查看: 3038|回复: 0
[NI软件产品] NI Circuit Design Suite 12.0.1 Edu Win32Eng/Ger/Jpn NI电路设计套件12.0.1教学版
    发表于 2021-3-13 00:15:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    12.0.1EDU
    ZIP版:
    文件大小: 665881354 字节 (635.03 MB)
    修改日期: 2019-06-25 02:41
    MD5: 84de8a20ebc0eaef25aa91d8b8884dec(官方正确)
    SHA1: 42deaf273cfd0211fb0602e803a7e88bb3f4b43d
    SHA256: 9f43bb884acba0ea9cf77f21ca37b3cce8ee206f3d8145348bacecaf089156c2
    CRC32: 619ab976
    EXE版:
    文件大小: 666476544 字节 (635.60 MB)
    修改日期: 2012-08-31 03:58
    MD5: e9d8ce880be86340c33fd92ecdfb9939
    SHA1: b8f82166040e12859c01a27b708e21c305bf63f5
    SHA256: 68afe01e74260b9e899b3be5c5f0540c8a510367e7b1fe6ff4d9c225d7124329
    CRC32: 504f6a22
    CDS12.0.1EDU.txt (1.09 KB, 下载次数: 0, 售价: 10 圆)
    NI Circuit Design Suite 12.0.1 Readme for Windows
    August 2012
    This file contains important last-minute information about Circuit Design Suite 12.0.1 for Windows, including installation issues, compatibility issues, bugs fixed, and changes from Circuit Design Suite 12.0. Refer to the NI Circuit Design Suite Release Notes for a complete list of new features in Circuit Design Suite 12.0.1. You can access this document by selecting Help»Release notes in Multisim or Ultiboard or navigating to Start»All Programs»National Instruments»Circuit Design Suite 12.0»Documentation»Release Notes.
    Refer to the Getting Started with NI Circuit Design Suite manual for information about getting started with Circuit Design Suite. You can access this PDF from Start»All Programs»National Instruments»Circuit Design Suite 12.0»Documentation»Getting Started.
    Supported Platforms
    Installing Circuit Design Suite 12.0.1
    New Components
    Supported Platforms
    Circuit Design Suite 12.0.1 supports Windows XP 32-bit edition, Windows Vista 32-bit and 64-bit editions, Windows 7 32-bit and 64-bit editions, Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit). Circuit Design Suite 12.0.1 does not support Windows 2000/NT/Me/98/95, Windows XP 64-bit edition, or the Windows Server non-R2 editions.
    Installing Circuit Design Suite 12.0.1Installing Multiple Versions
    Circuit Design Suite 12.0.1 upgrades Circuit Design Suite 12.0. You cannot install Circuit Design Suite 12.0.1 side-by-side with version 12.0. You must activate Circuit Design Suite after you install it. It will not activate itself automatically.
    Archiving Circuit Design Suite databases
    National Instruments recommends that you regularly back up the files created within the Multisim and Ultiboard components of NI Circuit Design Suite. Additionally, you should back up internal files that store user-created data, such as database components. For more information about which files to backup and where to find them, refer to the Help.
    Uninstalling
    Uninstalling Circuit Design Suite will not remove user data. For more information about the locations of user database and configuration files, refer to the Archiving Data Help topic.
    Known IssuesLabVIEW
    • LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    • You cannot install Circuit Design Suite 12.0.1 on Windows Vista Starter edition.
    • In Pentium III machines, NI Multisim cannot load LV Instruments created in NI LabVIEW 2011 and 2012; this also affects LVM and TDM sources and export, and the COM API method to capture a circuit image. This is due to the use of SSE2 optimizations in LV Application Builder when LabVIEW components used in Multisim were compiled. For more information, please read KB 60CCP0XL: I Get LV-related Error Messages When Opening Multisim in a Pentium III Machine.
    • Multisim and Ultiboard leak GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behavior and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    • The Multisim Buzzer component will not generate any sound in Windows Vista 64-bit edition. This is due to Microsoft not supporting use of the Beep function in that version of Windows. The Beep function is used by this component to generate sound.
