查看: 1937|回复: 0
[RTE运行引擎] NI RFmx W-CDMA/HSPA+ 2.4 Runtime Win64ENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试2.4运行版-64位
    16 分钟前
  • 签到天数: 3866 天
    连续签到: 59 天
    发表于 2022-4-12 11:27:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    发布日期:
    2017/12/6
    包含的版本:
    2.4运行版
    Windows 8.1
    Windows 7 (SP1) 64-bit
    Windows 10
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 355471376 字节 (339.00 MB)
    修改日期: 2017-12-11 16:27
    MD5: d164297b99c40b6e32fb5015cad59382
    SHA1: 374643ac7f13406bd5ed2d564c9987e26c1a3ae7
    SHA256: 967df78b106fead484ffef397c3a62d9e3a183a2eafe35ba67538c3b84c07793
    CRC32: 1b64544b
    注册登录视觉论坛用户,购买附件查看下载地址
    NI RFmx W-CDMA~HSPA 2.4RTE64.txt (518 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-RFmx WCDMA 2.4 Readme
    November 2017
    This file contains important information about NI-RFmx WCDMA and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI-RFmx WCDMA
    NI-RFmx WCDMA 2.3 includes the following new features:
    • Addition of Code Domain Analysis (CDA) measurement
    • Support for multi-carrier in ModAcc measurement
    NI-RFmx WCDMA 2.2 includes the following new features:
    • Addition of QEVM measurement
    • Addition of Slot Phase measurement
    • Addition of 21 additional standard defined UL test models in ModAcc measurement
    • Support for I/Q gain imbalance in ModAcc measurement
    • Support for quadrature skew in ModAcc measurement
    • Support for Limited Configuration Change when sweeping frequency and reference level in test applications
    • Support for LO leakage avoidance on VST devices
    • Support for reading the measurement configuration internally used by NI-RFmx in spectral measurements
    NI-RFmx WCDMA 2.1 f4 includes the following bug fixes and updates:
    • Recommended IQ Pre Trigger Time property now returns a positive number instead of a negative number. This property is applicable when NI-RFmx is used in the Analysis-Only mode.
    Caution  Before you install NI-RFmx WCDMA 2.4, ensure that you have uninstalled all related NI-RFmx 1.0 products.
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    • NI PXIe-5668R
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI-RFmx WCDMA 2.4 supports the following operating systems:
    Note  NI-RFmx WCDMA 2.4 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • RAM—2 GB*
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-RFmx WCDMA. To add support for ADEs installed after installing NI-RFmx WCDMA, modify your NI-RFmx WCDMA installation or launch the NI-RFmx WCDMA installer again.
    • NI LabVIEW 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, 2016, or 2017
    Note  NI-RFmx WCDMA will not operate correctly without the service packs and patches previously mentioned.
    Other Required Software
      • (32-bit) windows\system32
    ItemInstalled Location
    Import Library files (32-bit)\Shared\ExternalCompilerSupport\C\include
    Import Library files (64-bit)
    C, .NET
    Examples\NI-RFmx\WCDMA\Examples
    Examples\LabVIEW \examples\RFmx\WCDMA
    Select Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Measurement Interactive Panel to launch the NI-RFmx WCDMA Measurement Interactive Panel.
    Documentation for NI-RFmx WCDMA is located at Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFmx WCDMA HelpHTML/Windows HelpInformation about NI-RFmx WCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFmx WCDMA
    • A complete reference for all NI-RFmx WCDMA programming functions and VIs
    NI-RFmx WCDMA 2.4 ReadmeHTML (this document)Information about supported hardware, supported operating systems, new features, fixed issues, and legal notices.
    NI-RFmx WCDMA palette VIs are available from the Functions»Measurement I/O»NI-RFmx»WCDMA palette.
    You can access all the installed NI-RFmx WCDMA examples at Start»All Programs»National Instruments»NI-RFmx WCDMA»NI-RFmx WCDMA Examples.
    NI-RFmx WCDMA 2.4 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-RFmx WCDMA drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-RFmx WCDMA 2.4 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFmx WCDMA 2.4 to an unsupported OS. Additionally, after installing NI-RFmx WCDMA 2.4, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Select NI-RFmx WCDMA 2.4 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-RFmx WCDMA 2.4 installation, the following software is installed. To completely remove the NI-RFmx WCDMA 2.4 installation from your system, you must also remove the following package:
    • NI-RFmx WCDMA Runtime 2.4
    • NI-RFmx WCDMA Runtime 2.4 (64-bit)
    The following items are the behavior changes in NI-RFmx WCDMA 2.3.1 from NI-RFmx WCDMA 2.3.
    • Changed the default value of the IQ Power Edge Source property to ""(empty string).
    • The alias 'default@WCDMA' for the default signal name is accepted as a valid signal name in a selector string parameter.
    • LabVIEW built binaries using RFmx versions older than 2.2 are no longer supported.
    You can access the software and documentation known issues list online. Refer to the NI-RFmx WCDMA 2.4 Known Issues at ni.com for an up-to-date list of known issues in NI-RFmx WCDMA 2.4.
    The following items are the IDs and titles of a subset of issues fixed in NI-RFmx WCDMA. This is not an exhaustive list of issues fixed in the current version of the NI-RFmx WCDMA. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following item is the change in NI-RFmx WCDMA 2.4 from NI-RFmx WCDMA 2.3.1
    640495Fixed an issue where switching between measurements from an NI-RFmx cellular personality to Demod resulted in higher EVM on 5668R.
    The following items are changes in NI-RFmx WCDMA 2.3.1 from NI-RFmx WCDMA 2.3.
    The following items are changes in NI-RFmx WCDMA 2.3 from NI-RFmx WCDMA 2.2.
    641152Fixed an issue with configuring User Defined Channel properties in ModAcc and SlotPhase measurements with a named signal.
    © 2015–2017 National Instruments. All rights reserved.
    375559F-01
    GMT+8, 2026-4-24 08:08
