查看: 4446|回复: 0
[NI软件产品] NI Measurement Studio 2013_VS2012 Win32/64Eng NI MStudio 2013_VS2012
    发表于 2021-3-10 23:51:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Measurement Studio
    Measurement Studio是Microsoft Visual Studio的扩展软件,提供了用于创建测试和测量应用程序的.NET工具。
    Measurement Studio是一套专为构建工程应用程序而设计的.NET工具。您可以使用与硬件采集数据类型兼容的工程UI控件,以清晰明了地展示数据。Measurement Studio通过高级、直观的面向对象硬件类库简化了硬件通信。您可以使用业界最快、最灵活且最适合将测量数据存盘的文件格式TDMS,将自定义信息添加到采集的数据。您还可以对采集的信号进行实时在线分析,而无需编写自定义解析算法。
    Win32/64Eng 专业版/企业版/标准版/评估版
    MStudio2013_VS2012
    文件大小: 679357504 字节 (647.89 MB)
    修改日期: 2013-03-05 01:49
    MD5: 13a3294ecdb5ac0e1844ccc0b00ef431(可秒传)
    SHA1: 95850936017eb90d6f8e84dd0dd5a49a928fb2ea
    SHA256: e0bc94116533233490997aa0891572785c0839c133a2bc564fbe8db5d73468d0
    CRC32: 5ebf9e63
    MStudio2013_VS2012.txt (640 Bytes, 下载次数: 5, 售价: 10 圆)
    Measurement Studio 2013 for Visual Studio 2012 Readme
    Measurement Studio 2013 includes separate, parallel sets of class libraries, integration features, and support documentation for developing with Visual Studio 2012, Visual Studio 2010, and Visual Studio 2008. This readme documents only Measurement Studio support for Visual Studio 2012. Measurement Studio support for other versions of Visual Studio includes separate readme files; refer to these respective readme files or the Measurement Studio Release Notes for more information about Measurement Studio support for other versions of Visual Studio.
    For information on the new features and functionality that have been introduced in Measurement Studio since version 2012, refer to the What's New in Measurement Studio 2013 topic in the installed NI Measurement Studio Help.
    Installing Measurement Studio 2013
    To install and run Measurement Studio support for Visual Studio 2012, your computer must have the following:
    • Microsoft operating system:
      • Windows 8 (32-bit or 64-bit)
      • Windows 7 (32-bit or 64-bit), including Starter Edition (32-bit)
    • Microsoft Framework 4.5
    • Visual Studio 2012:
      • Ultimate Edition
      • Premium Edition
      • Professional Edition
      • Express for Web
      • Express for Windows Desktop
    • 1.6 GHz or faster processor
    • DirectX 9-capable video card running at 1024 x 768 or higher-resolution display
    • 1 GB (32-bit) or 2 GB (64-bit) RAM
    • 1.2 GB of free hard disk space
    • Microsoft-compatible mouse
    • Microsoft Internet Explorer 6.0
    Installation Notes
    • Measurement Studio does not support:
      • Non-R2 editions of Windows Server
    • Microsoft Visual Studio Express Editions do not support Measurement Studio Visual Studio-integrated tools.
    • This version of Measurement Studio supports, and was tested with, the latest Visual Studio service pack and the latest operating system service pack that was available at the time this version of Measurement Studio was released. National Instruments strongly recommends using Measurement Studio with the latest Visual Studio service pack and the latest operating system service pack.
    • If you want to upgrade your operating system from one major version to another, National Instruments recommends first uninstalling all National Instruments software, including application software and drivers. This is typically not necessary when installing an operating system service pack.
    • There are additional considerations for installing the Measurement Studio Help for Visual Studio 2012. Refer to the Installation Notes for Integrated Visual Studio 2012 Help section of this document for more information.
    National Instruments recommends that you exit all programs before running the Measurement Studio installer. Applications that run in the background, such as virus scanning utilities, might cause the installer to take longer than necessary to complete.
