查看: 3416|回复: 0
[NI驱动程序] NI CompactRIO 20.0 Win32/64 Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2020May
    发表于 2020-10-28 23:33:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO
    20.0
    文件大小: 4047544320 字节 (3.77 GB)
    修改日期: 2020-05-12 03:07
    MD5: 88eb6f79afb1a80e6e2d539b4341d439(重复下载一致)
    SHA1: a1a0e458c78ec65144e45440c9bf8e903745894c
    SHA256: 3dedbd28de63c773c2069c1a6f6730817fcfc15c954bfb7c08c4399ba352b509
    CRC32: 47c4b771
    NICRIOWin20.0.txt (287 Bytes, 下载次数: 2, 售价: 10 圆)
    NI CompactRIO 20.0 and Drivers Readme
    May 2020
    This document contains the following important information about NI CompactRIO 20.0 and Drivers:
    Installing NI CompactRIO 20.0 and Drivers
    What's New in NI CompactRIO 20.0 and Drivers
    Preserving Device Aliases when Upgrading Software
    LabVIEW NXG Support and Considerations
    NI CompactRIO and Drivers Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Installing NI CompactRIO 20.0 and Drivers requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    NI CompactRIO 20.0 and Drivers supports the following operating systems:
    • Windows Server 2016/2012 R21/2008 R2 SP12
    • Windows 10/8.11/7 SP12
    Note  Refer to NI CompactRIO and Drivers Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016, NI CompactRIO and Drivers dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI CompactRIO 20.0 and Drivers will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI CompactRIO 20.0 and Drivers to an unsupported OS. Additionally, after installing NI CompactRIO 20.0 and Drivers, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI CompactRIO 20.0 and Drivers supports the following application software versions, including service packs.
    Versions Supported
    LabVIEWLabVIEW 2020
    LabVIEW 2019 SP1
    LabVIEW 2018 SP1
    LabVIEW 2017 SP1
    LabVIEW NXG5.0
    Complete the following steps to install NI CompactRIO 20.0 and Drivers for use with LabVIEW. Refer to the Supported Hardware and Software section to confirm which software versions support your specific hardware devices.
    • Install one of the supported versions of LabVIEW. Refer to Application Software Support for a list of which versions of LabVIEW NI CompactRIO 20.0 and Drivers supports.
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO 20.0 and Drivers.
    • Added support for LabVIEW 2020 and LabVIEW NXG 5.0.
    • Added FPGA interface support in LabVIEW 2020 for the NI 9326 C Series Module.
    • NI CompactRIO 20.0 and Drivers ends support for the following devices:
      • cRIO-9022
      • cRIO-9023
      • cRIO-9024
      • cRIO-9025
      • cRIO-9073
      • cRIO-9074
      • cRIO-9075
      • cRIO-9076
      • cRIO-9081
      • cRIO-9082
      • cRIO-9111
      • cRIO-9112
      • cRIO-9113
      • cRIO-9114
      • cRIO-9116
      • cRIO-9118
      • NI 9144
      • NI 9146
      • NI 9148
      • sbRIO-9601
      • sbRIO-9602
      • sbRIO-9605
      • sbRIO-9606
      • sbRIO-9611
      • sbRIO-9612
      • sbRIO-9623
      • sbRIO-9626
      • sbRIO-9631
      • sbRIO-9632
      • sbRIO-9633
      • sbRIO-9636
      • sbRIO-9641
      • sbRIO-9642
      • sbRIO-9693
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO.
    Visit ni.com/compactrio for additional NI CompactRIO product support and information.
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO and Drivers to access the software help for your NI CompactRIO device.
    The following sections detail considerations for using LabVIEW NXG 5.0 with NI CompactRIO 20.0 and Drivers.
    LabVIEW NXG Hardware Support
    NI CompactRIO 20.0 and Drivers supports the following devices in LabVIEW NXG 5.0
    • C Series Modules
      • NI 9201
      • NI 9203
      • NI 9205
      • NI 9206
      • NI 9215
      • NI 9221
      • NI 9263
      • NI 9264
      • NI 9265
      • NI 9266
      • NI 9269
      • NI 9401
    • CompactRIO Controllers
      • cRIO-9040
      • cRIO-9041
      • cRIO-9042
      • cRIO-9043
      • cRIO-9045
      • cRIO-9046
      • cRIO-9047
      • cRIO-9048
      • cRIO-9049
      • cRIO-9053
      • cRIO-9054
      • cRIO-9055
      • cRIO-9056
      • cRIO-9057
      • cRIO-9058
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI CompactRIO and Drivers will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2004–2020 National Instruments. All rights reserved.
    375022P-01
    GMT+8, 2026-4-23 09:14
