabVIEW 2015 myRIO Software Bundle Readme
    June 2015
    This file contains important information about the LabVIEW myRIO Software Bundle, including system requirements, installation instructions, and links to detailed information about included products.
    With the LabVIEW myRIO Software Bundle, one installation gives you access to the LabVIEW myRIO Toolkit and other NI software for developing myRIO applications. The LabVIEW myRIO Software Bundle contains the following products:
    Required Software
    Optional Software
    Refer to the documentation of each product for specific system requirements and supported operating systems.
    The LabVIEW myRIO Software Bundle supports the following operating systems:
    • Windows 8.0/8.1 (32-bit and 64-bit)
    • Windows XP Service Pack 3 Professional
    Complete the following steps to install LabVIEW, Real-Time Module, myRIO Toolkit, and other NI software on a development computer:
    • Log in to the development computer as an administrator or as a user with administrative privileges.
    • Insert the LabVIEW myRIO Software Bundle DVD 1.
    • Follow the instructions on the screen to install and activate the software.
    • (Optional) Insert the LabVIEW myRIO Software Bundle DVD 2 if you want to install optional software for FPGA programming.
    Using NI Launcher
    Current Application
    Icon Location
    Pin to Action
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    NI LabVIEW myRIO Software Bundle Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW myRIO Software Bundle will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the LabVIEW myRIO Software Bundle that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    Info Code
    LabWindows™/CVI™cvi_lifecycle
    © 2013–2015 National Instruments. All rights reserved.
    • EULAs are located in the \_Legal Information.txt for information on including legal information in installers built with NI products.
    375388A-01
    GMT+8, 2026-4-7 15:44
