查看: 4396|回复: 0
[NI驱动程序] NI CompactRIO 17.0 Win32 Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2017May
    发表于 2020-10-28 22:57:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO 17.0 Win32Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2017May
    NI CompactRIO
    17.0
    文件大小: 3342073425 字节 (3.11 GB)
    修改日期: 2017-05-19 15:07
    MD5: bd58e0f444ca3b493a5f13589bbc4df5(官方正确)
    SHA1: 5d3afbd91f406efad493e653753ee74ef9f2ed40
    SHA256: a09da3dbe745752deae7b40a17c6a2dee8999a436b34220d1185b20c1bef8951
    CRC32: 8c34759c
    NICRIOWin17.0.txt (287 Bytes, 下载次数: 0, 售价: 10 圆)
    NI CompactRIO Device Drivers Readme
    May 2017
    This document contains the following important information about NI CompactRIO Device Drivers May 2017:
    Installing NI CompactRIO Device Drivers May 2017
    What's New in NI CompactRIO Device Drivers May 2017
    Preserving Device Aliases when Upgrading Software
    Note  This installation requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    Complete the following steps to install NI CompactRIO Device Drivers May 2017 for use with LabVIEW.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2017
      • LabVIEW 2016
      • LabVIEW 2015 SP1
      • LabVIEW 2014 SP1
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO Device Drivers May 2017.
    • Scan interface mode support for the following new C Series Modules:
      • NI 9350
      • NI 9351
    • Scan interface mode support for the following existing C Series Modules:
      • NI 9266
    • NI CompactRIO Device Drivers May 2017 no longer supports the following devices:
      • cRIO-9002
      • cRIO-9004
      • cRIO-9072
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your NI CompactRIO device.
    NI CompactRIO Device Drivers supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO.
    Visit to ni.com/compactrio for additional NI CompactRIO product support and information.
    © 2004–2017 National Instruments. All rights reserved.
    375022E-01
    GMT+8, 2026-4-23 09:14