    • The upgrade to the PICC 9.82 (pro) compiler in Circuit Design Suite 12.0.1 may break existing code in MCU files since macros used by the compiler have changed. For example, WDTEN has been replaced with WDT_ON, and OPTION has been replaced by OPTION_REG.
    The following is a subset of the issues fixed between Circuit Design Suite 12.0 and Circuit Design Suite 12.0.1.
    Multisim ( 77 )
    Bug IDDescription
    365744Changing the direction of a PLD connector from the co-simulation view will sometimes crash Multisim.
    363133Expand/collapse tree items in Rename/Renumber dialog may crash in some cases.
    363087ADG802BCBZ-REEL7 and ADG819BCB do not transfer to Ultiboard correctly.
    361071Undocking virtual serial terminal VTERM window causes crash in some cases.
    360449Power variable should not appear in the analysis variables list.
    359999Placing a PLD custom configuration file as a subcircuit will sometimes crash Multisim.
    359154Locking subcircuits does not prevent the design preview to show contents.
    358846PLD connectors don't connect when placed on wire/pin.
    351410When loading an MS12 file, the saved "Probe Properties" are not restored.
    350888Non_Ideal_Battery missing in Pro Versions of Multisim.
    350611Loading Multisim version 6 or version 7 files with multisection components crashes Multisim.
    350584Placing a Hierarchical Block Outside the Design Sheet Boundary Crashes Multisim.
    349472The symbol for 74LS48 incorrectly shows active low pins.
    349258Simulation throws errors found by the netlist generator after using the In Use List.
    348533Right-click does not cancel wiring unless the first junction has been placed/connected.
    348103Some long equation models may cause simulator failures.
    347337Thermal noise source doesn't accept values from the dialog.
    347242Symbol Pins Landing Off The Grid Create Uneven Wire Connections.
    346778Pulse current source not generating correct output in some cases.
    345953INA111AU and INA111BU have incorrect footprint assigned.
    345470ThreePhaseInverter sample circuit throws convergence error in interactive simulation.
    345217Loading PSpice exported CIR files in Multisim crashes Multisim in some cases.
    344083Opening NI ELVIS II Design crashes Multisim in some cases.
    343779Noise analysis is generating incorrect spice statement.
    342877New wire names are in random order when using drag drop a component to link a set of pins.
    342841Incorrect pin assignment in the NI-sbRIO-9605 and NI-sbRIO-9606 symbols.
    342692Remap 2000+ components that are linked to Footprints with the Ultiboard Pinout field populated.
    341809Update Components will not update certain information unless the Symbol checkbox is checked.
    337864Footprint pins should not auto-populate in Edit Component dialog.
    337423Multisim crashes on disconnect after creating a BOM using the Multisim COM API.
    337393False Positive Errors when Parsing in the Edit Model dialog
    335504Time delayed switch gives incorrect results.
    335308List box in component properties does not behave as expected.
    335288Autowire component on move list box in the Global preferences allows for invalid values to be entered.
    334342Selection snippets with post-it notes opened as design snippets through external COM crash Multisim.
    332480SN74123D gets convergence error when both sections are in use.
    332429Multisim simulation time drifts relative to LabVIEW simulation time when using the LabVIEW Co-Simulation plugin.
    329918Disable SPICE netlist viewing when the circuit restriction to hide component values is enabled.
    329871Interactive simulation settings ignored on first run following a transient simulation.
    329492Relay doesn't behave as expected in some cases.
    328669Grid does not appear in Multisim for some magnifications.
    327944Adding spaces before component names using Multisim's component search yields no results.
    326744Multi-select deleting empty rows in digital Grapher doesn't delete the selections.
    326727Buses are merged incorrectly on opening the design in some cases.
    326217The footprint mapping for the MCT6 pin 3 and 4 are reversed.
    326102L64211* components have bad mappings and land pattern.
    325947Deleting a wired up component causes net names to get mixed up in some cases.
    325904Horizontal Buses Cannot Move Sideways On First Click.
    325881Multisim leaks memory when opening a Multisim 7 file.
    324690PLD designs cannot be closed using File->Close on the top level page unless all other child pages are closed.