    • Log on as Administrator or as a user with administrator privileges.
    • Launch Autorun.exe, either from the installation media or from the location to which you extracted the downloaded disc image. Select Install Measurement Studio 2013.
    • In the Select Installation Option window, you can choose to activate Measurement Studio if you have a serial number, or you can choose to evaluate Measurement Studio.
    • Select Measurement Studio 2013 support for the version or versions of Visual Studio you want to install support for.
    • Select Device Drivers to install support for hardware.
    Tip    You can use a spec file to programmatically control the Measurement Studio installer for a single distribution or for the entire suite. An example spec file for a single distribution is located on your installation media at :Distributions\Measurement Studio for VS20xx\Bin\template_spec.txt. For more information, refer to KnowledgeBase Article 4CJDP38M: Automating the Installation of a Single Installer on ni.com. Alternately, you can generate a spec file for the entire Measurement Studio suite. Refer to KnowledgeBase Article 4GGGDQH0: Automating the Installation of a Suited Installer on ni.com for instructions on how to generate a spec file for your suite.
    Driver Support
    To determine what drivers are supported for each version of Visual Studio, whether the driver supports 32-bit or 64-bit applications, and the location of the installer files, refer to the Driver Support section of the Measurement Studio Release Notes.
    Activating Measurement Studio Licenses
    National Instruments offers a variety of Measurement Studio licenses, with certain licensed features available for each license type: Standard Edition, Professional Edition, and Enterprise Edition. Refer to the Measurement Studio Editions topic in the installed NI Measurement Studio Help for more information on Measurement Studio editions, and the Licensing Measurement Studio topic in the installed NI Measurement Studio Help for more information about licensing Measurement Studio.
    Tip    To move to a different Measurement Studio edition, you can activate the new edition by using NI License Manager. To access NI License Manager, select Start»All Programs»NationalInstruments»NI License Manager or, in Windows 8, select NI Launcher»NI License Manager.
    Measurement Studio supports concurrent licensing as part of a volume license agreement. If your software is a part of a Volume License Agreement (VLA), contact your VLA administrator for installation and activation instructions.
    You can use the Manage Content tab within the Help Viewer to uninstall or reinstall the Measurement Studio 2013 help. The help manifest files (.msha files) for the Measurement Studio 2013 help are located in the \MeasurementStudioVS2012\Help directory, where refers to the directory where you installed Measurement Studio.
    Tip    Select Set Help Preference»Launch in Help Viewer from within the Help menu in Visual Studio to view the integrated Measurement Studio help. If you have Launch in Browser selected, the Measurement Studio help does not appear.
    Installing the Current Version of Measurement Studio over Previous Versions of Measurement Studio
    If you install a newer version of Measurement Studio on a machine that has a prior version of Measurement Studio installed, the newer version installer replaces the prior version functionality, including class libraries. However, the prior version assemblies remain in the global assembly cache (GAC); therefore, applications that reference the prior version continue to use the prior version .NET assemblies.
    Note    NationalInstruments.Common.dll uses a publisher policy file to redirect applications to always use the newest version of NationalInstruments.Common.dll installed on the system, for each version of the .NET Framework. However, prior versions of NationalInstruments.Common.dll remain in the GAC after you install a newer version of Measurement Studio. National Instruments exerts extra effort to ensure that NationalInstruments.Common.dll is backward-compatible so that applications built against prior versions of Measurement Studio continue to work as expected.
    Deployment Requirements
    Visual Studio 2012 does not support Microsoft Setup Projects for deployment. You can use the following information to help you create an installer for your application in Visual Studio 2012. For more information on creating an installer with Measurement Studio support for Visual Studio 2012, refer to the Deploying Measurement Studio Applications topic in the installed NI Measurement Studio Help. Additionally, you can use the Deployment example application for a sample project you can modify and use to deploy your project. Refer to the Where to Find Examples topic in the installed NI Measurement Studio Help to determine where example projects are installed on your machine.
