查看: 3985|回复: 0
[NI软件产品] NI Circuit Design Suite 14.0 Pro Win32Eng/Ger NI电路设计套件14.0专业版
    发表于 2021-3-13 00:30:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    14.0Pro
    zip
    文件大小: 716561237 字节 (683.37 MB)
    修改日期: 2019-06-25 02:41
    MD5: 46ee74f1db1a5066e53432619eff0197(官方正确)
    SHA1: 9e65781337e08b64ce4ded6ca7608e4ef8251035
    SHA256: 47a8330cae50a86e5b31525ef1e05f014807d5aa0e8441824ee3f9d133be144f
    CRC32: c7629a8f
    exe
    文件大小: 717312856 字节 (684.08 MB)
    修改日期: 2015-03-27 10:23
    MD5: c3fb4f9699b65ee7fb817a421d60c20d
    SHA1: cd295c0ea3015b94f1c36b8534168d7a8e239c49
    SHA256: 5bd697f15e14f97b9323e223640670b980e6f48dd7eec58ca77a11bb507e272e
    CRC32: 443b849d
    CDS14.0PRO.txt (1.12 KB, 下载次数: 0, 售价: 10 圆)
    NI Circuit Design Suite 14.0 Readme for Windows
    April 2015
    This file contains important last-minute information about Circuit Design Suite 14.0 for Windows, including installation and compatibility issues.
    Refer to Getting Started with NI Circuit Design Suite for information about getting started with Circuit Design Suite. You can access this PDF from Start»All Programs»National Instruments»Circuit Design Suite 14.0»Documentation»Circuit Design Suite 14.0 Getting Started.
    You can also access this from the Multisim or Ultiboard Help menu.
    Supported Platforms
    Installing Circuit Design Suite 14.0
    New Components
    Supported Platforms
    To run Circuit Design Suite 14.0, your operating system (OS) must be one of:
    • Windows 8.1/8/7/Vista (32-bit and 64-bit).
    • Windows XP SP3 (32-bit).
    • Windows Server 2008 R2 (64-bit).
    • Windows Server 2003 R2 (32-bit).
    Circuit Design Suite 14.0 does not support Windows NT/Me/98/95/2000, Windows XP x64, or the Windows Server non-R2 editions.
    Your system must also meet or exceed the following:
    • Pentium 4/M class microprocessor or equivalent.
    • 512 MB of memory (256 MB minimum).
    • 2 GB of free hard disk space.
    • 1024 x 768 screen resolution.
    • To develop custom LabVIEW-based instruments for use in Multisim, LabVIEW 2013 or 2014 is required.
    NI Circuit Design Suite Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Circuit Design Suite will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Circuit Design Suite that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about Circuit Design Suite's product life cycle, visit NI Multisim OS Support and System Requirements. The information on this page applies to Multisim and Ultiboard.
    Installing Circuit Design Suite 14.0Installing Multiple Versions
    Circuit Design Suite 14.0 installs side-by-side with previous versions of Circuit Design Suite.
    Archiving Circuit Design Suite databases
    National Instruments recommends that you regularly back up the files created within the Multisim and Ultiboard components of NI Circuit Design Suite. Additionally, you should back up internal files that store user-created data, such as databases. For more information about which files to backup and where to find them, refer to the Help.
    Uninstalling
    Uninstalling Circuit Design Suite will not remove user data. For more information about the locations of user database and configuration files, refer to the Archiving Data Help topic.
    Circuit Design Suite 14.0 Updates and Notifications
    You can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during an automatic installation of NI software.
    When you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications to either the Start screen or the Taskbar on the desktop, as necessary:
    Finding All Programs
    Known IssuesLabVIEW
    LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    You cannot install Circuit Design Suite 14.0 on Windows Vista Starter edition.
    Multisim and Ultiboard leak GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behavior and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    The following is a subset of the issues fixed since the last release of Circuit Design Suite.
    Multisim ( 61 )
    Bug IDDescription
    518929Update components sometimes do not detect ELVISmx instruments components from an ELVIS schematic.
    517825Pasting a Title Block will not preserve the field values on multi-page sheet.
    514757Net names with special internal character $ is being allowed to be created, which may cause issues with the netlist.
    515526Importing a .cir file sometimes causes Multisim to crash.
    501065Schematic wires sometimes may appear as connected but in reality are not.
    509888Imported files can sometimes show a component's database location incorrectly.
    479149Unable to change the value for a RLC custom part.
    465428Setting a component value visible will sometimes place the RefDes away from the schematic symbol.
    490625Single pin source changes do not create an undo point.
    491624Modifying values on single pin sources, the SPICE netlist viewer does not get its "out of date" message.
    511469Multisim sometimes does not display correctly a component's value compared to the actual value.
    466171Component Wizard fails to provide all model nodes when line continuations are separated by comment lines.
    506416Replacing some components by hierarchical block or subcircuit within an hierarchical block will sometimes crash Multisim.
    504931Default digital graph color is difficult to see with default background.
    274344Editing a component in database should modify and not create a new component.
    493395SPICE model type is no longer shown in table view for basic RLC device models.
    491327Undo sometimes causes inconsistency between netlist and shematic.
    503533Multisim hangs when scope with normal trigger and non-default trigger value is used.
    500035Cannot use exponential number format in probe parameter values.
    368543Cannot save analysis settings without specifying output variables.
    465372The LVM source generates incorrect negative polarity signal.
    274752Oscillopscope's AC coupling generates a poor result.
    479847Uninstalling 13.0.1 causes an error message next time 12.0.1 is started.
    396771Checking for current sources in series will only check the first two nodes of objects defined in the netlist.