    324614Aligning parts with wires sometimes aligns them to the edge of the design.
    322674Some components sometimes may share symbols with Rated components causing multiple drawing layers when editing the symbol
    321970F1 doesn't go to the right topic for the text block.
    321715Automatic wiring produces scrambled paths when connections are too close.
    319775ERC doesn't flag errors with pins on a single component.
    318565Using Undo after searching the component browser will not restore the browser to the previously selected family and group.
    317110Pressing the Escape key In Component Wizard Quits Without Prompting.
    315848"Auto Resize" changes comments so that they are cut off.
    314297Short Fault does not allow more than 2 shorted connections.
    313574Digital Clock and Digital Ground do not work together in purely digital circuits.
    309298The 74123 does not work as expected.
    307083LM117HVH does not function as expected.
    301516The schematic symbol for the NDS8858H is incorrect.
    296710Multisim is slow when wiring to a component with high pin count.
    288052Control_1C relay no longer works in Multisim 11.0
    284733Multisim reports an error when placing the LCD_DISPLAY_08x1 component.
    275327Nets are not properly connected across multipages when back annotating in some cases.
    275136Copying and pasting subcircuit/hierarchical block should preserve page order.
    274870Dummy pin names showing up for connectors.
    274855Hiding the symbol names and adding new connectors in a sub-circuit changes the sub-circuit connector's name.
    274775Canceling the action to create a floating wire on schematic, will leave a floating junction behind.
    274530Multisim leaves junctions behind if user cancels place wire command.
    274382Reports incorrectly show component values with the component values circuit restrictions enabled.
    273963Adding components to database when importing from orcad does not immediately show.
    273544"Highlight Selection in Ultiboard" brings all Multisim and Ultiboard windows to the foreground.
    272380Multisim allows creating zero length busses in some cases.
    222209Unable to create POWER SOURCE symbols that can be simulated.
    Ultiboard ( 73 )
    361847Keep-in Area Over Copper Area Crashes Ultiboard.
    357562Right-click Context Menu In Gerber Viewer does not work as expected.
    354078Ultiboard crashes by moving an object after deleting a group in some cases
    352489Polyline to Polygon conversion during DXF Import causes Ultiboard to hang.
    348652Narrow Trace and Follow Me router crashes Ultiboard in some cases.
    348599Rotating a Component during placement causes Ultiboard to Hang.
    346797Custom Pad Shape Used In New Part Not Selectable in Soldermask and Pastemask Layers Active.
    346796Resizing custom pad shape does not redraw correctly.
    346754Deleting a Part In Ultiboard Triggers a DRC Error And The Part Is Not Deleted From Netlist.
    344199Ultiboard DXF Export for Bottom Layers cannot be opened in AutoCAD 2012.
    342978Copy and paste a jumper or testpoint does not automatically increment the RefDes.
    341672Ultiboard becomes unstable after placing a custom netbridge pin.
    341563Place Pin dialog has length and width reversed.
    3415453D Pad Data is incorrect when rotated in increments of 45 degrees.
    340688Ultiboard crashes when placing certain objects and clicking elsewhere in some cases.
    339662Ultiboard does not display custom pads correctly in some cases.
    337306DXF import does not import line thickness correctly in some cases.
    336065Third-party DXF viewers unable to view Ultiboard DXF exports that contain certain types of text attributes.
    3360353D View incorrectly allows selecting active layer
    334850Placing a pin on a newly created PCB part will crash Ultiboard.
    333422Creating a new project does not close Recent view in some cases.
    331606SMT pin properties does not show custom pad preview correctly in some cases.
    330536IPC 356A netlist generates incorrect coordinates for custom pads.
    329698Silkscreen top and bottom graphics disappear when opened using Ultiboard v12.0 if the ' enable 3d for this object ' option was set.
    329362Through Hole Pin Properties layer selection and design toolbox active layer do not match.
    328327User being prompted to re-specify 3D font rendering if they change unrelated 3D settings.
    328214Automatic spoke generation in thermal relief has changed in version 12.0.
    327921Ultiboard does not mark a file as changed after loading a technology file.
