LabVIEWӾ
 һ
 עԱ
б
鿴: 4128|ظ: 0
[NIƷ] NI Linux RT System Image 19.6 Win32Eng NI Linuxʵʱϵͳӳ2019.12
  • TAÿ
    2 Сʱǰ
  • ǩ: 3865
    ǩ: 58
    2020-10-24 23:03:22 | ʾȫ¥ |Ķģʽ ԣ㶫ʡݸ ͨ
    ע½ɲ鿴ʹͼԼ
    Ҫ ¼ ſػ鿴û˺ţעԱ
    Windowsϵͳ£LinuxMACϵͳ˽NIĸģ顢߰ʹNI֤ģ󲿷ֵĶʹNI Lincense ActivatorNIкSerial NumberɼNI License ActivatorLabVIEW/VBAI/VDM/VASģ鹤߰ƽ⹤߲ް汾http://visionbbs.com/thread-490-1-1.html
    Ӿ̳ĸNIԴӾصģʹ⣬󲿷ֵĶʹãṩԴṩ֧֡ԴصַһͬʱṩNIٷͰٶ̵ĵַijЩ߰NIַʧЧûNIַֻʹðٶ̵ַٶ̵ַʧЧڣϵ̳ͷ¡NIķʱٶȺ׳ɰװʱִ޷װɺ󣬶ԴУ(NIһṩMD5SHA256)֤ٷӾ̳ṩУͶԱȣһ¾Ϳ԰װ粻һ£ҪءӾ̳ϴԴ϶صԴ2019صԴNIȷУͶԱȹ֤ȷԴϴٶ̡У͹صַļHashFHashļУ֤ļȷ֤MD5ֵ㡢SHA1ֵ㡢SHA256ֵ㡢CRC32ֵhttp://visionbbs.com/thread-26524-1-1.html
    ڴNIʵʱNI LinuxʵʱϵͳҪNI Linux RT System Image
    NI Linux RTSystem Imageһʵаϵͳӳڸʽô󲿷NIʵʱʹܹNI Linux Real-TimeϵͳҪµװPXIҪȸϵͳӳע̱LinuxʹûLinus TorvaldsרȨLMIȨLinus TorvaldsӵLinuxע̱ȫΧڵȨ
    19.6~2019.12
    ļС: 533886976 ֽ (509.15 MB)
    ޸: 2019-12-18 10:31
    MD5: 74d99ed4e201d71c6b55da77c81aa7eeٷȷ
    SHA1: c80b9a1c3c53063503764de5e55a462968861761
    SHA256: f5bcdb44a258528a6d9985b76f529666c4d209fd62dbb0698d09029051aca0a6
    CRC32: d0c3e808
    ٶ̺NIٷصַ¸鿴
    NI Linux RT System Image19.6.txt (333 Bytes, ش: 3, ۼ: 10 Բ)
    LabVIEW 2019 Real-Time Module Readme
    March 2019
    This file contains important information about the LabVIEW 2019 Real-Time Module, including system requirements, installation instructions, and known issues.
    New and Changed Features
    Real-Time Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The Real-Time Module is a complete solution for creating reliable, stand-alone embedded systems with a graphical programming approach. As an add-on to the LabVIEW development environment, the Real-Time Module helps you develop and debug graphical, deterministic real-time applications that can be downloaded to and executed on embedded hardware devices such as CompactRIO Controllers, CompactDAQ Controllers, CompactRIO Single-Board Controllers, PXI Controllers, or vision systems.
    The Real-Time Module has the following requirements:
    • LabVIEW 2019 Full or Professional Development System (32-bit)
    • At least 200 MB of disk space in addition to the LabVIEW-recommended minimum
    Note
    • The Real-Time Module is compatible with LabVIEW (32-bit) only. Therefore, you must have LabVIEW (32-bit) installed even if you use a 64-bit OS.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    The Real-Time Module supports the following operating systems for application development:
    • Windows 10 (version 1809)/8.11/7 SP12
    Note  Refer to Real-Time Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016 the Real-Time Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2019 Real-Time Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2019 Real-Time Module to an unsupported OS. Additionally, after installing the LabVIEW 2019 Real-Time Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The Real-Time Module installs the following real-time operating systems (RTOSes). Refer to the specific RT target hardware documentation for information about which RTOS your target uses.
