查看: 3071|回复: 0
[NI驱动程序] NI CompactRIO 18.5 Win32 Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2019Jan
    发表于 2020-10-28 23:07:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO 18.5 Win32Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2019Jan
    NI CompactRIO
    18.5
    文件大小: 5115404259 字节 (4.76 GB)
    修改日期: 2018-10-16 05:16
    MD5: 0b28a695370b02a92e92c29018d18bd5(官方正确)
    SHA1: 1b0ed276a49437174c799e74d62dbd4dab810c93
    SHA256: c85440881e6b4190bab25d25267a862520488893a4d45f16db8ae0254c0f0835
    CRC32: 48e3630a
    NICRIOWin18.5.txt (287 Bytes, 下载次数: 4, 售价: 10 圆)
    NI CompactRIO Device Drivers Readme
    January 2019
    This document contains the following important information about NI CompactRIO Device Drivers January 2019:
    Installing NI CompactRIO Device Drivers January 2019
    What's New in NI CompactRIO Device Drivers January 2019
    Preserving Device Aliases when Upgrading Software
    Note  This installation requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    Complete the following steps to install NI CompactRIO Device Drivers January 2019 for use with LabVIEW. Refer to the Supported Hardware and Software section to confirm which software versions support your specific hardware devices.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2018 SP1
      • LabVIEW 2017 SP1
      • LabVIEW 2016
      • LabVIEW 2015 SP1
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO Device Drivers January 2019.
    NI CompactRIO Device Drivers supports the following operating systems:
    • Windows 10/8.11/7 SP12
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft articles March 2014 servicing stack update for Windows 8.1 and Windows Server 2012 R2 and Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update: April 2014 for more information about how to install these updates.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft Security Advisory 3033929 for more information about how to install this security update.
    Note  In 2016 NI CompactRIO Device Drivers dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI CompactRIO Device Drivers January 2019 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI CompactRIO Device Drivers January 2019 to an unsupported OS. Additionally, after installing NI CompactRIO Device Drivers January 2019, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI CompactRIO Device Drivers January 2019 ends support for the NI 9802 C Series Memory Module.
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO.
    Visit to ni.com/compactrio for additional NI CompactRIO product support and information.
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your NI CompactRIO device.
    © 2004–2019 National Instruments. All rights reserved.
    375022J-01
    GMT+8, 2026-4-23 09:14
