查看: 4057|回复: 0
[NI驱动程序] NI CompactRIO 18.0 Win32 Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2018May
    发表于 2020-10-28 23:02:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO 18.0 Win32Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2018May
    NI CompactRIO
    18.0
    文件大小: 5016803819 字节 (4.67 GB)
    修改日期: 2018-05-17 00:57
    MD5: b8336a8d3436a6bbf5f1aca658aa41ca(官方正确)
    SHA1: 979130804290550831e87554e5f9b61678655c4d
    SHA256: 9f34fe13c6d6d3f2824e8587aa581955a10bc84fdd51146822b301b6bf1016f8
    CRC32: 0e30fc6e
    NICRIOWin18.0.txt (287 Bytes, 下载次数: 13, 售价: 10 圆)
    NI CompactRIO Device Drivers Readme
    May 2018
    This document contains the following important information about NI CompactRIO Device Drivers May 2018:
    Installing NI CompactRIO Device Drivers May 2018
    What's New in NI CompactRIO Device Drivers May 2018
    Preserving Device Aliases when Upgrading Software
    Note  This installation requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    Complete the following steps to install NI CompactRIO Device Drivers May 2018 for use with LabVIEW.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2018
      • LabVIEW 2017 SP1
      • LabVIEW 2016
      • LabVIEW 2015 SP1
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO Device Drivers May 2018.
    • Software support in LabVIEW 2018 for the following new hardware:
      • NI 9231
      • NI ELVIS III
    • Scan Interface Mode support in LabVIEW 2018 for the following eixsting C Series modules:
      • NI 9210
      • NI 9224
      • NI 9228
    • NI CompactRIO Device Drivers May 2018 no longer supports the FTP Server Recommended Software Set add-on for CompactRIO Linux-RT devices.
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your NI CompactRIO device.
    NI CompactRIO Device Drivers supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO.
    Visit to ni.com/compactrio for additional NI CompactRIO product support and information.
    © 2004–2018 National Instruments. All rights reserved.
    375022G-01
    GMT+8, 2026-4-23 09:14
