NI-XNET 20.1 Driver Win32/64 Eng/Ger/Jpn NI-XNET仪器驱动程序20.1下载
NI-XNET
20.1
文件大小: 2236727296 字节 (2.08 GB)
修改日期: 2020-07-01 05:47
MD5: 5a0ed3e899bba18900cab0fc7568875f(官方正确)
SHA1: 2f2eb5770f96379ae4cd4e78cfad0f13222a8b8d
SHA256: 4bffc2cc461018f03bc3e4f7984274c8b1a7b3f874e6ce39053c861fe12117f2
CRC32: 8773d6dc
NI-XNET20.1.txt
(275 Bytes, 下载次数: 1, 售价: 10 圆)
NI-XNET 20.1 ReadmeMay 2020 This file contains important information about NI-XNET, including installation instructions and known issues. Overview Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates New Features and Changes Supported Hardware Known Issues Bug Fixes Additional Programming Topics Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 LabVIEW NXG Support and Considerations Legal Information OverviewNI-XNET is an NI instrument driver that features a common set of easy-to-use functions for reading and writing Automotive Ethernet, CAN, LIN, and FlexRay data on many different platforms including USB, PXI, PCI, NI CompactDAQ, and NI CompactRIO. Supported Operating SystemsNI-XNET supports the following operating systems: - Windows 10/8.11/7 SP12
- Windows Embedded Standard 7 SP12
- Windows Server 2016
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAEsupport. 1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. The NI-XNET installer does not support Windows Server 2003/NT/Vista/XP/Me/2000/98/95 or the Windows Server non-R2 editions. NI-XNET does not support guest accounts on Windows 7. You must log into an administrative or user account to use NI-XNET on these operating systems. PXI Automotive Ethernet Interface Modules (PXIe-8521, PXIe-8522, and PXIe-8523) do not support the Phar Lap ETS real-time operating system that installs with the LabVIEW Real-Time Module. NI-XNET Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021NI-XNET will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport. NI Software Drops Support for Phar Lap ETS Real-Time Operating System in 2022NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi. Application Software SupportThe following table lists the application software versions supported by NI-XNET. Application Software3 | Versions Supported by NI-XNET 20.1 | LabVIEW | 2017, 2018, 2019, and 2020 | LabVIEW Real-Time (RT) | 2017, 2018, 2019, and 2020 | LabVIEW NXG | 5.0 | LabWindows™/CVI™ | 2015 and later | | 3 Application software support for LabVIEW NXG is not included with NI-XNET and must be downloaded separately via NI Package Manager. Refer to Installing NI-XNET for LabVIEW NXG for instructions. | Microsoft Visual Studio SupportNI-XNET supports the following Microsoft Visual Studio versions and associated programming languages. Programming Languages | Versions Supported by NI-XNET 20.1 | Microsoft Visual C/C++ | Visual Studio 2003 or later | Installation InstructionsRefer to the following instructions to install NI-XNET from a DVD. To install NI-XNET for LabVIEW NXG, refer to Installing NI-XNET for LabVIEW NXG. Before installing the NI-XNET software, log on as Administrator or as a user with Administrator privileges. The NI-XNET software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-XNET software. - Insert the NI-XNET software DVD into the DVD drive. If the installer does not launch automatically, navigate to the DVD using Windows Explorer and launch the autorun.exe file from your NI-XNET software DVD.
- Click Install.
- The installation wizard guides you through the necessary steps to install the NI-XNET software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
- When the installation is complete, click Finish.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New Features and ChangesNew NI-XNET 20.1 Features and Changes as Compared to NI-XNET 20.0The NI-XNET 20.1 release adds the following features: - Added NI-XNET IP Stack, which improves support for TCP/IP-based protocols using Automotive Ethernet modules. NI-XNET IP Stack supports the following protocols and features:
- TCP, UDP
- IPv4, ARP, ICMPv4, IGMP
- Static and link-local IPv4 addressing
- IEEE 802.1Q tagged and non-tagged virtual interfaces
- Jumbo frames (gigabit Ethernet speeds only)
- Added new logging property Ethernet:Logging:Error? to XNET Session Node.
The NI-XNET 20.1 release changes the following: - Extended the Interrupt Moderation property to support the PXIe-8521 Automotive Ethernet module.
- Disabled the automatic import of all ARXML files contained within a folder. Instead, only the ARXML file specified by the user is imported.