    327524The option to ask for formation on DRC when adding teardrop to a design will ask for confirmation on every teardrop created.
    327159Pasting polygons into layers that don't exist produces voiding error messages.
    326743"Part Spacing Bottom" value in Part Group Settings has no effect on part spacing.
    326339Board Outline Problem Dialog Allows Input of Negative Numbers.
    326282Board outline fix doesn't indicate success or failure.
    326082The Shield net column in the Spreadsheet Nets tab does not behave as expected.
    325850Pads Not Displayed in Database If Copper Top Layer Is Turned Off.
    325103Ultiboard view does not jump to the plane when clicking on the net connected to the place in the spreadsheet.
    324241Trace-Length-Check in Ultiboard does not work in some cases.
    323407Advanced holes are not displayed in Ultiboard 3D view.
    323405Pin with "Advanced Holes" do not properly display the hole size.
    3214753D Preview leaks memory when it is docked.
    321437Part settings revert back after cancelling group editor dialog.
    321212The Test Point reference ID should be on by default.
    321206Moving a pie object show the full object instead of the outline.
    320813The autorouter results output in the spreadsheet does not use the system locale when displaying the date and time.
    320663Text Tool Is Disabled When Active Layer Is Solder Mask or Paste Mask.
    320243Fanout dialog allows the creation of invalid vias.
    319790Changing layers in the THT pad property dialog's pad tab, will change layers in the main design.
    319057Default width for many spreadsheet columns is too narrow.
    313500Copper areas tab does not auto-apply settings in spreadsheet view.
    307943Added DONOTANNOTATE attribute by default to netbridges, jumpers and test points.
    289732Ultiboard does not behave as expected when saving a modified part back into a user or corporate database.
    286008Trace length on the Spreadsheet view and High Speed DRC doesn't match.
    279770Jumpers Show As Unrouted Connections In Statistics Tab.
    279098Ultiboard allows creating invalid rectangles in some cases.
    278180Unable to unlock a net using the spreadsheet in some cases.
    275646In-Place Part edit allows you to irreversibly remove RefDes attribute.
    275307Find the selected net zooms to fit all pins/pads on net instead of net.
    275284Trace drawing mode is incorrectly activated after test point is dropped.
    274919Pin/pad of locked test point can be moved.
    274641Connectivity Check cannot ascertain RefDes of components in groups.
    274520Partially drawn copper area doesn't redraw properly if switching to a different tool.
    274412Errors are reported when saving a newly created netbridge whose pins are connected by an ellipse.
    274059Ultiboard incorrectly allows for attributes with duplicate tags in some cases.
    273347Select Width combo box does not contain any values after Ultiboard returns from Full Screen mode.
    273346Importing Ultiboard 5 net file cannot handle spaces in the name.
    273234Deleting a polygon vertex can create invalid shape in some cases.
    271327"Convert Closed Objects To Filled" Is Not Working in some cases.
    271315The 3D preview of a component changes incorrectly when the component is rotated on the design.
    271298Spheres attached to Ultiboard components do not get mirrored when component is placed on board bottom.
    266662Locked jumper gets pulled off the board when you start auto-routing.
    266537Clearances for small circular objects are not drawn correctly.
    346755Forward Annotation Fails to Detect That A Part Has Been Deleted in Ultiboard.
    275657In spreadsheet, clicking on column header while in-place edit is active effects the whole column.
    327522After transferring a design from Multisim to Ultiboard, multiple clearances are displayed in the Parts tab when they are disabled in the default Design Rules settings.
    333752Undoing position settings changes crashes Ultiboard.
    344558Multisim is tranferring a net assigned to a simulation only pin which will generate a DRC error in Ultiboard.
    New Components
    For information about new components, refer to the Database Improvements section of the release notes.
    Infineon Models
    The Infineon level 3 models added in this release are available in the Power Pro and Education editions of Multisim.
    © 2006-2012 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Electronics Workbench, Multisim and Ultiboard are trademarks of National Instruments. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    The EKV MOST model used in this software was developed, implemented and tested by the Electronics Laboratory (LEG) of the Swiss Federal Institute of Technology (EPFL).
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2026-4-23 09:14
