查看: 3697|回复: 0
[NI驱动程序] NI CompactRIO 19.1 and Drivers Win32/64 Eng/Jpn/Chn设备驱动程序完整版及驱动下载NICRIO2019June
    发表于 2020-10-28 23:18:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO
    19.1 and Drivers
    文件大小: 7586273280 字节 (7.07 GB)
    修改日期: 2019-06-18 20:42
    MD5: 72a41b4c912379b2626359496c33e36e(官方正确)
    SHA1: 2ba5a483771646da2e324b2b34d18750d61d63aa
    SHA256: 7616a31655080b8dfc3f25aac3117f3ce2bbdbeb00435ceaba6fb0ea57f9b3dc
    CRC32: cd6cbc2d
    NICRIOWin19.1 - Driver.txt (329 Bytes, 下载次数: 2, 售价: 20 圆)
    NI CompactRIO Device Drivers Readme
    June 2019
    This document contains the following important information about NI CompactRIO Device Drivers June 2019:
    Installing NI CompactRIO Device Drivers June 2019
    What's New in NI CompactRIO Device Drivers June 2019
    Preserving Device Aliases when Upgrading Software
    NI CompactRIO Device Drivers Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Note  This installation requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    Complete the following steps to install NI CompactRIO Device Drivers June 2019 for use with LabVIEW. Refer to the Supported Hardware and Software section to confirm which software versions support your specific hardware devices.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2019
      • LabVIEW 2018 SP1
      • LabVIEW 2017 SP1
      • LabVIEW 2016
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO Device Drivers June 2019.
    NI CompactRIO Device Drivers supports the following operating systems:
    • Windows 10/8.11/7 SP12
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft articles March 2014 servicing stack update for Windows 8.1 and Windows Server 2012 R2 and Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update: April 2014 for more information about how to install these updates.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft Security Advisory 3033929 for more information about how to install this security update.
    Note  Refer to NI CompactRIO Device Drivers Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016, NI CompactRIO Device Drivers dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI CompactRIO Device Drivers June 2019 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI CompactRIO Device Drivers June 2019 to an unsupported OS. Additionally, after installing NI CompactRIO Device Drivers June 2019, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Added software support in LabVIEW 2019 for the following new C Series Modules:
    • NI 9252
    • NI 9253
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO.
    Visit ni.com/compactrio for additional NI CompactRIO product support and information.
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your NI CompactRIO device.
    NI CompactRIO Device Drivers will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2004–2019 National Instruments. All rights reserved.
    375022L-01
    GMT+8, 2026-4-23 09:13
