查看: 2030|回复: 0
[RTE运行引擎] NI RFmx W-CDMA/HSPA+ 20.7.1 Runtime x64Win10 64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试20.7.1运行版-64位
    16 分钟前
  • 签到天数: 3866 天
    连续签到: 59 天
    发表于 2022-4-12 12:36:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:
    2021/7/22
    包含的版本:
    20.7.1运行版
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 611106816 字节 (582.80 MB)
    修改日期: 2021-07-22 02:19
    MD5: 6cf87daf0067d28d9be0d187ef3cc142
    SHA1: 5e402f67d1c5fb73e79a7e55dc6a94e803271753
    SHA256: 1f978ec6bf2a28e51e489ab59997a8bc03a84dfd568475c52123c8288c9c6e05
    CRC32: fe4918dc
    注册登录视觉论坛用户,购买附件查看下载地址
    NI RFmx W-CDMA~HSPA 20.7.1RTE64.txt (579 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WCDMA 20.7.1 Readme
    July 2021
    Installed Software
    RFmx WCDMA is an optimized API for performing physical layer measurements on WCDMA cellular standard signals. RFmx WCDMA is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx WCDMA 20.0 includes the following new features:
    RFmx WCDMA 19.1 includes the following new feature:
    RFmx WCDMA 19.0 includes the following new features:
    • Addition of RFmx WCDMA Soft Front Panel (SFP 64-bit) with debug support
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    • PXIe-5668 with PXIe-5698
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5841 with PXIe-5655
    RFmx WCDMA 20.7.1 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 20.7.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 20.7.1 to an unsupported OS. Additionally, after installing RFmx WCDMA 20.7.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to  Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx WCDMA
    LabVIEW2017, 2018 SP1 f4 patch, 2019 SP1 f3 patch, or 2020 SP1
    Required Software
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation .
    Installed Software
    ItemInstalled Location
    Import Library files (64-bit)
    Select Start » All Programs » National Instruments » RFmx WCDMA » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » NI-RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » All Programs » National Instruments » RFmx WCDMA » RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx WCDMA HelpHTML/Windows HelpContains primary help content for RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx WCDMA
    • A complete reference for all RFmx WCDMA programming functions and VIs
    RFmx WCDMA 20.7.1 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx WCDMA examples at Start » All Programs » National Instruments » RFmx WCDMA » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    The following are the behavior changes in RFmx WCDMA 19.1 from RFmx WCDMA 19.0.
    • Obsoleted RFmxWCDMA Analyze (IQ) and RFmxWCDMA Analyze (Spectrum) APIs. Use RFmxWCDMA Analyze (IQ, 1 Wfm) and RFmxWCDMA Analyze (Spectrum, 1 Wfm) APIs instead.
    The following are the behavior changes in RFmx WCDMA 19.0 from RFmx WCDMA 3.0.
    • Deprecated the Recommended I/Q Measurement Bandwidth property in RFInstr.
    • Dropped support for RFmx WCDMA Measurement Interactive Panel.
    You can access the RFmx WCDMA known issues online at RFmx WCDMA 20.7 Known Issues.
    You can access the RFmx WCDMA bug fix list online at RFmx WCDMA 20.7 Bug Fixes. This list describes a subset of issues fixed in RFmx WCDMA. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    © 2015–2021 National Instruments Corporation. All rights reserved.
    375559P-01
    GMT+8, 2026-4-24 08:09
