查看: 3430|回复: 0
[NI软件产品] NI Multisim Blue Premium 14.0 Win32 Eng/Ger/Jpn NI电路设计软件高级版14.0
    发表于 2021-3-13 23:07:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Multisim Component Evaluator Mouser Electronics Edition电路设计软件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    文件大小: 1023193944 字节 (975.79 MB)
    修改日期: 2015-07-29 13:12
    MD5: 2aa0750e75e768a8475a0fc3664f060e
    SHA1: aee475ee114bd80f50e9832e606f8f72bac075f6
    SHA256: 8cb25f00b4b135f16676699b034d64353b6fee99151df3503d93bf67791beac0
    CRC32: 0bf7fc6a
    MultiSIM_BLUE_Premium14.0.txt (601 Bytes, 下载次数: 0, 售价: 12 圆)
    Multisim Component Evaluator Mouser Electronics Edition 14.0 Readme for Windows
    May 2015
    This file contains important last-minute information about Multisim Component Evaluator.
    Refer to the Getting Started with NI Multisim Component Evaluator Mouser Electronics Edition manual for useful information including a tutorial. You can access this PDF from Start»All Programs»National Instruments»Multisim Component Evaluator 14.0»Mouser Electronics Edition»Documentation»Multisim Component Evaluator 14.0 Getting Started.
    Supported Platforms
    NI Multisim Component Evaluator Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    Supported Platforms
    To run Multisim Component Evaluator 14.0, your operating system (OS) must be one of:
    • Windows 8.1/8/7/Vista (32-bit and 64-bit).
    • Windows XP SP3 (32-bit).
    • Windows Server 2008 R2 (64-bit).
    • Windows Server 2003 R2 (32-bit).
    Multisim Component Evaluator 14.0 does not support Windows NT/Me/98/95/2000, Windows XP x64, or the Windows Server non-R2 editions.
    Your system must also meet or exceed the following:
    • Pentium 4/M class microprocessor or equivalent.
    • 512 MB of memory (256 MB minimum).
    • 2 GB of free hard disk space.
    • 1024 x 768 screen resolution.
    • To develop custom LabVIEW-based instruments for use in Multisim, LabVIEW 2013 or 2014 is required.
    National Instruments Multisim Component Evaluator will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Multisim Component Evaluator that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003.
    Finding All Programs
    Known IssuesLabVIEW
    • LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    • You cannot install Multisim Component Evaluator on Windows Vista Starter edition.
    Multisim
    • Multisim leaks GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behaviour and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications to either the Start screen or the Taskbar on the desktop, as necessary:
    The following is a subset of the issues fixed since the last release of Multisim Component Evaluator Mouser Electronics Edition.
    Multisim ( 7 )
    Bug IDDescription
    504903Mouser Launcher Tool doesn't handle non-US date formats.
    495889My projects browse button takes you to program files location.
    495887Clicking on Download Parts while already downloading an update can lead to a crash.
    495886MultiSIM BLUE About dialog shows database update in truncated UTC format.
    495788If the manufacturer database does not exist then the database update will not work.
    495781Mouser search LabVIEW instrument saves Proxy password in plain text.
    491019Multisim sometimes does not detect the Manufacturer database.
    When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products.
    Refer to Multisim Help, accessible from the Help menu, for information about Multisim Component Evaluator.
    © 2007–2015 National Instruments. All rights reserved.
    375239A-01
    GMT+8, 2026-4-23 09:13
