查看: 3945|回复: 0
[NI软件产品] NI Measurement Studio 2012_VS2005 Win32/64Eng NI MStudio 2012_VS2005
    发表于 2021-3-10 23:34:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Measurement Studio
    Measurement Studio是Microsoft Visual Studio的扩展软件,提供了用于创建测试和测量应用程序的.NET工具。
    Measurement Studio是一套专为构建工程应用程序而设计的.NET工具。您可以使用与硬件采集数据类型兼容的工程UI控件,以清晰明了地展示数据。Measurement Studio通过高级、直观的面向对象硬件类库简化了硬件通信。您可以使用业界最快、最灵活且最适合将测量数据存盘的文件格式TDMS,将自定义信息添加到采集的数据。您还可以对采集的信号进行实时在线分析,而无需编写自定义解析算法。
    Win32/64Eng 专业版/企业版/标准版/评估版
    文件大小: 605457032 字节 (577.41 MB)
    修改日期: 2012-08-03 05:15
    MD5: 65cf12b90158b65be903f710eab2c258(可秒传)
    SHA1: e844339b1c36de727f4c2952bc5e2783bb19eb7e
    SHA256: f4f930fad538231b149db38e94b4e879ab32c886766477c6c73748cea19ef1ba
    CRC32: 094d9abd
    MStudio2012_VS2005.txt (614 Bytes, 下载次数: 0, 售价: 10 圆)
    Measurement Studio 2012 for Visual Studio 2005 Readme
    Measurement Studio 2012 includes separate, parallel sets of class libraries, integration features, and support documentation for developing with Visual Studio 2010, Visual Studio 2008, and Visual Studio 2005. This readme documents only Measurement Studio support for Visual Studio 2005. Measurement Studio support for other versions of Visual Studio includes separate readme files; refer to these respective readme files or the Measurement Studio Release Notes for more information about Measurement Studio support for other versions of Visual Studio. Select Start»All Programs»National Instruments»»Release Notes to view the Measurement Studio Release Notes.
    For information on the new features and functionality that have been introduced in Measurement Studio since version 2010 Service Pack 1, refer to the What's New in Measurement Studio 2012 topic in the installed NI Measurement Studio Help.
    Installing Measurement Studio 2012
    To install and run Measurement Studio support for Visual Studio 2005, your computer must have the following:
    • Microsoft operating system:
      • Windows 7 (32-bit or 64-bit), including Starter Edition (32-bit)
      • Windows Vista, Service Pack 1 (32-bit or 64-bit)
      • Windows XP, Service Pack 2 (32-bit)
      Note    Measurement Studio class libraries are designed to work on 64-bit operating systems. However, Measurement Studio class libraries for Visual Studio 2005 cannot be used to create 64-bit applications. To use Measurement Studio class libraries for Visual Studio 2005 on a 64-bit operating system, you must configure your projects to build 32-bit applications or libraries.
    • Microsoft .NET Framework 2.0
    • Visual Studio 2005:
      • Team System Edition
      • Professional Edition
      • Standard Edition
      • Visual C# Express Edition
      • Visual Basic .NET Express Edition
      • Visual Web Developer Express Edition
    • Intel Pentium III class processor, 1.6 GHz or higher
    • Video display—1024 x 768
    • 512 MB of RAM (1024 MB or more recommended)
    • 800 MB of free hard disk space
    • Microsoft-compatible mouse
    • Microsoft Internet Explorer 6.0
    Installation Notes
    • Measurement Studio does not support:
      • Windows Vista Starter Edition
      • Non-R2 editions of Windows Server
    • Microsoft Visual Studio Express Editions do not support Measurement Studio Visual Studio-integrated tools.
    • This version of Measurement Studio supports, and was tested with, the latest Visual Studio service pack and the latest operating system service pack that was available at the time this version of Measurement Studio was released. National Instruments strongly recommends using Measurement Studio with the latest Visual Studio service pack and the latest operating system service pack.
    • If you want to upgrade your operating system from one major version to another, National Instruments recommends first uninstalling all National Instruments software, including application software and drivers. This is typically not necessary when installing an operating system service pack.
    • In order for links from Measurement Studio help topics to .NET Framework help topics to work, you must install the product documentation for Visual Studio, which installs the MSDN Library. This requires a secondary installation during the Visual Studio installation process.
    • Some National Instruments components require Microsoft Silverlight 4.0. If you use a component that requires Silverlight, a dialog box prompts you to install Silverlight from the Internet. Microsoft Silverlight 4.0 is available from the Microsoft Web site at http://www.microsoft.com/silverlight. Measurement Studio does not contain Silverlight controls.
    National Instruments recommends that you exit all programs before running the Measurement Studio installer. Applications that run in the background, such as virus scanning utilities, might cause the installer to take longer than necessary to complete.
    • Log on as Administrator or as a user with administrator privileges.
    • Launch Autorun.exe, either from the installation media or from the location to which you extracted the downloaded disc image. Select Install Measurement Studio 2012.
    • In the Select Installation Option window, you can choose to activate Measurement Studio if you have a serial number, or you can choose to evaluate Measurement Studio.
    • Select Measurement Studio 2012 support for the version or versions of Visual Studio you want to install support for.
