查看: 5044|回复: 0
[NI软件产品] NI Measurement Studio 2012_VS2010 Win32/64Eng NI MStudio 2012_VS2010
    发表于 2021-3-10 23:36:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Measurement Studio
    Measurement Studio是Microsoft Visual Studio的扩展软件,提供了用于创建测试和测量应用程序的.NET工具。
    Measurement Studio是一套专为构建工程应用程序而设计的.NET工具。您可以使用与硬件采集数据类型兼容的工程UI控件,以清晰明了地展示数据。Measurement Studio通过高级、直观的面向对象硬件类库简化了硬件通信。您可以使用业界最快、最灵活且最适合将测量数据存盘的文件格式TDMS,将自定义信息添加到采集的数据。您还可以对采集的信号进行实时在线分析,而无需编写自定义解析算法。
    Win32/64Eng 专业版/企业版/标准版/评估版
    文件大小: 660826760 字节 (630.21 MB)
    修改日期: 2012-08-03 05:18
    MD5: f7d0659cc51e21ee59dbaf972cec0a84(可秒传)
    SHA1: aa23332eef8910382ae52f9a8317ac61f6376e9b
    SHA256: 79ccb0118c29b871e7892be9578baa90d859b6f25aa24485cfa1d9da6847614e
    CRC32: 7f899a6c
    MStudio2012_VS2010.txt (613 Bytes, 下载次数: 2, 售价: 10 圆)
    Measurement Studio 2012 for Visual Studio 2010 Readme
    Measurement Studio 2012 includes separate, parallel sets of class libraries, integration features, and support documentation for developing with Visual Studio 2010, Visual Studio 2008, and Visual Studio 2005. This readme documents only Measurement Studio support for Visual Studio 2010. Measurement Studio support for other versions of Visual Studio includes separate readme files; refer to these respective readme files or the Measurement Studio Release Notes for more information about Measurement Studio support for other versions of Visual Studio. Select Start»All Programs»National Instruments»»Release Notes to view the Measurement Studio Release Notes.
    For information on the new features and functionality that have been introduced in Measurement Studio since version 2010 Service Pack 1, refer to the What's New in Measurement Studio 2012 topic in the installed NI Measurement Studio Help.
    Installing Measurement Studio 2012
    To install and run Measurement Studio support for Visual Studio 2010, your computer must have the following:
    • Microsoft operating system:
      • Windows 7 (32-bit or 64-bit), including Starter Edition (32-bit)
      • Windows Vista, Service Pack 1 (32-bit or 64-bit)
      • Windows XP, Service Pack 3 (32-bit)
    • Microsoft .NET Framework 4.0
    • Visual Studio 2010:
      • Ultimate Edition
      • Premium Edition
      • Professional Edition
      • Visual C# Express Edition
      • Visual Basic Express Edition
      • Visual Web Developer Express Edition
    • Intel Pentium III class processor, 1.6 GHz or higher
    • DirectX 9-capable video card running at 1024 x 768 or higher-resolution display
    • 1 GB (32-bit) or 2 GB (64-bit) RAM
    • 1.2 GB of free hard disk space
    • Microsoft-compatible mouse
    • Microsoft Internet Explorer 6.0
    Installation Notes
    • Measurement Studio does not support:
      • Windows Vista Starter Edition
      • Non-R2 editions of Windows Server
    • Microsoft Visual Studio Express Editions do not support Measurement Studio Visual Studio-integrated tools.
    • This version of Measurement Studio supports, and was tested with, the latest Visual Studio service pack and the latest operating system service pack that was available at the time this version of Measurement Studio was released. National Instruments strongly recommends using Measurement Studio with the latest Visual Studio service pack and the latest operating system service pack.
    • If you want to upgrade your operating system from one major version to another, National Instruments recommends first uninstalling all National Instruments software, including application software and drivers. This is typically not necessary when installing an operating system service pack.
    • There are additional considerations for installing the Measurement Studio Help for Visual Studio 2010. Refer to the Installation Notes for Integrated Visual Studio 2010 Help section of this document for more information.
    • Some National Instruments components require Microsoft Silverlight 4.0. If you use a component that requires Silverlight, a dialog box prompts you to install Silverlight from the Internet. Microsoft Silverlight 4.0 is available from the Microsoft Web site at http://www.microsoft.com/silverlight. Measurement Studio does not contain Silverlight controls.
    National Instruments recommends that you exit all programs before running the Measurement Studio installer. Applications that run in the background, such as virus scanning utilities, might cause the installer to take longer than necessary to complete.
    • Log on as Administrator or as a user with administrator privileges.
    • Launch Autorun.exe, either from the installation media or from the location to which you extracted the downloaded disc image. Select Install Measurement Studio 2012.
    • In the Select Installation Option window, you can choose to activate Measurement Studio if you have a serial number, or you can choose to evaluate Measurement Studio.
    • Select Measurement Studio 2012 support for the version or versions of Visual Studio you want to install support for.
    • Install hardware drivers and configure your hardware, if necessary.
    Tip    You can use a spec file to programmatically control the Measurement Studio installer for a single distribution or for the entire suite. A spec file allows you to install Measurement Studio 2012 without viewing any installation dialog boxes. An example spec file for a single distribution is located on your installation media at :Distribution\Measurement Studio for VS20xx\Bin\template_spec.txt. For more information, refer to KnowledgeBase Article 4CJDP38M: Automating the Installation of a Single Installer on ni.com. Alternately, you can generate a spec file for the entire Measurement Studio suite. Refer to KnowledgeBase Article 4GGGDQH0: Automating the Installation of a Suited Installer on ni.com for instructions on how to generate a spec file for your suite.
