查看: 3170|回复: 0
[NI驱动程序] NI-RIO 4.0旧版设备驱动Linux系统32位English完整版
    发表于 2020-10-27 22:42:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RIO(旧版)
    NI-RIO用于为可重配置硬件设备提供支持。
    NI-RIO是一个设备驱动,用于支持可重配置I/O (RIO)硬件的识别、编程和部署。它为CompactRIO模块、多功能可重配置I/O设备、PXI多功能可重配置I/O模块和FlexRIO仪器提供了支持。
    4.0
    文件大小: 10895360 字节 (10.39 MB)
    修改日期: 2011-08-18 04:25
    MD5: 621a7acc6cd3028af711636bd45587de(官方正确)
    SHA1: e566750ac27d9914146e4f221bccbf05e57441ff
    SHA256: 194a53450c1e91770084da2284d3f0166857f9244b18ba7a174101341d6b2823
    CRC32: 46355108
    NIRIOLinux4.0.txt (302 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RIO for Linux, Version 4.0.0Copyright (c) 2011 National Instruments Corporation.All Rights Reserved.-------------------------------------------------------------------------------This file contains late-breaking news about NI-RIO and supersedes anyinformation found in other documentation included in the distribution. Refer toni.com/linux for the most recent information about Linux support from NationalInstruments.------------------------------------------------------------------------------------------------Table of Contents------------------ NI-RIO for Linux- Differences from the Windows Driver- System Requirements- Installing NI-RIO for Linux- Using the NI-RIO Driver and FPGA Interface C API- Using the NI-RIO RPC Server- Uninstalling NI-RIO for Linux- Running Linux on PXI Controllers- FAQ----------------------NI-RIO for Linux----------------------NI-RIO for Linux contains the NI-RIO drivers, the FPGA Interface C API runtimelibrary, and all supporting runtime libraries and services necessary tointeract with a RIO device from a system running Linux.-----------------------------------Differences from the Windows Driver-----------------------------------The following NI-RIO driver features supported for Windows are not supportedfor Linux:* Development of LabVIEW FPGA VIs and bitfiles (*.lvbitx)* Development of LabVIEW FPGA Interface host VIsYou must compile a bitfile using LabVIEW FPGA on a Windows machine. Refer tothe "Using the NI-RIO Driver and FPGA Interface C API" section for moreinformation.-------------------System Requirements-------------------NI-RIO for Linux requires one of the following distributions:* Red Hat Enterprise Linux 5.x i386* Red Hat Enterprise Linux 5.x x86_64* Red Hat Enterprise Linux 6.x i386* Red Hat Enterprise Linux 6.x x86_64* Scientific Linux 5.x i386* Scientific Linux 5.x x86_64* Scientific Linux 6.x i386* Scientific Linux 6.x x86_64NI-RIO does not support systems with memory or memory-mapped devices beyond thefirst 4 GB of physical address space. NI-RIO will fail to load if it detectshardware beyond this address limit. To ensure the successful operation ofNational Instruments RIO products, you must use a kernel configuration thatrecognizes only up to 4 GB of physical memory. Refer to the documentation ofyour Linux distribution to determine how to configure the distributioninstaller to select an appropriate kernel. Alternatively, you can dynamicallyrestrict the addressable range of the kernel to a specific limit by passing"mem=" to the kernel at boot time. For example, to restrict the kernel to3 GB of addressable physical space, specify "mem=3072M".For more information about Linux versions and distributions supported byNational Instruments, refer to ni.com/linux.In order to use NI-RIO on Linux, you need a Windows system to develop yourLabVIEW FPGA application. You must compile a bitfile, generate headers with theFPGA Interface C API Generator, and then move the application to your Linuxsystem. Refer to the "Using the NI-RIO Driver and FPGA Interface C API" sectionfor more information.---------------------------Installing NI-RIO for Linux---------------------------Before installing this version of NI-RIO, uninstall any previous versions. Forinformation about uninstalling an old version of NI-RIO, refer to the readmefor that version.To install NI-RIO for Linux, run the INSTALL script from this directory asroot. The INSTALL script ensures that all requirements are met beforeinstalling the NI-RIO software. The script then uses RPM to install the contentof the NI-RIO packages in /usr/local/natinst/. The script also creates links in/usr/local/lib/ to the libraries in /usr/local/natinst/.Missing dependencies can cause the installer to fail. The most commonlymissing dependencies are GCC and kernel headers. You can install thosedependencies by running the following as root:   yum install gcc kernel-devel-$(uname -r)After installing all missing dependencies, run the INSTALL script again.Once the INSTALL script completes successfully, reboot the system to ensurethat all the drivers are updated.After installation, the NI-RIO drivers are loaded by default at boot time ifthere is a RIO device in the system.