    • Install hardware drivers and configure your hardware, if necessary.
    Tip    You can use a spec file to programmatically control the Measurement Studio installer for a single distribution or for the entire suite. A spec file allows you to install Measurement Studio 2012 without viewing any installation dialog boxes. An example spec file for a single distribution is located on your installation media at :Distribution\Measurement Studio for VS20xx\Bin\template_spec.txt. For more information, refer to KnowledgeBase Article 4CJDP38M: Automating the Installation of a Single Installer on ni.com. Alternately, you can generate a spec file for the entire Measurement Studio suite. Refer to KnowledgeBase Article 4GGGDQH0: Automating the Installation of a Suited Installer on ni.com for instructions on how to generate a spec file for your suite.
    Driver Support
    To determine what drivers are supported for each version of Visual Studio, whether the driver supports 32-bit or 64-bit applications, and the location of the installer files, refer to the Driver Support section of the Measurement Studio Release Notes. To view the Measurement Studio Release Notes, select Start»All Programs»National Instruments»»Measurement Studio Release Notes.
    Activating Measurement Studio Licenses
    National Instruments offers a variety of Measurement Studio licenses, with certain licensed features available for each license type: Standard Edition, Professional Edition, and Enterprise Edition. Refer to the Measurement Studio Editions topic in the installed NI Measurement Studio Help for more information on Measurement Studio editions, and the Licensing Measurement Studio section in the installed NI Measurement Studio Help for more information about licensing Measurement Studio.
    Tip    To move to a different Measurement Studio edition, you can activate the new edition by using NI License Manager. Select Start»All Programs»NationalInstruments»NI License Manager to access NI License Manager.
    Measurement Studio 2012 supports concurrent licensing as part of a volume license agreement. If your software is a part of a Volume License Agreement (VLA), contact your VLA administrator for installation and activation instructions.
    Installing the Current Version of Measurement Studio over Previous Versions of Measurement Studio
    If you install a newer version of Measurement Studio on a machine that has a prior version of Measurement Studio installed, the newer version installer replaces the prior version functionality, including class libraries. However, the prior version assemblies remain in the global assembly cache (GAC); therefore, applications that reference the prior version continue to use the prior version .NET assemblies.
    Note    NationalInstruments.Common.dll uses a publisher policy file to redirect applications to always use the newest version of NationalInstruments.Common.dll installed on the system, for each version of the .NET Framework. However, prior versions of NationalInstruments.Common.dll remain in the GAC after you install a newer version of Measurement Studio. National Instruments exerts extra effort to ensure that NationalInstruments.Common.dll is backward-compatible so that applications built against prior versions of Measurement Studio continue to work as expected.
    Deployment Requirements
    For assistance in getting started with Measurement Studio 2012, refer to the Measurement Studio Overview and the Getting Started with the Measurement Studio Class Libraries topics in the installed NI Measurement Studio Help or refer to the Getting Started with Measurement Studio PDF or the printed Measurement Studio Release Notes.
    Within Visual Studio, you can launch the NI Measurement Studio Help by selecting Measurement Studio»NI Measurement Studio Help.
    You can access the list of bugs fixed in Measurement Studio 2012 online. Refer to the Measurement Studio Bug Fix Information Web page for a complete listing of the bugs fixed in Measurement Studio 2012.
    Known Issues in Measurement Studio 2012
    For a complete list of incompatibilities in Measurement Studio with previous versions of Measurement Studio and otherwise supported features, including a list of obsoleted members and members that have been changed to sealed override or non-virtual, refer to the Measurement Studio Incompatibilities topic in the NI Measurement Studio Help.
    2012
    • When converting data types, if DataConverter supports both the source and the target data types, then converting an empty array does not throw an exception. CanConvert returns true and Convert returns an empty array of the target data type. For example, DataConverter supports converting Double into DateTime, so CanConvert returns true and Convert returns an empty array of DateTime.In previous versions of Measurement Studio, calling CanConvert returns false and Convert on an empty array would result in an exception.
    • Setting the AnalogWaveform.Timing property to the same value it already contains does not change the value of the AnalogWaveform.IsPrecisionTimingInitialized property. In previous versions of Measurement Studio, when the AnalogWaveform.Timing property was set to any valid value, the AnalogWaveform.IsPrecisionTimingInitialized would return false.
    • The TDMS .NET library throws an InvalidOperationException when calling TdmsChannel.GetData or TdmsChannel.AppendData where TData is an unsupported data type. Previous versions of the TDMS .NET library threw an ArgumentException when calling TdmsChannel.GetData or TdmsChannel.AppendData where TData is an unsupported data type.
    Legacy Languages and Frameworks
    As a result, Measurement Studio 2012 does not provide new feature support for Visual Studio 6.0, Visual Studio 2003, and Visual C++ MFC.
    To qualify to receive these products, you must meet one of the following criteria:
    • You must maintain an active Measurement Studio Standard Service Program (SSP) contract; or
    • You must have purchased the most recent version of Measurement Studio.
    ©2003–2012 National Instruments. All rights reserved.
    LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information section on ni.com/trademarks for other National Instruments trademarks.
    To comment on National Instruments documentation, refer to the National Instruments Web site.
    GMT+8, 2026-4-23 09:14
