查看: 4059|回复: 0
[NI驱动程序] NI CompactRIO 19.6 Win32/64 Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2019Dec
    发表于 2020-10-28 23:27:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO
    19.6
    文件大小: 4205488128 字节 (3.92 GB)
    修改日期: 2019-12-13 22:21
    MD5: 8df2a12b49b823c08fa90e88bd3f7d0a(官方正确)
    SHA1: cf634bd9a753344d1c93cab2fa26a525fe432fd3
    SHA256: 90c8d7a9a02a4a0c90d35c92a7078eccf4adee0cfb88a2cb3dccbaf58b531d59
    CRC32: 6623212c
    NICRIOWin19.6.txt (287 Bytes, 下载次数: 1, 售价: 10 圆)
    NI CompactRIO and Drivers Readme
    December 2019
    This document contains the following important information about NI CompactRIO and Drivers December 2019:
    Installing NI CompactRIO and Drivers December 2019
    What's New in NI CompactRIO and Drivers December 2019
    Preserving Device Aliases when Upgrading Software
    NI CompactRIO and Drivers Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Note  This installation requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    Complete the following steps to install NI CompactRIO and Drivers December 2019 for use with LabVIEW. Refer to the Supported Hardware and Software section to confirm which software versions support your specific hardware devices.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2019 SP1
      • LabVIEW 2018 SP1
      • LabVIEW 2017 SP1
      • LabVIEW 2016
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO and Drivers December 2019.
    NI CompactRIO and Drivers supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  Refer to NI CompactRIO and Drivers Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016, NI CompactRIO and Drivers dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI CompactRIO and Drivers December 2019 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI CompactRIO and Drivers December 2019 to an unsupported OS. Additionally, after installing NI CompactRIO and Drivers December 2019, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    • Added software support in LabVIEW 2019 SP1 for the NI 9470 C Series Module.
    • Added Scan Interface support for the NI 9253 C Series Module.
    • Added Component-Level IP support (CLIP) for RS-232 and RS-485 on sbRIO-9608, sbRIO-9609, sbRIO-9628, sbRIO-9629, and sbRIO-9803 devices.
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO.
    Visit ni.com/compactrio for additional NI CompactRIO product support and information.
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO and Drivers to access the software help for your NI CompactRIO device.
    NI CompactRIO and Drivers will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2004–2019 National Instruments. All rights reserved.
    375022N-01
    GMT+8, 2026-4-23 09:13