New NI-XNET 20.0 Features and Changes as Compared to NI-XNET 19.6The NI-XNET 20.0 release adds the following features: - Added support for LabVIEW NXG 5.0.
- Added support for LabVIEW 2020.
- Added a System Configuration API property, Interrupt Moderation, for PXIe-8522 and PXIe-8523 Automotive Ethernet modules that can improve system performance.
The NI-XNET 20.0 release changes the following: - Removed support for LabVIEW 2016.
- Removed support for CVI 2013.
- Removed support for cRIO-9022, cRIO-9023, cRIO-9024, cRIO-9025, cRIO-9081, and cRIO-9082 controllers.
- Removed support for cRIO-9111, cRIO-9112, cRIO-9113, cRIO-9114, cRIO-9116, and cRIO-9118 chassis.
New NI-XNET 19.6 Features and Changes as Compared to NI-XNET 19.5The NI-XNET 19.6 release adds the following features: - Added support for jumbo frames with the PXIe-8522 and PXIe-8523 Automotive Ethernet modules.
- Added support for Ethernet Frame Filter property.
- Added support for Automotive Ethernet modules to use Wireshark to monitor Ethernet frames in real-time. (Supported in Windows only and tested with Wireshark 3.0.6.)
New NI-XNET 19.5 Features and Changes as Compared to NI-XNET 19.1The NI-XNET 19.5 release adds the following features: - Added support for LabVIEW NXG 4.0.
- Added support for sbRIO-9603, sbRIO-9608, sbRIO-9609, sbRIO-9628, sbRIO-9629, and sbRIO-9638 chassis.
- Added support for PXIe-8522 and PXIe-8523 Automotive Ethernet modules.
New NI-XNET 19.1 Features and Changes as Compared to NI-XNET 19.0The NI-XNET 19.1 release adds the following features: - Added support for PXI controllers running NI Linux Real-Time for NI-XNET PCI, PXI, PCIe, PXIe, and C Series devices4.
- Added support for network time synchronization with the PXIe-8521 while in Tap mode.
- Added support for the PXIe-8521 in LabVIEW NXG 3.1.
4C Series devices are supported only when used in a supported CompactDAQ chassis. New NI-XNET 19.0 Features and Changes as Compared to NI-XNET 18.5The NI-XNET 19.0 release adds the following features: - Added support for LabVIEW 2019.
- Added support for the PXIe-8521 4-port, 100BASE-T1 Automotive Ethernet Interface Module.
Note The PXIe-8521 does not support LabVIEW Real-Time or LabVIEW NXG in NI-XNET 19.0. The NI-XNET 19.0 release changes the following: - Extended the NI-XNET LabVIEW API to support Automotive Ethernet.
- Removed support for LabVIEW 2015.
- Removed support for NI-XNET C series modules in a cDAQ chassis when attached to a controller or host running Phar Lap. Support for other Operating Systems remains unaffected.
- Removed support for cRIO-9012 and cRIO-9014 controllers. Note that these targets may still support installation, but they are no longer officially supported, and may be removed in a future release.
- Changed behavior for Signal Input Waveform sessions to address defects.
- Changed options for building LabVIEW or CVI application installers: "NI-XNET Runtime" installs only the NI-XNET Runtime, "NI-XNET Utilities" installs the NI-XNET Database Editor and Bus Monitor in addition to the NI-XNET Runtime.
New NI-XNET 18.5 Features and Changes as Compared to NI-XNET 18.0The NI-XNET 18.5 release adds the following features: - Added support for LabVIEW NXG 3.0.
- Added support for LabVIEW 2018 SP1.
- Added support for the USB-8501 NI-XNET CAN LS/FT Interface.
- Added support for importing CAN FD settings from FIBEX 4.1.2 databases.
- Added support for J1939 session property, SAE J1939:Include Destination Address in PGN, in LabVIEW NXG.
The NI-XNET 18.5 release changes the following: - Lowered the default value for the nxPropSession_J1939ResponseTimeTrSD property from 0.05 s to 0 s to improve performance in handling multipacket messages.
- Improved performance when opening large database files.
- Removed support for LabVIEW NXG 2.0 and 2.1.
