查看: 2064|回复: 0
[LV工具模块] LabVIEW 2009 Adaptive Filter Toolkit Win32Eng LabVIEW自适应滤波器工具包2009版
    昨天 07:53
    发表于 2022-5-13 18:00:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    算法包括: LMS, 归一化LMS, 漏溢式LMS, 快速LMS, sign LMS, RLS和QR-RLS
    用于主动噪音/振动控制的X滤波LMS和归一化X滤波LMS
    范例包括: 自适应噪声/回声消除, 自适应系统辨识, LPC
    用于定点LMS自适应滤波器的仿真和NI LabVIEW FPGA代码自动生成
    2009
    文件大小: 39062048 字节 (37.25 MB)
    修改日期: 2012-08-03 21:26
    MD5: c40640e46bc9b711b98f2b57f5b7e8e4(重复下载一致)
    SHA1: 8a410fb5355d668bc62e445603c151538b40a5e9
    SHA256: bc72b9b7adaf3772e70d967501e8b49c43e312f0fc42f5e196b949601be14c30
    CRC32: 7a601c87
    百度网盘和NI官方下载下载:
    请注册登录视觉论坛账号,购买附件查看下载地址
    AFTK2009.txt (584 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2009 Adaptive Filter Toolkit Readme
    June 2009
    The LabVIEW 2009 Adaptive Filter Toolkit updates the Adaptive Filter Toolkit 1.0 to support LabVIEW 2009. This release is a maintenance release.
    The Adaptive Filter Toolkit includes tools for designing, analyzing, and simulating adaptive filters, including fixed-point adaptive filters. This file contains the following information about the Adaptive Filter Toolkit.
    An adaptive filter is a computational device that iteratively models the relationship between the input and output signals of the filter. An adaptive filter self-adjusts the filter coefficients according to an adaptive algorithm. You can use the Adaptive Filter Toolkit to create adaptive filters with the following adaptive algorithms:
    • Least mean squares (LMS) and the variants, such as normalized LMS, leaky LMS, normalized leaky LMS, sign LMS, and fast block LMS
    • Filtered-x LMS and normalized filtered-x LMS
    • Recursive least squares (RLS) and QR decomposition-based RLS (QR-RLS)
    You can apply the adaptive filters that you create to different applications, such as adaptive noise cancellation, adaptive echo cancellation, system identification, and so on. You also can create and implement fixed-point adaptive filters on National Instruments FPGA targets.
    The computer you are using must meet the following minimum system requirements to run the Adaptive Filter Toolkit:
    • Windows Vista/XP/2000
    • 50 MB free disk space
    • LabVIEW 2009 Full or Professional Development System
    Note: If you want to use the Adaptive Filter Toolkit to generate LabVIEW FPGA code for a fixed-point adaptive filter, you must install the LabVIEW FPGA Module on the host computer.
    You can install all of your LabVIEW products—including the Adaptive Filter Toolkit—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the Adaptive Filter Toolkit along with activation instructions in the following locations:
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    Refer to the LabVIEW Help, accessible by selecting Help»Search the LabVIEW Help from the pull-down menu in LabVIEW, for information about using the Adaptive Filter Toolkit.
    You can access the examples for the Adaptive Filter Toolkit by selecting Help»Find Examples to display the NI Example Finder and then navigating to the Toolkits and Modules»Adaptive Filters folder. You also can click the Find Examples link in the Examples section of the Getting Started window to display the NI Example Finder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Adaptive Filter Toolkit in the labview\examples\Adaptive Filters directory.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Adaptive Filter Toolkit.
    Important Information
    © 2009 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-24 06:38
