查看: 3514|回复: 0
[NI软件产品] NI InstrumentStudio 2019 Win64Eng NI仪器套件InstrumentStudio19.0.2
    发表于 2021-2-24 23:19:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    InstrumentStudio
    InstrumentStudio是一款免费的应用程序软件,提供了集成的交互式PXI测量方法。
    InstrumentStudio可帮助您统一显示数据,将仪器配置导出到代码,并监测和调试您的自动测试系统。 您可以使用大型高分辨率显示器在统一显示界面上查看数据,然后捕获多仪器屏幕截图和测量结果。 您还可保存项目级配置,以便针对特定的待测设备更轻松地重复进行测试,或将仪器配置导出到编程环境,以简化代码并保证测量相关性。您还可以同时使用代码和InstrumentStudio来监测和调试正在运行的测试应用程序。
    2019
    19.0.2
    文件大小: 1551507456 字节 (1.44 GB)
    修改日期: 2019-12-12 04:16
    MD5: 0bd5cad9252a2d06af73fa0bbe8be39d(官方正确)
    SHA1: c3dd86d5c1fdf2cb0a652919f40c6d2732a1e3dc
    SHA256: 6ebd119a99036ebb4faa759187a378428773acdf922c6ba229c167efa2dff183
    CRC32: a609a65d
    InstrumentStudio19.0.2.txt (658 Bytes, 下载次数: 0, 售价: 10 圆)
    InstrumentStudio 2019 Readme
    September 2019
    This file contains important information about InstrumentStudio 2019, including supported hardware and operating systems, a partial list of bugs fixed, and known issues.
    InstrumentStudio allows you to generate and acquire measurements from multiple devices within a single application. You can also use InstrumentStudio to monitor and control devices being used in external applications, capture data files, export device configuration to other applications, and more.
    InstrumentStudio 2019 has the following requirements:
    • Pentium 4 G1 equivalent or later (Intel i5 equivalent or higher recommended)
    • 4 GB RAM
    • 10 GB disk space
    • 1024 x 768 screen resolution (1366 x 768 or higher recommended)
    InstrumentStudio 2019 supports the following operating systems:
    • Windows 7 (SP1) 64-bit2
    • Windows 8.1 64-bit1
    • Windows 10 64-bit1
    • Windows Embedded Standard 7 (SP1)2
    • Windows Server 2008 R2 (SP1) 64-bit2
    • Windows Server 2012 R2 64-bit1
    InstrumentStudio 2019 supports the creation of soft front panels with the following device drivers:
    Device Driver
    Versions Supported by InstrumentStudio 2019
    NI-SCOPE19.1
    NI-FGEN19.1
    NI-DMM18.1
    NI-DCPOWER18.1 (new features in InstrumentStudio 2019 require NI-DCPower version 19.1 or higher)
    Installing InstrumentStudio 2019 with NI Package Manager
    NI automates installation of NI software using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    New FeaturesInstrumentStudio 2019
    • Added power spectral density measurements to oscilloscope FFT channels.
    • Multiple NI-SCOPE devices of the same model can now be synchronized in the same oscilloscope panel.
    • Added support for selecting trigger sources and events from other NI devices in your system.
    • Added waveform graphing, pulse current, pulse voltage, voltage sequence, and current sequence modes to SMU panels, including automatic hardware synchronization across multiple devices.
    • Added asymmetric limits and software-protected ranges to SMU/Power Supply panels.
    • Added NI-DCPower SourceAdapt configuration to SMU panels, useful for transient measurements.
    • Added channel views to hide idle channels, show power calculations, and condense channel views to the SMU/Power Supply panels.
    • Added inductance and capacitance measurements along with open and short cable compensation to digital multimeter (DMM) panels.
    • Added the ability to generate waveforms from binary files to the waveform generator panel.
    • Added debugging and monitoring support to the waveform generator panel.
    • Added exporting configuration files from the waveform generator panel for use with the NI-FGEN driver.
    • Added capability to export device configurations to TestStand for use in test step configuration.
    • Added ability to use pin maps created in Digital Pattern Editor to group devices and channels by site and use pin names for channel aliases.
    InstrumentStudio 2018 SP2
    • Added support for the PXIe-5163 oscilloscope, newly supported in NI-SCOPE 18.7.
    • Added CSV file format for data capture.
    • Added support for exporting instrument events to PXI chassis trigger lines.
    • Added support for arbitrary waveform generation mode to the Waveform Generator panels.
    • Added support for frequency list and sweep modes to the Waveform Generator panels.
    • Added FFT channels, frequency markers, and FFT channel measurements to the Oscilloscope panels.
    • Added additional 2-channel measurements to the Oscilloscope panels.
    InstrumentStudio 2018 SP1
    Added support for the PXIe-5110, PXIe-5111, and PXIe-5113 oscilloscopes, newly supported in NI-SCOPE 18.6
    The following hardware models are supported in InstrumentStudio 2019:
    NI-DCPOWER Devices
    • PXIe-4112
    • PXIe-4113
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    • PXIe-4154
    • PXIe-4162
    • PXIe-4163
    • PXI-4110
    • PXI-4130
    • PXI-4132
    NI-DMM Devices
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    • PXI-4065
    • PXI-4070
    • PXI-4071
    • PXI-4072
    • PCI-4065
    • PCIe-4065
    • USB-4065
    • PCI-4070
    NI-FGEN Devices
    • PXIe-5413 (1-channel)
    • PXIe-5413 (2-channel)
    • PXIe-5423 (1-channel)
    • PXIe-5423 (2-channel)
    • PXIe-5433 (1-channel)
    • PXIe-5433 (2-channel)
    • PXIe-5442
    • PXIe-5450
    • PXIe-5451
    • PXI-5402
    • PXI-5404
    • PXI-5406
    • PXI-5412
    • PXI-5421
    • PXI-5422
    • PXI-5441
    • PCI-5402
    • PCI-5406
    • PCI-5412
    • PCI-5421
    NI-SCOPE Devices
    • PXIe-5105
    • PXIe-5110
    • PXIe-5111
    • PXIe-5113
    • PXIe-5114
    • PXIe-5122
    • PXIe-5160 (2-channel)
    • PXIe-5160 (4-channel)
    • PXIe-5162 (2-channel)
    • PXIe-5162 (4-channel)
    • PXIe-5163
    • PXIe-5164
    • PXIe-5170 (4-channel)
    • PXIe-5170 (8-channel)
    • PXIe-5171 (8-channel)
    • PXIe-5172 (4-channel)
    • PXIe-5172 (8-channel, 325T)
    • PXIe-5172 (8-channel, 410T)
    • PXIe-5185
    • PXIe-5185 (1MΩ)
    • PXIe-5186
    • PXIe-5186 (1MΩ)
    • PXIe-5622
    • PXIe-5622 (DD)
    • PXI-5105
    • PXI-5114
    • PXI-5122
    • PXI-5124
    • PXI-5142
    • PXI-5152
    • PXI-5153
    • PXI-5154
    • PXI-5922
    • PCI-5105
    • PCI-5114
    • PCI-5122
    • PCI-5124
    • PCI-5142
    • PCI-5152
    • PCI-5153
    • PCI-5154
    • PCI-5922
    • PCIe-5155
    • USB-5132
    • USB-5133
    You can access the software and documentation known issues list online. Refer to InstrumentStudio Known Issues on ni.com for an up-to-date list of known issues in InstrumentStudio.
    © 2018-2019 National Instruments. All rights reserved.
    377562D-01
    GMT+8, 2026-4-23 09:13