New NI-XNET 18.0 Features and Changes as Compared to NI-XNET 17.5.1The NI-XNET 18.0 release adds the following features: - Added ability in SystemDesigner to discover XNET hardware ports and select new names for them. (LabVIEW NXG)
- Added a new J1939 session property, SAE J1939:Include Destination Address in PGN. (C and LabVIEW 2018 only)
- Added support for LabVIEW NXG 2.1.
- Added support for LabVIEW 2018.
The NI-XNET 18.0 release changes the following: - Removed support for LabVIEW 2014.
New NI-XNET 17.5.1 Features and Changes as Compared to NI-XNET 17.5The NI-XNET 17.5.1 release changes the following: - Bug Fix for cDAQ-9171 support.
New NI-XNET 17.5 Features and Changes as Compared to NI-XNET 17.0.1The NI-XNET 17.5 release adds the following features: New NI-XNET 17.0.1 Features and Changes as Compared to NI-XNET 17.0The NI-XNET 17.0.1 release changes the following: - Bug Fix for LabVIEW 64-bit support.
New NI-XNET 17.0 Features and Changes as Compared to NI-XNET 16.1The NI-XNET 17.0 release adds the following features: The NI-XNET 17.0 release changes the following: - Improvements that require a firmware update for NI 9860 modules and the cDAQ integrated XNET port.
- Removed support for LabVIEW 2013.
- Removed support for CVI 2010.
Supported Hardware- USB-8501 Low-Speed/Fault Tolerant USB CAN Interface Device
- USB-8502 High-Speed/FD USB CAN Interface Device
- USB-8506 USB LIN Interface Device
- PCI-8511 Low‑Speed/Fault-Tolerant CAN Interface Device
- PCI-8512 High‑Speed/FD CAN Interface Device
- PCI-8513 Software‑Selectable/FD CAN Interface Device
- PCI-8516 PCI LIN Interface Device
- PCI-8517 FlexRay Interface Device
- PCIe-8510 PCIe Vehicle Multi-Protocol Interface Device
- PXI-8511 Low-Speed/Fault Tolerant PXI CAN Interface Module
- PXI-8512 High-Speed, Flexible Data Rate PXI CAN Interface Module
- PXI-8513 Software-Selectable PXI CAN Interface Module
- PXI-8516 PXI LIN Interface Module
- PXI-8517 PXI FlexRay Interface Module
- PXIe-8510 PXI Vehicle Multiprotocol Interface Module
- PXIe-8521 100BASE-T1 PXI Automotive Ethernet Interface Module
- PXIe-8522 1000BASE-T1 PXI Automotive Ethernet Interface Module
- PXIe-8523 100/1000BASE-T1 PXI Automotive Ethernet Interface Module
- TRC-8542 CAN HS/FD Transceiver Cable
- TRC-8543 CAN HS/FD or LS/FT Transceiver Cable
- TRC-8546 LIN Transceiver Cable
C Series modules: - NI 9860 C Series Vehicle Multiprotocol Interface Module
- NI 9861 Low-Speed/Fault Tolerant C Series CAN Interface Module
- NI 9862 High-Speed, Flexible Data Rate C Series CAN Interface Module
- NI 9866 C Series LIN Interface Module
Supported platforms for XNET C Series modules: - CompactDAQ—NI-DAQmx 17.1 (or later) is required for:
- USB Chassis: cDAQ-9171, cDAQ-9174, cDAQ-9178, and cDAQ-9179
- Ethernet Chassis: cDAQ-9181, cDAQ-9184, and cDAQ-9188
- Wireless Chassis: cDAQ-9191
- cDAQ Controller: cDAQ-9138 (Windows only) and cDAQ-9139 (Windows only)
- cDAQ Controller: cDAQ-9132 (Windows and RT) and cDAQ-9134 (Windows and RT)
- cDAQ Controller: cDAQ-9133 (Windows and RT) and cDAQ-9135 (Windows and RT)
- cDAQ Controller: cDAQ-9136 (Windows and RT) and cDAQ-9137 (Windows and RT)
- Ethernet Chassis: cDAQ-9185 and cDAQ-9189
- CompactRIO—CompactRIO 20.0 (or later) and LabVIEW 2017 (or later) are required for the following targets:
- Integrated CompactRIO Real-Time Controller: cRIO-906x, and cRIO-903x
- Single-Board RIO: sbRIO-9627, sbRIO-9607
- CompactRIO Real-Time Controller: cRIO-9032, cRIO-9037
- CompactRIO Real-Time Controller: cRIO-9035 (Sync), cRIO-9039 (Sync)
- When using a cRIO-903x or cRIO-906x, a bit stream is not needed with NI 986x modules in the project
- When using a cRIO-903x, cRIO-906x, or sbRIO-96x7, installation in the "Other" programming environment is not supported
- CompactRIO Real-Time Controller: cRIO-9040, cRIO-9042, cRIO-9043, cRIO-9045, cRIO-9047, cRIO-9048, and cRIO-9049