------------------------------------------------Using the NI-RIO Driver and FPGA Interface C API------------------------------------------------You must begin development on a computer running Windows. Use LabVIEW FPGA todevelop and build an FPGA VI that runs on a RIO device. Use the FPGAInterface C API Generator to create the C source files for your application.Go to ni.com/info and enter the Info Code fpgainterfacecapi to get the latestversion of the FPGA Interface C API Generator. Then copy the generated filesto the Linux machine to begin development of C/C++ code for your application.For information about using the FPGA Interface C API, go to ni.com/info andenter the Info Code fpgainterfacecapihelp.To find the RIO device you are using in your application, use the command"lsni -v" to list information on all National Instruments devices in thesystem.If your application requires triggering, you can reserve triggers staticallywith the NI PXI Config utility or dynamically with NI-VISA. For informationabout using these configuring PXI systems in Linux, go to ni.com/info and enterthe Info Code linuxconfigpxi. For information about PXI triggering, go toni.com/info and enter the Info Code pxitrigger. This version of NI-RIO forLinux supports triggering only on i386 versions of Linux.---------------------------Using the NI-RIO RPC Server---------------------------Complete the following steps to access Linux targets remotely using the NI-RIORPC server:1. Select a port for the NI-RIO RPC server to use. The default port is 11296.2. Configure the system firewall to allow TCP connections through the selectedport.3. Edit the nirio.ini file at /usr/local/natinst/nirio/etc/ to specify both theselected port and the users allowed to access the device. The following examplespecifies the default port, 11296, and allows only users at the IP address10.0.29.54 to have access to the device:   [General]   RpcServerPort = 11296   DeviceAccess = "-*;+10.0.29.54"4. Start the NiRioRpcServer at /usr/local/natinst/nirio/bin/.Note that the DeviceAccess variable is defined by a semicolon-delimited list ofqualifiers, IP addresses, DNS hostnames, and wildcard patterns. To determinewhether a remote system has access to RIO devices on this system, the RIOserver looks for an entry in the list that matches the remote system. The "+"qualifier allows access, and the "-" qualifier denies access. The RIO serveruses the last matching entry in the list to determine whether to allow or denyaccess. If no entry matches the remote system, the RIO server denies access.For example, if the list is empty, all remote systems are denied access. Thefirst argument in the example above explicitly restricts remote access from anyIP address. The second argument allows access from the IP address 10.0.29.54.To allow access from multiple IP addresses, define DeviceAccess as follows:   DeviceAccess = "+10.0.29.54;+10.0.35.42"To allow access from any IP address on the network, define Device Access asfollows:   DeviceAccess = "+*"-----------------------------Uninstalling NI-RIO for Linux-----------------------------To uninstall the driver and its dependencies, run the UNINSTALL script.--------------------------------Running Linux on PXI Controllers--------------------------------NI-RIO for Linux works with all PXI and PXI Express controllers and chassis.However, to use PXI Express features, you must install the PXI PlatformServices driver 2.6 (not included with this installer), use an i386 version ofLinux, and use a PXI Express controller and chassis.PXI Express features:* NI-P2P streaming* Slot and chassis identification* Trigger bus number identification (for trigger reservation)Supported PXI Express controllers:* PXIe-8101* PXIe-8108Supported PXI Express chassis:* Any PXI Express chassis except the PXIe-1073To install the PXI Platform Services driver, go to ni.com/info and enter theInfo Code linuxpxidriver. For installation and configuration notes specific toeach controller, go to ni.com/info and enter the Info Code linuxpxiembedded.---FAQ---Q: I am not using one of the distributions listed as supported above. Will   NI-RIO still work?A: The distributions above have been tested and verfied by National   Instruments. Other distributions may work, but you should test extensively   before deploying a system using such a configuration. For information about   which Linux distributions National Instruments supports, go to ni.com and   enter the Info Code nilinuxdistro.Q: My application used to work, but I updated my kernel and now I'm getting   "libnipalu.so failed to initialize    Perhaps you need to run updateNIDrivers    Aborted"   Will it no longer work?A: The NI-RIO and supporting drivers must be built with the kernel headers   for the kernel that is in use. As root, run "updateNIDrivers" and restart   to fix the issue.Q: I am using a PXI controller and I have installed PXI Platform Services on my   i386 version of Linux, but when I run "lsni -v" I don't see any PXI-specific   information. What is wrong?A: You must reboot after installing PXI Platform Services to see PXI-specific   information.Q: Does NI-RIO 4.0.0 support native x86_64 applications?A: NI-RIO 4.0.0 does not support native x86_64 applications. The shared   libraries included with NI-RIO are compiled as x86, so all user   applications must be x86 as well. Note that an x86 application can run   unchanged on an x86_64 system, provided all required x86 libraries are   installed.Q: The NI-RIO installation was successful but returned the following error:   "/lib/ld-linux.so.2: bad ELF interpreter: No such file or directory".   What went wrong?A: This kind of error occurs if the installer runs on an x86_64 distribution   that does not include required x86 libraries. Install x86 versions of glibc   and libstdc++, then uninstall and re-install NI-RIO.Q: When I run 'lsni', I see the following error:   "libstdc++.so.6: cannot open shared object file: No such file or directory"A: 'lsni' requires libstdc++. You must install the x86 version of libstdc++.
    GMT+8, 2026-4-23 09:22
