查看: 3725|回复: 0
[NI软件产品] NI Circuit Design Suite 12.0 Pro Win32Eng/Ger/Jpn NI电路设计套件12.0专业版
    发表于 2021-3-13 00:09:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    12.0PRO
    zip
    文件大小: 596408589 字节 (568.78 MB)
    修改日期: 2014-07-29 22:40
    MD5: 9377940c0dffdeccde6e039f9647e2ad(官方正确)
    SHA1: a1f638b072221a61043943f9486006b367e9cf34
    SHA256: 97fdb5b6906f535406929145f169cc9a0a12c4ba450f53863ad2879fba2578b5
    CRC32: 1855f887
    exe
    文件名: NI_Circuit_Design_Suite_12.0.exe
    文件大小: 596511392 字节 (568.88 MB)
    修改日期: 2012-02-13 23:51
    MD5: bcfcedaaf348935211c5f9e5cd4d305f
    SHA1: e04dabdb09838ff4c2258c84736b105224b4bb08
    SHA256: 7f501e0177a8d4c87a482d1376d7fde7b197a6545e45d11e860d29295ef7f697
    CRC32: 6e35e666
    CDS12.0PRO.txt (1.31 KB, 下载次数: 0, 售价: 10 圆)
    NI Circuit Design Suite 12.0 Readme for Windows
    January 2012
    This file contains important last-minute information about Circuit Design Suite 12.0 for Windows, including installation issues, compatibility issues, bugs fixed, and changes from Circuit Design Suite 11.x. Refer to the NI Circuit Design Suite Release Notes for a complete list of new features in Circuit Design Suite 12.0 . You can access this document by selecting Help»Release notes in Multisim or Ultiboard or navigating to Start»All Programs»National Instruments»Circuit Design Suite 12.0»Documentation»Release Notes.
    Refer to the Getting Started with NI Circuit Design Suite manual for information about getting started with Circuit Design Suite. You can access this PDF from Start»All Programs»National Instruments»Circuit Design Suite 12.0»Documentation»Getting Started.
    Supported Platforms
    Installing Circuit Design Suite 12.0
    New Components
    Supported Platforms
    Circuit Design Suite 12.0 supports Windows Vista/XP 32-bit editions, Windows Vista 64-bit edition, Windows 7 32-bit and 64-bit editions, Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit). Circuit Design Suite 12.0 does not support Windows NT/Me/98/95/2000, Windows XP x64, or the Windows Server non-R2 editions.
    Installing Circuit Design Suite 12.0Installing Multiple Versions
    Circuit Design Suite 12.0 installs side-by-side with version 11.x. You must activate Circuit Design Suite after you install it. It will not activate itself automatically.
    Installing Circuit Design Suite Silently
    You can install Circuit Design Suite without viewing any installation dialog boxes. Refer to the silent_install.txt file in the Supportfiles directory in the Circuit Design Suite distribution for more information about installing Circuit Design Suite silently.
    Archiving Circuit Design Suite databases
    National Instruments recommends that you regularly back up the files created within the Multisim and Ultiboard components of NI Circuit Design Suite. Additionally, you should back up internal files that store user-created data, such as database components. For more information about which files to backup and where to find them, refer to the Help.
    Uninstalling
    Uninstalling Circuit Design Suite will not remove user data. For more information about the locations of user database and configuration files, refer to the Archiving Data Help topic.
    Known IssuesLabVIEW
    • LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    • You cannot install Circuit Design Suite 12.0 on Windows Vista Starter edition.
    • Multisim and Ultiboard leak GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behavior and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    • The Multisim Buzzer component will not generate any sound in Windows Vista-64 bit and on Windows XP-64 bit. This is due to Microsoft not supporting use of the Beep function in those versions of Windows. The Beep function is used by this component to generate sound.
    • The upgrade to the PICC 9.82 (pro) compiler in Circuit Design Suite 12.0 may break existing code in MCU files since macros used by the compiler have changed. For example, WDTEN has been replaced with WDT_ON, and OPTION has been replaced by OPTION_REG.
    Release Notes
    • The "snippet" feature includes code from libpng 1.4.3, licensed by a third party or parties pursuant to the libpng license. For more information, refer to Notifications.pdf at ... \National Instruments\Circuit Design Suite 12.0\Licenses\.