- When using a cRIO-904x, NI 986x modules will only be usable in Real-Time mode, and no bit stream is necessary
- CompactRIO—CompactRIO 20.0 (or later) and LabVIEW 2018 (or later) are required for the following targets:
- CompactRIO Real-Time Controller: cRIO-9053, cRIO-9054, cRIO-9056, and cRIO-9057
- When using a cRIO-905x, NI 986x modules will only be usable in Real-Time mode, and no bit stream is necessary
- CompactRIO—CompactRIO 20.0 (or later) and LabVIEW 2019 (or later) are required for the following targets:
- Single-Board RIO: sbRIO-9603, sbRIO-9608, sbRIO-9609, sbRIO-9628, sbRIO-9629, sbRIO-9638
- When using an sbRIO-9603, sbRIO-9608, sbRIO-9609, sbRIO-9628, sbRIO-9629, or sbRIO-9638, NI 986x modules will only be usable in Real-Time mode, and no bit stream is necessary
Note The NI-XNET software supports only National Instruments Automotive Ethernet, CAN, FlexRay, and LIN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products. Known IssuesYou can access the NI-XNET 20.1 known issues online at NI-XNET 20.1 Known Issues. Bug FixesYou can access the NI-XNET 20.1 bug fix list online at NI-XNET 20.1 Bug Fixes. This list describes a subset of issues fixed in this release. If you have a Bug ID, you can search this list to validate that the issue has been fixed. Additional Programming TopicsNI-CAN CompatibilityIf you intend to use the NI-CAN API with NI-XNET hardware, refer to the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual. Deployed databases on LabVIEW Real-Time targetsWhen upgrading the NI-XNET software on your LabVIEW Real-Time target, you need to re-deploy your database files to that target using a host computer that runs the same version of NI-XNET as the target. Removing and inserting C Series modules on CompactRIO targets during device communication is not supportedInserting a module into or removing a module from a cRIO chassis that is actively communicating with an NI 986x module can cause application failures and possibly device damage. This does not apply to controllers which support the NI-DAQmx programming method, such as the cRIO-904x family. RT Bus Monitor requires LabVIEW Real-TimeInstalling software to a Real-Time target using the "Other" programming environment will not run the RT Bus Monitor. To use this utility, select a "LabVIEW" or "LabVIEW NXG" programming environment. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. LabVIEW NXG Support and ConsiderationsThe following sections detail considerations for using NI-XNET with LabVIEW NXG. LabVIEW NXG Operating Systems and System RequirementsSoftware support for LabVIEW NXG differs in the following ways: - System requirements—Only 64-bit (x64) processors are supported.
- Operating system—Only 64-bit operating systems are supported. Refer to the Supported Operating Systems section for more information.
Installing NI-XNET for LabVIEW NXGLabVIEW NXG is installed using NI Package Manager. Complete the following steps to install NI-XNET for LabVIEW NXG. - Visit ni.com/info and enter the info code NXGDownload to access the LabVIEW NXG download page.
- Click Download LabVIEW NXG.
- NI Package Manager installs, and then automatically opens a download window.
- Select LabVIEW NXG Suite, and click the green Install button.
- Select LabVIEW NXG and NI-XNET.
- Complete the installer instructions to download LabVIEW NXG and NI-XNET.
LabVIEW NXG HelpView context help in LabVIEW by pressing and hovering over an object. Search for items using the search bar in the upper right corner of the LabVIEW window. You can also view context help for the search results. Additional documentation is available online at ni.com/manuals. LabVIEW NXG ExamplesLaunch LabVIEW and click the Learning tab. LabVIEW lessons are located in the Lessons tab, and LabVIEW Examples are located in the Examples tab. Follow the instructions in the lessons and examples. Legal InformationCopyright © 2009–2020 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 374802V-01 |
