查看: 2938|回复: 0
[NI驱动程序] NI CompactRIO 19.5 Win32/64 Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2019Oct
    发表于 2020-10-28 23:21:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO
    19.5
    文件大小: 4174186496 字节 (3.89 GB)
    修改日期: 2019-10-25 22:36
    MD5: 316f1be440956eab69eecb696f37a013(重复下载一致)
    SHA1: def3496046676bc606f8ebfe806ededc58608b8b
    SHA256: a6fa8c333bcaabf6fe9aee27b3904230892f8ccd0460b46f3e80b69c07c57ab8
    CRC32: 53668487
    NICRIOWin19.5.txt (287 Bytes, 下载次数: 0, 售价: 10 圆)
    NI CompactRIO Device Drivers Readme
    October 2019
    This document contains the following important information about NI CompactRIO Device Drivers October 2019:
    Installing NI CompactRIO Device Drivers October 2019
    What's New in NI CompactRIO Device Drivers October 2019
    Preserving Device Aliases when Upgrading Software
    NI CompactRIO Device Drivers Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Note  This installation requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    Complete the following steps to install NI CompactRIO Device Drivers October 2019 for use with LabVIEW. Refer to the Supported Hardware and Software section to confirm which software versions support your specific hardware devices.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2019 SP1
      • LabVIEW 2018 SP1
      • LabVIEW 2017 SP1
      • LabVIEW 2016
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO Device Drivers October 2019.
    NI CompactRIO Device Drivers supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  Refer to NI CompactRIO Device Drivers Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016, NI CompactRIO Device Drivers dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI CompactRIO Device Drivers October 2019 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI CompactRIO Device Drivers October 2019 to an unsupported OS. Additionally, after installing NI CompactRIO Device Drivers October 2019, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Added software support in LabVIEW 2019 SP1 for the following new CompactRIO Single-Board Controllers:
    • sbRIO-9603
    • sbRIO-9608
    • sbRIO-9609
    • sbRIO-9628
    • sbRIO-9629
    • sbRIO-9638
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO.
    Visit ni.com/compactrio for additional NI CompactRIO product support and information.
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your NI CompactRIO device.
    NI CompactRIO Device Drivers will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2004–2019 National Instruments. All rights reserved.
    375022M-01
    GMT+8, 2026-4-23 09:15
