查看: 2733|回复: 0
[NI软件套件] HIL and Real-Time Test Software Suite 21.5 x64Win10 64bitENG 硬件在环和实时测试软件套件2021秋季版英文
    16 分钟前
  • 签到天数: 3866 天
    连续签到: 59 天
    发表于 2022-4-24 09:26:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    HIL and Real-Time Test Software Suite是用于验证嵌入式软件和运行模型物理测试的软件集合。
    HIL and Real-Time Test Software Suite将LabVIEW集成开发环境(IDE)与应用软件和模块相结合,用于创建实时测试应用程序。借助该套件,您可以开发仿真模型和控制算法,并将其部署到实时硬件中。您还可以添加自定义功能,确保测试系统具有足够的灵活性来满足几乎任何应用需求,此外,您还可以在NI可重配置I/O硬件上执行高速仿真和处理。
    套件包含:
    LabVIEW专业版开发系统
    LabVIEW高级信号处理工具包
    VeriStand完整版开发系统
    LabVIEW Real-Time模块
    LabVIEW FPGA模块
    LabVIEW控制设计与仿真模块
    LabVIEW状态图模块
    相关NI设备驱动程序
    2021Fall ENG64
    发布日期
    2022/2/17
    包含版本
    Fall 2021
    受支持的操作系统
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 35216240640 字节 (32.80 GB)
    修改日期: 2022-02-17 00:02
    MD5: 97cb9712348cb464882f577987c3b404(官方正确)
    SHA1: 17b7a3a608d6bde7d7db126d736494b9a209678e
    SHA256: c73912bacb2af144385375f824c6d18c2b55290b04ca068a49ab8100c3621410
    CRC32: 550268e1
    HIL21.5x64ENG.txt (783 Bytes, 下载次数: 1, 售价: 40 圆)
    HIL and Real-Time Test Software Suite Fall 2021 Readme
    February 2022
    This file contains installation instructions and compatibility information for HIL and Real-Time Test Software Suite.
    Installation InstructionsInstalling and Activating the HIL and Real-Time Test Software Suite
    NI installs the HIL and Real-Time Test Software Suite using NI Package Manager. If you do not already have NI software installed, the HIL and Real-Time Test Software Suite installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the HIL and Real-Time Test Software Suite. For more information on the HIL and Real-Time Test Software Suite activation, refer to NI Software Activation.
    If you install software using the HIL and Real-Time Test Software Suite installation media, complete the following steps to install products:
    • Insert the HIL and Real-Time Test Software Suite installation media.
    Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the HIL and Real-Time Test Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the HIL and Real-Time Test Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    Installing the Proper Versions of LabVIEW
    When programming NI FPGAs for NI R Series Multifunction RIO, NI CompactRIO, or NI-Industrial Communications for EtherCAT hardware, you must install 32-bit versions of the following software.
    • LabVIEW
    • LabVIEW FPGA module
    • (Optional) LabVIEW Real-Time Module.
    This software is needed to perform programming operations, such as developing and compiling bitfiles for use with VeriStand. For other VeriStand-related programming tasks, such as creating custom devices and using VeriStand APIs, use the 64-bit version of LabVIEW.
    Products Included on the HIL and Real-Time Test Software Suite Media
    The following products are included on the HIL and Real-Time Test Software Suite media. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Note  Some drivers included with previous versions of the HIL and Real-Time Test Software Suite are not included with this release. Visit ni.com/downloads for the latest driver versions.
    Application Software
    Version
    Bitness
    LabVIEW2021 SP132-bit and 64-bit
    NI Switch Executive 202121.5.032-bit and 64-bit
    VeriStand202164-bit
    Add-Ons
    Version
    Bitness
    JKI VI Package Manager2021 SP132-bit and 64-bit
    LabVIEW Advanced Signal Processing Toolkit202132-bit and 64-bit
    LabVIEW Control Design and Simulation Module202132-bit and 64-bit
    LabVIEW Desktop Execution Trace Toolkit202132-bit and 64-bit
    LabVIEW Digital Filter Design Toolkit202132-bit and 64-bit
    LabVIEW FPGA Compilation Tool for ISE 14.7202032-bit and 64-bit
    LabVIEW FPGA Compilation Tool for Vivado 2019.1202064-bit
    LabVIEW FPGA Compile Farm Toolkit202132-bit and 64-bit
    LabVIEW FPGA Module202132-bit and 64-bit
    LabVIEW MathScript Module202132-bit and 64-bit
    LabVIEW Model Interface Toolkit202164-bit
    LabVIEW Real-Time Module202132-bit and 64-bit
    LabVIEW Unit Test Framework Toolkit202132-bit and 64-bit
    LabVIEW VI Analyzer Toolkit202132-bit and 64-bit
    VeriStand Model Framework202132-bit and 64-bit
    VeriStand Model Generation Support for LabVIEW 2021202132-bit and 64-bit
    Driver Software
    Version
    Bitness
    FlexRIO with Integrated I/O21.5.032-bit and 64-bit
    FlexRIO with Modular I/O21.5.032-bit and 64-bit
    NI CompactRIO21.0.032-bit and 64-bit
    NI R Series Multifunction RIO21.5.032-bit and 64-bit
    NI-488.221.5.032-bit and 64-bit
    NI-DAQmx21.3.032-bit and 64-bit
    NI-DCPower21.5.032-bit and 64-bit
    NI-Industrial Communications for EtherCAT21.5.032-bit
    NI-SWITCH21.3.032-bit and 64-bit
    NI-Sync21.3.032-bit and 64-bit
    NI-VISA21.5.032-bit and 64-bit
    NI-XNET21.5.032-bit and 64-bit
    PXI Platform Services21.5.032-bit and 64-bit
    Note  The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit. You can locate the readmes for these products in the labview\readme directory.
    To compare the products included in NI Software Suites, including the HIL and Real-Time Test Software Suite, refer to the NI Software Portfolio.
    HIL and Real-Time Test Software Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2014–2022 National Instruments Corporation. All rights reserved.
    • EULAs are located in the \_Legal Information.txt for information on including legal information in installers built with NI products.
    377943F-01
    GMT+8, 2026-4-24 08:08