    The following is a subset of the issues fixed between Circuit Design Suite 11.0.2 and Circuit Design Suite 12.0.
    Multisim ( 57 )
    Bug IDDescription
    2608223D parts (using bitmaps of real components) do not show "placed" status on schematic workspace.
    262628Switching from show net names to hide netnames resets the positioning of net names.
    268734TRIAC Models do not simulate as expected.
    269201PZT2907A and PZT2907A should be PNP components.
    269965Digital state machine component does not work as expected.
    270357Multisim crashes when trying to change values of lumped elements in Match Net. Designer.
    270574BAT15_099R is incorrect.
    271671.IC and .NODESET commands malfunction if used within .subckt.
    273803Incorrect errors are generated when expressions reference nodes that start with the $ symbol.
    274388User database template should be better named to avoid customer confusion.
    274472Clicking the mouse wheel should pan the document in Multisim.
    274856Preferred net names show up incorrectly when merging nets.
    274869Unable to hide the SC symbol name for a bus connector via sheet properties.
    274910Ron/Roff values for Interactive switches have poor defaults and are not configurable.
    275132Refdes is duplicated when copying and pasting a component in some cases.
    275264Oscilloscope when in XY or YX or A/B or B/A mode should have facilities to clear screen.
    275400Back annotating a design with nets on bus lines does not behave correctly in some cases.
    275448Pins not added to heirarchical blocks or subcircuits when back annotating.
    275474In 120 DPI Display Mode Graph Background Color List Is Not Working in Windows XP.
    275491Shorting Bus Lines causes crash in some cases.
    275542CNTR_BCD_SDC component will always count down after first down count.
    275616Bus Vector Connect dialog not filled in when first opened.
    275661Multisim crashes when adding/removing component in some cases.
    275667Export to PRZ doesn't grab linked landpatterns.
    275691Potentiometer Not Displaying Increment Precision Digits.
    277103Behavioral sources were slow in Multisim version 11.x.
    283843BOM Report to Text is incorrect if the order of the columns is modified.
    285414PWL source with Unicode characters in the path fails to simulate.
    2874391N5619GP diode uses the incorrect simulation model.
    289548JK flip flop in a PLD design does not work as expected.
    291144Duplicate pages show up in a multi-page design when you add it to a project.
    291724Multisim Crashed when non convergent analyses are swept in some cases.
    305192Buses can only be used in net name mode in some cases.
    306480Cutting, changing part settings and then pasting section of component will get settings out-of-sync in some cases.
    306485Naming and modifying nets across different instances of a subcircuit can cause Multisim to crash.
    307199Using the digital state machine with a very long file name will cause a crash.
    307472Undo does not undo the bus color change.
    309264Sensitivty analysis causes Internal simulation error in mixed-mode circuits.
    310389Switch toggling behaves erratically when in subcircuits in some cases.
    310422A Hierarchical block connector on a multi-page design is not renamed correctly in some cases.
    310826Cancelling the placement of a HB from file will affect the netlist for the opened design.
    311328Multisim crashes when copying a HB that contains a missing HB.
    311799LMV393MM and LMC6772AIMM have bad symbol pin names.
    313502Certain parameter and expression heavy models crash Multisim.
    314137Watt Meter doesn't operate with DC Source.
    314142Gerber Drill and NC Drill holes are not exported correctly.
    315101LT1882 model is not correct.
    315461AD8694* components have incorrect footprint pin mappings.
    315698Changing RefDes in a large design takes a very long time.
    315869Editing Sub-circuit Symbol Breaks Bus Connection Into The Symbol.
    317233Multisim crashes when connecting two wire to a pin using junctions.
    317646Models with different data but same model ID wil be used incorrectly in a multi-sheet design.
    317906The gain of the "Current probe" should be displayed on the schematic.
    318588Opening a Multisim file in windows explorer fails to open file if Multisim is already running.
    321176Graph axis range minimum and maximum values are swapped without warning in some cases.
    323164Several components in TIL family have incorrect logic technology setting, leading to simulation errors.
    325816Multisection RNxxxx components should have their emitters marked as common.
    Ultiboard ( 48 )
    263374Importing an Orcad max file will make the component refdes a part of the footprint's name.