    • NI Linux Real-Time
    • Phar Lap ETS
    • VxWorks
    Note  Each RTOS supports only a subset of LabVIEW features. Refer to the Real-Time Module»Real-Time Operating Systems book on the Contents tab of the LabVIEW Help for a list of unsupported LabVIEW features and special considerations for each RTOS.
    The LabVIEW 2019 Real-Time Module supports the following application software versions, including service packs.
    Versions Supported by the Real-Time Module
    LabVIEW2019 (32-bit only)
    You also can install all of your LabVIEW productsincluding the Real-Time Moduleusing the LabVIEW 2019 Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    Note  If you purchased this product with an NI Software Suite or NI Product Bundle, use the NI Package Manager or the installation media that shipped with your purchase to install this product.
    Installing and Using Japanese and Simplified Chinese Languages on an RT Target
    After you install the Real-Time Module on your development computer, you can complete the following steps to install and use Japanese and Simplified Chinese languages on an RT target:
    • Use the LabVIEW Real-Time Software Wizard in NI Measurement & Automation Explorer (NI MAX) to install the Language Support for Japanese or Language Support for Simplified Chinese software component on the RT target. Refer to the Measurement & Automation Explorer Help for information about the LabVIEW Real-Time Software Wizard.
    • Open the System Settings tab and select Japanese or Simplified Chinese as the Locale.
    Note  You cannot use Japanese or Simplified Chinese characters in directory names or filenames on the RT target.
    Configuring RT Targets
    Use NI MAX to configure RT targets and to install software and drivers on targets. You can install NI MAX from the NI Package Manager or the LabVIEW Platform media.
    • Networked RT TargetsRefer to the Remote Systems book in the Measurement & Automation Explorer Help, available by selecting Help»MAX Help from MAX, for information about configuring networked RT targets.
    • Desktop PC TargetsRefer to the Using Desktop PCs as RT Targets with the Real-Time Module document for information about configuring a desktop PC as a networked RT target. Navigate to the labview\manuals directory and double-click RT_Using_PC_as_RT_Target.pdf to open the document.
    Note  If you install NI Web-based Configuration & Monitoring on an RT target, you can use a web browser to perform common monitoring and configuration tasks on the target. On the Contents tab in the LabVIEW Help, select Fundamentals»Working with Projects and Targets»How-To»Monitoring and Configuring a Remote Device from a Web Browser for information about NI Web-based Configuration & Monitoring.
    • Dropped support for time-triggered shared variables. The following palette, VIs, and properties are deprecated:
      • Time-Triggered Network VIs palette
      • Create Time Triggered Network Timing Source Node
      • Handle Timed-Triggered Network Error VI
      • Time-Triggered:Enabled Property
      • Time-Triggered:GUID Property
      • Time-Triggered:Max Size Property
      • Time-Triggered:Slot Offset Property
      • Time-Triggered:SMB Array Number Of Elements Property
      • Time-Triggered:SMB Variable Property
      • Time-Triggered:Table Index Property
      • Time-Triggered:Transmission Time Property
    • Added support for PXI controllers with NI Linux Real-TimePXIe-8840 Quad-Core, PXIe-8880, and PXIe-8861. This support no longer relies on VeriStand.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code lvrt2019kil for an up-to-date list of known issues in the LabVIEW 2019 Real-Time Module.
    The following items are the IDs and titles of a subset of issues fixed in the Real-Time Module. This is not an exhaustive list of issues fixed in the current version of the Real-Time Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    695318Using Auto-Increment file path in Application Builder causes an RTEXE to fail to deploy to a real-time target.
    715800A UDP Multicast read call only works on the first Network Interface Card for NI Linux Real-Time targets.
    718638When using external DAQ timing on a Timed Loop, the first iteration of the Timed Loop may execute without external timing.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Real-Time Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Real-Time Module are located in the labview\examples\Real-Time Module directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Real-Time Module will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 1999C2019 National Instruments. All rights reserved.
    374714K-01
    ظ
    ʹõ ٱ
    б
    LabVIEW HALCONͼŽ̳̣25.08
    ʯλӾLabVIEW VisionͼPDF+Ƶ̳11ȫ
    LabVIEW Visionʵ2020-2024̳-NI Visionкʹ÷ܣNI VISION2020VDM21/22/23/24
    QQ|LabVIEWӾ |վͼ
    GMT+8, 2026-4-23 10:37
    ٻظ ض б