    • National Instruments recommends creating your installer in Visual Studio 2012 with the Windows Installer XML (WiX) toolset, available at WiXToolset.org. The WiX toolset is a set of open source build tools that integrates into Visual Studio.
    • Measurement Studio merge modules for Visual Studio 2012 install the Measurement Studio assemblies by default to the global assembly cache (GAC). Measurement Studio merge modules for Visual Studio 2010 and 2008 install the Measurement Studio assemblies by default to the application folder. To install Measurement Studio assemblies for Visual Studio 2012 to the application folder, you must set the ConfigurationData element in your .wxs file for that component. For information on how to use this element, refer to the Deployment example installed with Measurement Studio.
    • Measurement Studio support for Visual Studio 2012 and Visual Studio 2010 uses the same NationalInstruments.Common.dll assembly, which is built against the .NET Framework version 4.0.
    Note   Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    For assistance in getting started with Measurement Studio 2013, refer to the Measurement Studio Overview and the Getting Started with the Measurement Studio Class Libraries topics in the installed NI Measurement Studio Help or refer to the Measurement Studio Release Notes and Getting Started with Measurement Studio manual.
    You can access the list of bugs fixed in Measurement Studio 2013 online. Refer to the Measurement Studio Bug Fix Information Web page for a complete listing of the bugs fixed in Measurement Studio 2013.
    Known Issues in Measurement Studio 2013
    For a complete list of incompatibilities in Measurement Studio with previous versions of Measurement Studio and otherwise supported features, including a list of obsoleted members and members that have been changed to sealed override or non-virtual, refer to the Measurement Studio Incompatibilities topic in the NI Measurement Studio Help.
    • Measurement Studio no longer ships support for Visual Studio 2005. Refer to ni.com/mstudio/legacysupport for more information on Measurement Studio support for legacy environments and languages.
    • Measurement Studio support for Visual Studio 2012 does not include support for the Instrument I/O Assistant.
    • Measurement Studio support for Visual Studio 2012 does not include support for the Measurement & Automation Explorer (MAX) Configuration API.
    • Visual Studio 2012 does not support Microsoft Setup Projects for deployment. National Instruments recommends using the Windows Installer XML (WiX) toolset for creating deployment projects. Refer to the Deploying Measurement Studio Windows Applications topic in the NI Measurement Studio Help for further information.
    • Measurement Studio merge modules for Visual Studio 2012 install Measurement Studio assemblies by default to the Global Assembly Cache (GAC). This is a change from Measurement Studio merge modules for Visual Studio 2008 and Visual Studio 2010, which install Measurement Studio assemblies by default to the application folder
    • Several NI-VISA and NI-488.2 .NET support members are now obsolete. Refer to the Modifications to Existing .NET API Members section of the Measurement Studio Incompatibilities topic in the NI Measurement Studio Help for a list of these members.
    • For WPF controls, in Measurement Studio 2013 support for Visual Studio 2012 and Visual Studio 2010, you can edit options with parameters for enumerated properties only from the Property Grid. However, in Measurement Studio 2012, you can edit these options from both the control's smart tag and the Property Grid. For example, in Measurement Studio 2012, you can select and edit the ToIntervalFromBase option for the GaugeDouble.CoercionMode property from both the gauge smart tag and the Property Grid. In Measurement Studio 2013, you can only select and edit this option from the Property Grid.
    Legacy Languages and Frameworks
    To qualify to receive these products, you must meet one of the following criteria:
    • You must maintain an active Measurement Studio Standard Service Program (SSP) contract; or
    • You must have purchased the most recent version of Measurement Studio.
    ©2003–2013 National Instruments. All rights reserved.
    LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the NI Trademarks and Logo Guidelines section on ni.com/trademarks for other National Instruments Trademarks.
    To comment on National Instruments documentation, refer to the National Instruments Web site.
    GMT+8, 2026-4-23 09:16