    263473Clearance for elliptical arc drawn improperly.
    265586Valid DRC errors are missing from Ultiboard v 10.x.
    267766Board outline is not closed when a DXF file is merged to the outline layer in some cases.
    269497Unable to export a real circle to DXF.
    270271Copying and pasting a pad into the 'Custom Pad shape edit mode' does not allow you to save the shape.
    270367Elliptical Arc clearance isn't displayed until arc is completed.
    270512Copper area outside the board outline is not removed.
    270534Coordinates doesn't appear after exiting from the 3D viewer.
    271327"Convert Closed Objects To Filled" Is Not Working in some cases.
    271508Change shape command can cause DRC errors and broken boards.
    273334Density bars should take into account all pads.
    273482Keep in/keep out polygons should have polygon list accessible to user.
    273495Ultiboard incorrectly fills in power plane for odd board outline.
    273531The 3D view of a design is invalid in some cases.
    273773Drawing a polygon when polygon drawing is turned off should give some warning message.
    273938SOT23_3 produces DRC error upon placement.
    273966Forward annotation does not delete nets that aren't connected to a component prior to annotation.
    274310Vertices can be added/removed/changed for a locked polygon.
    274311Vertices can be added/removed from a locked polygon.
    274312A locked rectangle does not show the locked orange border.
    274401Copper area does not void board outline holes in some cases.
    274603Height information does not update in 3D view after placement from database.
    274609Moving land patterns from one database to another doesn't actually delete the data from the source database.
    274790Tool tip does not hide itself when Ctrl is released.
    275064Rectangle hole in pad resets its size when the part is rotated.
    275508Using High Contrast Black Wndows Theme settings makes some dialogs unreadable.
    275540Automatic Test Points are placed incorrect when keep-in areas are present in a design in some cases.
    275558Pin number information is missing from multi-section components if the components are not in the database when the file is loaded.
    275603DRC error not generated when copper polygon is not directly conntected to pins.
    275671Traces created with the Bezier and Arc tools are connected to a Copper Area.
    275971Description in status bar does not clear if menu is selected using keyboard.
    277621Removing Islands "Not Connected To Outer Edge" Is Deleting Islands Connected To Pads.
    287628The netbridge trace shorts with copper area in some cases.
    291652Passwords do not protect user/coorporate databases in Ultiboard.
    299398Undoing an action that added layers does not remove the layers.
    3018193d preview colours are incorrectly transferred between unrelated objects.
    302143Changing any values of the Attribute Properties during In-Place Edit breaks the properties dialog.
    303316Ultiboard netlist doesn't match with the schematic after forward annotation in some cases.
    305667Can't pan in Y direction when viewing 3D from directly overhead.
    305704Manually Assigned Via Disappears and produces DRC Errors.
    308758Switching trace layers causes Ultiboard to crash in some cases.
    312095Transfer to Ultiboard of Large Design causes Ultiboard to become unresponsive.
    313380Vertices of a placed circle can only be moved horizontally.
    317483DXF import ignores custom scaling factor.
    321207Locking a rectangle doesn't show the lock border.
    323403TO-3(K08A) Footprint Pins Are In Incorrect Positions.
    326339Board Outline Problem dialog allows entering negative numbers.
    The following is a subset of the issues fixed between Circuit Design Suite 12.0 and Circuit Design Suite 12.0.0.1.
    Multisim ( 3 )
    Bug IDDescription
    334101Loading LabVIEW 2011 instruments crashes Multisim 12.0.
    333932Multisim COM interface unable to open Multisim 12 files.
    336490Multisim crashes on disconnect after creating a BOM when using the Multisim COM interface.
    Ultiboard (2)
    335190Exporting Parts centroids for designs containing test points crashes Ultiboard.
    337602Ultiboard crashes when viewing certain files.
    New Components
    For information about new components, refer to the Database Improvements section of the release notes.
    Using Microsoft Silverlight
    © 2012 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Electronics Workbench, Multisim and Ultiboard are trademarks of National Instruments. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    The EKV MOST model used in this software was developed, implemented and tested by the Electronics Laboratory (LEG) of the Swiss Federal Institute of Technology (EPFL).
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2026-4-23 09:16