    Driver Support
    To determine what drivers are supported for each version of Visual Studio, whether the driver supports 32-bit or 64-bit applications, and the location of the installer files, refer to the Driver Support section of the Measurement Studio Release Notes. To view the Measurement Studio Release Notes, select Start»All Programs»National Instruments»»Measurement Studio Release Notes.
    Activating Measurement Studio Licenses
    National Instruments offers a variety of Measurement Studio licenses, with certain licensed features available for each license type: Standard Edition, Professional Edition, and Enterprise Edition. Refer to the Measurement Studio Editions topic in the installed NI Measurement Studio Help for more information on Measurement Studio editions, and the Licensing Measurement Studio section in the installed NI Measurement Studio Help for more information about licensing Measurement Studio.
    Tip    To move to a different Measurement Studio edition, you can activate the new edition by using NI License Manager. Select Start»All Programs»NationalInstruments»NI License Manager to access NI License Manager.
    Measurement Studio 2012 supports concurrent licensing as part of a volume license agreement. If your software is a part of a Volume License Agreement (VLA), contact your VLA administrator for installation and activation instructions.
    To run the Measurement Studio installer in repair mode:
    • Launch the standard Windows Control Panel utility for adding and removing programs.
    • Select National Instruments Software and click Change/Remove.
    • In the National Instruments Software dialog box, select NI Measurement Studio 2012 for VS2010.
    • Click Repair.
    By default, Visual Studio 2010 installs the Microsoft Help Library to the English locale. Measurement Studio provides a tool, HelpConfigurationUtility.exe, which you can use to install Measurement Studio for Visual Studio 2010 documentation to other Microsoft documentation locales. You can also use the Help Configuration Utility to uninstall or reinstall Measurement Studio documentation for Visual Studio 2010.
    For more information on how to use this utility, refer to the Help Configuration Utility Readme, located in the directory where you installed the Help Configuration Utility.
    Installing the Current Version of Measurement Studio over Previous Versions of Measurement Studio
    If you install a newer version of Measurement Studio on a machine that has a prior version of Measurement Studio installed, the newer version installer replaces the prior version functionality, including class libraries. However, the prior version assemblies remain in the global assembly cache (GAC); therefore, applications that reference the prior version continue to use the prior version .NET assemblies.
    Note    NationalInstruments.Common.dll uses a publisher policy file to redirect applications to always use the newest version of NationalInstruments.Common.dll installed on the system, for each version of the .NET Framework. However, prior versions of NationalInstruments.Common.dll remain in the GAC after you install a newer version of Measurement Studio. National Instruments exerts extra effort to ensure that NationalInstruments.Common.dll is backward-compatible so that applications built against prior versions of Measurement Studio continue to work as expected.
    Deployment Requirements
    To facilitate use in Visual Studio Setup projects, all Measurement Studio class libraries that support 64-bit include both 32-bit and 64-bit deployment merge modules. This is true regardless of whether the class library includes platform-specific (i.e., x86 or x64) or platform-agnostic (i.e., Any CPU) assemblies. Refer to Deploying Windows Applications in the NI Measurement Studio Help for more information on using 64-bit merge modules.
    Getting Started with Measurement Studio 2012
    For step-by-step guides to learning how to develop applications with Measurement Studio, refer to the Measurement Studio Walkthroughs section of the installed NI Measurement Studio Help.
    To view a PDF of the Getting Started with Measurement Studio guide or the Measurement Studio Release Notes, select Start»All Programs»National Instruments»»Getting Started with Measurement Studio or Start»All Programs»National Instruments»»Measurement Studio Release Notes. To view these documents, you need the free Adobe Reader. Refer to the Adobe Systems Incorporated Web site at www.adobe.com to download Adobe Reader.
    Bug Fixes in Measurement Studio 2012
    You can access the known issues for Measurement Studio 2012 online. Refer to the Measurement Studio 2012 Known Issues Web page for a complete, up-to-date listing of known issues in Measurement Studio 2012.
    Measurement Studio 2012 Incompatibilities with Previous Versions of Measurement Studio
    NI Measurement Studio 2009 was the last version of Measurement Studio to support Visual Studio 6.0, Visual Studio 2003, and Visual C++ MFC.
    However, legacy support is available in the following products:
    • NI Measurement Studio for Legacy Environments/Languages (Measurement Studio LEL), which includes support for:
      • Visual Studio 2008 (Visual C++ MFC)
      • Visual Studio 2005 (Visual C++ MFC)
      • Visual Studio 2003 (Visual C++ MFC, Visual C#, Visual Basic .NET)
      • Visual Studio 6.0 (Visual Basic 6.0, Visual C++ 6.0)
    • Measurement Studio C++ MFC for Visual Studio 2010 (Measurement Studio MFC 10), which includes support for:
      • Visual Studio 2010 (Visual C++ MFC)
    Refer to ni.com/mstudio/legacysupport for additional information on NI Measurement Studio for Legacy Environments/Languages and Measurement Studio C++ MFC for Visual Studio 2010, including installation and configuration information, or contact a Technical Sales Representative at ni.com/contact.
    Important InformationCopyright
    For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments patent notice at ni.com/patents.
    To comment on National Instruments documentation, refer to the National Instruments Web site.
    GMT+8, 2026-4-23 09:16
