查看: 3349|回复: 0
[NI软件产品] NI Circuit Design Suite 14.2 Pro Win32/64 Eng/Ger NI电路设计套件14.2专业版
    发表于 2021-3-13 00:38:45 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    Win32/64 Eng/Ger
    14.2Pro
    文件大小: 920307712 字节 (877.67 MB)
    修改日期: 2019-05-15 23:08
    MD5: 85289db945bfa7d2236bf2571634a064
    SHA1: 47428c81120c3c6ebd3d25b7b764a59fe4c8b1cf
    SHA256: d9f3560528e8ea7d87889ca6bbb64e18a69c2325959eaab28bad842f7d58970f
    CRC32: 7af77d50
    CDS14.2PRO.txt (615 Bytes, 下载次数: 1, 售价: 10 圆)
    NI Circuit Design Suite 14.2 Readme for Windows
    March 2019
    This file contains important information about NI Circuit Design Suite 14.2 for Windows, including installation instructions and known issues.
    Refer to Getting Started with NI Circuit Design Suite for useful information about getting started with Circuit Design Suite. You can access this PDF from Start»All Programs»National Instruments»Circuit Design Suite 14.2»documentation»Getting Started with NI Circuit Design Suite. You can also access the PDF from the Multisim or Ultiboard Help menu.
    Circuit Design Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Circuit Design Suite 14.2 has the following requirements:
    • Pentium 4M (or equivalent) or later (32-bit)
    • Pentium 4 G1 (or equivalent) or later (64-bit)
    • 1 GB of memory
    • 2 GB of free hard disk space
    • 1024 x 768 screen resolution
    • To develop custom LabVIEW-based instruments for use in Multisim, LabVIEW 2017, 2018, or 2019 Full or Professional Development System is required.
    Additional System Requirements for Modules and Toolkits
    The LabVIEW Multisim Co-Simulation Plug-in has the following requirements:
    • LabVIEW 2017, 2018, or 2019 Full or Professional Development System (32-bit)
    • LabVIEW 2017, 2018, or 2019 Control Design and Simulation Module
    To install the LabVIEW Multisim API Toolkit, you must already have LabVIEW 2017, 2018, or 2019 Full or Professional Development System (32-bit) installed.
    Circuit Design Suite 14.2 supports the following operating systems:
    • Windows 10 (version 1809)/8.1 Update 11/7 SP12
    Note
    • In 2016 Circuit Design Suite dropped support for Windows Vista, Windows XP, and Windows Server 2003, and installations of Windows 7 without any service packs. Circuit Design Suite 14.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Circuit Design Suite 14.2 to an unsupported OS. Additionally, after installing Circuit Design Suite 14.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?
    • Refer to Circuit Design Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    To install Circuit Design Suite using the installer from ni.com/download/multisim, double-click the setup.exe file in the root directory of the installer and follow the instructions on the screen to install this product.
    With the purchase of the Circuit Design Suite, you have access to Multisim Live Premium, our web-based component of Multisim, at no additional cost. Visit multisim.com/premium to activate Multisim Live Premium.
    Note  If you purchased this product with an NI Software Suite or NI Product Bundle, use the installer that shipped with your purchase to install this product.
    Installing Multiple Versions
    Circuit Design Suite 14.2 installs side-by-side with Circuit Design Suite 13.x and prior.
    Archiving Circuit Design Suite Databases
    NI recommends that you regularly back up the files created within the Multisim and Ultiboard components of Circuit Design Suite. Additionally, you should back up internal files that store user-created data, such as databases. For more information about which files to backup and where to find them, refer to the Multisim Help or Ultiboard Help.
    Uninstalling
    Uninstalling Circuit Design Suite will not remove user data. For more information about the locations of user database and configuration files, refer to the Archiving Data Help topic.
    Known IssuesLabVIEW
    LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Multisim Help and Ultiboard Help display in very small windows on high resolution monitors (e.g., 3200 x 1800). To enlarge the windows, click in a help topic, hold down and spin the mouse wheel. For notebook computers with precision touchpads, hold down and use pinch-in and pinch-out gestures to zoom to the desired level.
    Circuit Design Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2006–2019 National Instruments. All rights reserved.
    375231D-01
    GMT+8, 2026-4-23 09:15
