查看: 3225|回复: 0
[NI软件产品] NI Circuit Design Suite 14.1 Edu Win32Eng/Ger NI电路设计套件14.1教学版
    发表于 2021-3-13 00:35:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    14.1 EDU
    zip
    文件大小: 786920312 字节 (750.47 MB)
    修改日期: 2019-06-25 02:42
    MD5: 1d364f904992ca2c7ed08dc0be54f5d6(官方正确)
    SHA1: 877cf15ac8479abf9985cbccbb5cabf841ec0168
    SHA256: c9181be0049fdadf2fb955b7c7549c6a001116c721845ac7bdb61a32ff5e4489
    CRC32: f652b338
    CDS14.1EDU.txt (630 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Circuit Design Suite 14.1 Readme for Windows
    February 2017
    This file contains important last-minute information about Circuit Design Suite 14.1 for Windows, including installation and compatibility issues.
    Refer to Getting Started with NI Circuit Design Suite for useful information about getting started with Circuit Design Suite. You can access this PDF from Start»All Programs»National Instruments»Circuit Design Suite 14.1 Documentation»Getting Started.
    You can also access this from the Multisim or Ultiboard Help menu.
    Supported Platforms
    Installing Circuit Design Suite 14.1
    New Components
    Supported Platforms
    To run Circuit Design Suite 14.1, your operating system (OS) must be one of:
    • Windows 10, 8.1 or 7 SP1.
    • Windows Server 2012 R2.
    • Windows Server 2008 R2 SP1.
    Your system must also meet or exceed the following:
    • Pentium 4M (or equivalent) or later (32-bit).
    • Pentium 4 G1 (or equivalent) or later (64-bit).
    • 1 GB of memory.
    • 2 GB of free hard disk space.
    • 1024 x 768 screen resolution.
    • To develop custom LabVIEW-based instruments for use in Multisim, LabVIEW 2015 or 2016 is required.
    Note
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/info and enter the Info Code exjq43 for more information and steps to resolve this issue.
    Installing Multiple Versions
    Circuit Design Suite 14.1 installs side-by-side with Circuit Design Suite 13.x and prior.
    Archiving Circuit Design Suite databases
    National Instruments recommends that you regularly back up the files created within the Multisim and Ultiboard components of NI Circuit Design Suite. Additionally, you should back up internal files that store user-created data, such as databases. For more information about which files to backup and where to find them, refer to the Help.
    Uninstalling
    Uninstalling Circuit Design Suite will not remove user data. For more information about the locations of user database and configuration files, refer to the Archiving Data Help topic.
    Circuit Design Suite 14.1 Updates and Notifications
    You can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during an automatic installation of NI software.
    • For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications to either the Start screen or the Taskbar on the desktop, as necessary:
    Windows 8.1 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.1 DesktopStart screenRight-click application and select Pin to Start
    Windows 8.1 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    For more information about NI support for Windows 8.1, visit ni.com/windows8.
    Known IssuesLabVIEW
    LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Multisim and Ultiboard leak GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behavior and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    Multisim Help and Ultiboard Help display in very small windows on high resolution monitors (e.g., 3200 x 1800). To enlarge the windows, click in a help topic, hold down Ctrl and spin the mouse wheel. For notebook computers with precision touchpads, hold down Ctrl and use pinch-in and pinch-out gestures to zoom to the desired level.
    The following is a subset of the issues fixed since the last release of Circuit Design Suite.
    Multisim ( 15 )
    Bug IDDescription
    601548MultiSim throws Internal Simulation Error with Word generator and Logic Analyzer.
    615490When using Worst Case Scenario analysis, the values change when they shouldn't for different runs of the analysis.
    588152Breadboard view causes Multisim to crash for QuizShow sample file in Student tier.
    615085Worst case does not always use the right component values when pressing the play button.
    581111Greek lettering used about pins of Symbols for Induction Machine Wound Extended and Induction Machine Squirrel Cage Extended, do not correspond well with the Pin Names applied.
    572487DIVIDER symbol should use autocolor.
    572481ABM Sources should have useful model name.
    572485Improve symbol pin label positions for the VOLTAGE_GAIN_BLOCK.
    586695Importing code model DLLs does not work.
    363322Power Sources failing ERC checks in a expected configuration.
    539505OECL font-style and font-size not working.
    562105Component 74HC85XX_6V produce netlist errors when try to run a simulation.
    520560Spice warnings do not appear in Multisim spreadsheet view.
    610772Multisim 14.0 not assigning net names.
    Ultiboard ( 4 )
    Bug IDDescription
    568090No polarity marker in certain electrolytic capacitors footprints in Ultiboard.
    569718Fanout does not work on parts that use THT pins in addition to SMT pads.
    587824Pins are not recognized when forward annotated to Ultiboard 14.0.
    614189Vias in attached file are incorrectly connected to power planes when exported to Gerber.
    New Components
    Refer to the Database section of the Multisim 14.1 Features and Improvements topic of Multisim Help for a list of new components.
    Legal InformationCopyright
    © 2006-2017 National Instruments Corporation. All rights reserved.
    375231C-01
    GMT+8, 2026-4-23 09:14
