查看: 5471|回复: 0
[NI软件产品] NI Package Builder 20.0 Win32/64Eng NI安装包生成器NIPB20.0
    2 小时前
    发表于 2020-11-18 23:07:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI Package Builder可帮助您管理和生成自己的NI软件包、软件包安装程序和订阅源。
    NI Package Builder是一个用于分发软件的实用程序。您可以使用它来管理和生成多个软件包和订阅源,然后使用Package Manager或SystemLink软件进行分发。您还可以生成和分发独立的软件包安装程序。此外,您可以将多个NI产品安装程序捆绑到自定义安装文件中。
    20.0
    文件大小: 548429824 字节 (523.02 MB)
    修改日期: 2020-03-28 03:45
    MD5: ae5e20fead598ca603b8b06c26a267dc(官方正确)
    SHA1: 27ff3802b494cfdc44cd61205e016c753dff5417
    SHA256: 46197909c8ecdc01b4a9bcd9839283345cb9e412564c70462a78249f1f3ed125
    CRC32: a57c6426
    NIPB20.0.txt (645 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Package Builder 20.0 Readme
    February 2020
    This file contains important information about NI Package Builder, including installation instructions, features, and known issues.
    Features
    NI Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Use NI Package Builder to set up, create, and publish complex package-based deployments.
    NI Package Builder 20.0 has the following recommended requirements:
    • Intel i5 or equivalent
    • At least 130 MB of disk space
    • 4 GB RAM
    NI Package Builder 20.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  Refer to NI Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    NI Package Builder 20.0 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by Package Builder 20.0
    NI TestStand™1
    2019 f2
    LabVIEW NXG
    5.0
    1 NI Package Builder supports TestStand deployments that use a version of LabVIEW that TestStand supports. NI Package Builder requires TestStand 2019 f2 to work properly with supported version of LabVIEW. NI Package Builder cannot deploy LabVIEW 2016 and 2017 Runtimes because they are not available as packages.
    NI automates Package Builder installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/info and enter the Info Code exjq43 for more information and steps to resolve this issue.
    Features
    Refer to NI Package Builder Features for a list of new features and changes.
    You can access the software and documentation known issues list online. Visit ni.com/r/nipbknownissues200 for an up-to-date list of known issues in NI Package Builder 20.0.
    Refer to NI Package Builder Bug Fixes for a list of bugs fixed in NI Package Builder 20.0. This is not an exhaustive list of issues fixed in the current version of NI Package Builder.
    Refer to the NI Package Builder Help, accessible from the Package Builder toolbar, for information about Package Builder.
    NI will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2020 National Instruments. All rights reserved.
    377980D-01
    GMT+8, 2026-4-23 10:36
