查看: 3654|回复: 0
[NI驱动程序] NI CompactRIO 15.5 Win32 Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2016Feb
    发表于 2020-10-28 22:45:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO 15.5 Win32Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2016Feb
    NI CompactRIO
    15.5
    文件大小: 3370601097 字节 (3.14 GB)
    修改日期: 2016-01-30 06:31
    MD5: 9e7021e96688c6eaf11594e7d9fbc146(官方正确)
    SHA1: b5a59c96663ae8d44f189228e17a5b3ced745bdf
    SHA256: 0c608260c6c4b7acf089228c932316f74408bae486feac9f128ebced71af4599
    CRC32: 887e0417
    NICRIOWin15.5.txt (287 Bytes, 下载次数: 0, 售价: 10 圆)
    NI CompactRIO Device Drivers February 2016 Readme
    February 2016
    This document contains the following important information about NI CompactRIO Device Drivers February 2016:
    • Installing NI CompactRIO Device Drivers February 2016
    • What's New in NI CompactRIO Device Drivers February 2016
    • Preserving Device Aliases when Upgrading to NI CompactRIO Device Drivers February 2016
    • Driver Version Naming Changes
    • Bug Fixes
    • Known Issues
    • Accessing the Help
    • Supported Platforms
    • Supported Hardware and Software
    • Product Security and Critical Updates
    • Using NI Software with Microsoft Windows 10
    • Using NI Software with Microsoft Windows 8.1
    • NI CompactRIO Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    • Legal Information
    Note  This installation requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    Complete the following steps to install NI CompactRIO Device Drivers February 2016 for use with LabVIEW.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2015 SP1
      • LabVIEW 2014 SP1
      • LabVIEW 2013 SP1
      • LabVIEW 2012 SP1
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO Device Drivers February 2016.
    ↑ Back to Top
    • Software support for the following new CompactRIO controllers:
      • cRIO-9032
      • cRIO-9037
    • FPGA Interface mode support for the following new C Series modules:
      • NI 9436
    • Scan Interface mode support for the following existing C Series modules:
      • NI 9209
      • NI 9216
      • NI 9226
    • Support for Microsoft Windows 10.
    • Ability to detect the active power source for a cRIO-903x controller from a LabVIEW property. Right-click the System Hardware property node and select CompactRIO»Active Power Source. You can use this property to detect whether the controller has reverted to battery backup and handle that change programmatically.
    ↑ Back to Top
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    ↑ Back to Top
    NI CompactRIO versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with.
    Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI CompactRIO 15.0 is the version released with LabVIEW 2015.
    The last version released under the old numbering scheme is NI CompactRIO 4.1. The first version released under the new numbering scheme is NI CompactRIO 13.0.
    ↑ Back to Top
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    ↑ Back to Top
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    ↑ Back to Top
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your NI CompactRIO device.
    ↑ Back to Top
    Supported Platforms
    Use the following Microsoft Windows operating systems and service packs with NI CompactRIO Device Drivers February 2016.
    Operating System64-bit32-bitComments
    Windows 10
    Refer to the Using NI Software with Microsoft Windows 10 section of this document for more information about NI CompactRIO on Windows 10.
    Windows 8.1
    Refer to the Using NI Software with Microsoft Windows 8.1 section of this document for more information about NI CompactRIO on Windows 8.1.
    Windows 7 Professional
    Windows Vista Business SP1
    Refer to the NI CompactRIO Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016 section of this document for more information about NI CompactRIO support for those versions.
    Windows XP Professional SP3
    Windows Server 2012 R2
    Windows Server 2008 R2
    Windows Server 2003 R2
    Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    ↑ Back to Top
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO.
    Visit to ni.com/compactrio for additional NI CompactRIO product support and information.
    ↑ Back to Top
    ↑ Back to Top
    ↑ Back to Top
    ↑ Back to Top
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1. You can launch NI MAX either from the Apps view or from within NI Launcher.
    Windows 8.1 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.1 DesktopStart screenRight-click application and select Pin to Start
    Windows 8.1 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    For more information about NI support for Windows 8.1, visit ni.com/windows8.
    ↑ Back to Top
    NI CompactRIO will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI CompactRIO that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    ↑ Back to Top
    © 2004–2016 National Instruments. All rights reserved.
    375022C-01
    GMT+8, 2026-4-23 09:17
