查看: 2044|回复: 0
[RTE运行引擎] NI RFmx WLAN 20.0 Runtime Win64ENG RFmx无线局域网络20.0运行版-64位
    15 分钟前
  • 签到天数: 3866 天
    连续签到: 59 天
    发表于 2022-4-13 11:05:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    RFmx WLAN为WLAN 802.11a/b/g/j/p/n/ac/ax/be测试应用提供信号生成和分析功能。
    RFmx WLAN(Wireless Local Area Networks)是一个测量API,旨在扩展NI RF仪器生成和分析WLAN 802.11信号的能力。该软件可以通过误差矢量幅度(EVM)、频谱发射屏蔽(SEM)、发射功率(TXP)等符合标准的物理层测量,对802.11a/b/g/j/p/n/ac/ax/be信号进行分析。此外,你可以使用RFmx WLAN生成和分析多达8x8的多输入和多输出(MIMO)单用户和多用户信号,并为每个用户提供灵活的配置、损伤和结果。您可通过交互式软面板快速轻松地执行和调试测量,使用附带的RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:
    2020/6/9
    包含的版本:
    20.0运行版
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 600238080 字节 (572.43 MB)
    修改日期: 2020-06-09 15:48
    MD5: 49dbc062ee4706c7a7d577cc2d85c7bc
    SHA1: 208972c0e78c4b6bdd3bde598aa4a56314575417
    SHA256: 4fc76443b1cae31e6ace5f5ded205b5d7e24c3ddd4ae193c1bd904b708610db8
    CRC32: bf0489bd
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx WLAN 20.0RTE64.txt (571 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WLAN 20.0 Readme
    June 2020
    This file contains important information about the RFmx WLAN, including system requirements, and installation instructions.
    Installed Software
    RFmx WLAN Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    RFmx WLAN supports the following features:
    • Support for OFDM physical layer of 802.11ax Single-User (SU), Multi-User (MU), Extended Range SU, and Trigger-Based PPDUs in single transmit chain configuration, conforming to IEEE P802.11ax/D4.3.
    • Support for OFDM physical layers of 802.11a, 802.11j, 802.11p, 802.11n, and 802.11ac in single transmit chain configuration.
    • Support for channel bandwidths of 20 MHz, 40 MHz, 80 MHz, and 160 MHz for OFDM physical layers.
    • Support for modulation accuracy, transmit power, and spectrum emission mask measurements on OFDM physical layer signals.
    • Support for DSSS physical layer of 802.11b/g.
    • Support for modulation accuracy, transmit power, power ramp, and spectrum emission mask measurements on DSSS physical layer signals.
    RFmx WLAN 20.0 includes the following new features:
    • Support for packet data decoding
    • Support for EVM Noise Compensation on PXIe-5830/5831
    • Support for analysis and data decoding for MCS 12 and MCS 13 in 802.11ax
    • Support for 320MHz in 802.11ax SU PPDU for early testing of the 802.11be 320MHz channels
    RFmx WLAN 19.1 includes the following new features:
    • Addition of per user EVM and per user constellation traces for 802.11ax
    • Addition of preamble frequency error trace for OFDM standards
    • Support for channel estimation on L-LTF for OFDM Standards
    • Addition of PE Disambiguity attribute for Trigger based PPDU analysis
    • Support for preamble punctured MU PPDU in 802.11ax for SEM measurement
    • Support for 802.11ax MU PPDU demodulation when number of HE-SIG-B symbols exceeds 16
    • Support for 4096 QAM in 802.11ax
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    RFmx WLAN 19.0 includes the following new features:
    • Support for PXIe-5830
    Vector Signal Analyzers
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5840
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    • PXIe-5646
    RFmx WLAN has the following requirements:
    RFmx WLAN 20.0 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx WLAN dropped support for all 32-bit Windows operating systems. RFmx WLAN will not install or run on an unsupported OS. Refer to RFmx WLAN Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, RFmx WLAN dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use RFmx WLAN 20.0 to an unsupported OS. Additionally, after installing RFmx WLAN 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. To add support for application software installed after installing RFmx WLAN modify your RFmx WLAN installation or launch the RFmx WLAN installer again. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx WLAN
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, 2020
    Required Software
    If you are using the RFmx WLAN .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WLAN .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    NI installs RFmx WLAN using NI Package Manager. If you do not already have NI software installed, RFmx WLAN installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WLAN. For more information on RFmx WLAN activation, refer to National Instruments Software Activation .
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WlanMX.Fx40.dll
    Select Start » All Programs » National Instruments » RFmx WLAN » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » NI-RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » All Programs » National Instruments » RFmx WLAN » RFmx WLAN Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx WLAN HelpHTML/Windows HelpContains primary help content for RFmx WLAN. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WLAN
    • A complete reference for all RFmx WLAN programming functions and VIs
    RFmx WLAN 20.0 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx WLAN examples at Start » All Programs » National Instruments » RFmx WLAN » RFmx WLAN Examples.
    The following items are behavior changes in RFmx WLAN 20.0 from RFmx WLAN 19.1.
    • SEM Mask creation now accounts for nearest bin quantization of offset start and stop frequencies
    The following items are behavior changes in RFmx WLAN 19.1 from RFmx WLAN 19.0.
    • Dropped support for Cleaner Spectrum property on PXIe-5830 and PXIe-5831 devices
    • Obsoleted RFmxWLAN Analyze (IQ) and RFmxWLAN Analyze (Spectrum) APIs. Use RFmxWLAN Analyze (IQ, 1 Wfm) and RFmxWLAN Analyze (Spectrum, 1 Wfm) APIs instead
    The following items are behavior changes in RFmx WLAN 19.0 from RFmx WLAN 3.0.
    You can access the RFmx WLAN known issues online at RFmx WLAN 20.0 Known Issues.
    You can access the RFmx WLAN bug fix list online at RFmx WLAN 20.0 Bug Fixes. This list describes a subset of issues fixed in RFmx WLAN. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    RFmx WLAN will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2019–2020 National Instruments. All rights reserved.
    377888D-01
    GMT+8, 2026-4-24 08:08