    282395Attribute Device incorrectly repeats attribute Value in non-RLC components.
    367605Adding a new bus line should use net name as its default bus line name.
    461943Non-ideal resistor doesn't behave correctly without brackets around its model expression.
    473601Using Update Components should report any broken connections.
    487152When adding device parameters to analysis setup, unwanted parameters are also added.
    478607Cmod S6 config files are missing internal clock pins.
    490907Renaming a DGND component will not update other DGND instances.
    440051Malconfigured pulse source causes an internal error during simulation.
    485982Hierarchical PLD design sometimes prompts for net name collision continuosly.
    488395Exponential voltage/current source has different behaviour than in PSPICE.
    485448Octave AC sweep disregards logarithmic y axis.
    486102Error mesasge is not clear when simulating with an expression that evaluates a divided by zero value.
    403700LabVIEW microphone instrument is not able to acquire data for more than 10 sec.
    274615Multisim sometimes shows a white screen for a period of time while opening a file.
    424840Component Wizard allows different number of symbol pins in ANSI vs IEC.
    467540Some frequency-domain analyses display seconds as the unit in the simulation status bar.
    323705DMM uses 1e-9ohm series resistor to measure current, which causes convergence issues.
    394799Unable to set the Xilinx path in Multisim for all users using the same computer.
    443707Fourier analysis doesn't display DC component in graph.
    393295Grapher does not appear to handle very small values well and rounds them off to zero.
    462216The grapher's Y-axis marks do not match up with trace values.
    480780AC Phase confined to and jumps between -180 and 180.
    478305RefDes and Value are 'top aligned' when part is rotated in the vertical position.
    269360Pole-zero analysis does not remember the analysis type setting.
    465765Vertical symbol text renders horizontally when placed on schematic.
    472570Triangular current source seems to only reach the peak current on the first period.
    469208Unable to assign a footprint to a component with no footprints, assignment from the spreadsheet no longer works.
    195405No clean way of stopping Wait for Next Output in Multisim COM API.
    466133Logic Converter sometimes crashes when converting an expression to logic circuit.
    465748Simulation slows down after changing parameters on the Function Generator.
    465038Certain symbols from master database are reported as invalid when saving to user database.
    347561The Schematic Statistic Report incorrectly counts each section of a multi-section component as a part.
    456597Components with unmapped model nodes can be saved to database from the model template view without warning.
    274318Placing a component with a user-created footprint will reset it to a default footprint.
    456610Adding a section to a component with custom section names doesn't map all pins.
    458840Copy and paste components to a new design will re-enumerate its refdeses.
    459432PLD components not flagged correctly after saving to database.
    Ultiboard ( 40 )
    Bug IDDescription
    470546Importing a DXF file sometimes does not draw the pads correctly.
    507801Ultiboard sometimes places annotated components on top of existing components.
    512407Moving a part around a group of parts object will cause to crash Ultiboard.
    480776Toggling layer visibility for copper stack up layers with micro via placed on them may lead to Multisim crash.
    268382Autorouting of buses should not have vertical trace segments.
    275699Ultiroute incorrectly runs traces over a custom pad shape.
    444411Non-standard fill styles do not work on copper areas that are not power planes.
    495370Ultiboard crashes when follow-me router is used after changing clearance.
    274648Rule precision should not round to significant digits.
    320661The unit dropdown in Global options >> PCB design does not seem to get affected when units are changed from main toolbar control.
    266630Fanout SMD does not work well in BGA packages.
    264328Follow me router violates DRC when auto narrow traces is enabled.
    275664Trace running over a via without copper ring doesn't cause connectivity error.
    387633Duplicate footprint is added to the PCB when a footprint without pin is forward annotated.
    443579Fiducial marks are located incorrectly when text attribute is used outside the board outline.
    445863Text attribute voiding uses larger boundary box when attribute is rotated.
    450179When parts are set to transparent, one can no longer see through parts in 3D view
    286414NC Drill export generates incorrect file due to some decimal points in the coordinate area of the drill.
    362253Attempting to change the RefDes visibility for multiple components will prompt an error message and will still allow to proceed.
    440295Through-hole pad properties window is missing rounded rectangle as an option.
    351243Ultiboard does not show properly when there is a μ in the component's value tag.
    445866Soldermask option in via only allows none or all of the via covered.
    284242Placing a hole does not have a soldermask on the hole by default.
    467306Ultiboard database browser failing to refresh preview and place the selected part.
    275527Net shielding field in Net Edit dialog looses focus during edit.
    290268Cannot add a vertex by simply right clicking on the vertex.
    461581Ultiboard's grab-and-drag layout behaviour is different than Multisim.
    263206Import from Protel sometimes loses via connection.
    274339Grouped components edited via spreadsheet do not undo correctly.
    274629Cannot ungroup multiple group objects at once.
    276402Using the delete Open Trace Ends tool sometimes removes complete connections.
    274708Unknown footprint is sometimes ignored when importing from an older netlist.
    324536Test point sometimes generates an invalid DRC message.
    346268Changing a value in the spreadsheet view sometimes does not update the DRC result tab.
    269514Incorrect pad radius will generate error message when ultiroute is run.
    275732False DRC errors created when placing a net bridge underneath a component.
    278859When replacing a footprint on the design, text attributes sometimes changes unexpectedly.
    272973Router sometimes will not start due to an object in the silkscreen layer.
    420397Cancelling the Gerber-D Import dialog will prompt a invalid warning message.
    420320Net bridges do not export properly to DXF.
    New Components
    Refer to the Database section of the Multisim 14.0 Features and Improvements topic of Multisim Help for a list of new components.
    Important InformationCopyright
    © 2006-2015 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-23 09:15
