查看: 3102|回复: 0
[NI驱动程序] NI-XNET 1.1 Driver Win32Eng/Ger/Jpn NI-XNET仪器驱动程序1.1下载
    3 小时前
    发表于 2020-10-20 22:26:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-XNET
    1.1
    文件大小: 327903470 字节 (312.71 MB)
    修改日期: 2019-06-25 02:42
    MD5: 9461be06f6d374cc1769955cd6bf0834
    SHA1: 2b3fe636a86cf576995372ffca0c2dd3fde9e8b9
    SHA256: 823c988305523a18b0117f192a6d215bc06c58a6f6f9892b1eba81249aad28d9
    CRC32: a5ff6a7a
    NI-XNET1.1.txt (277 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-XNET 1.1 Readme
    March 2010
    ni.com/xnet
    This file contains information about the NI-XNET software for Windows 7/Vista/XP and LabVIEW™ Real-Time (RT). Information in this file is organized in the following sections:
    • Documentation
    • Supported Platforms
    • Installing NI-XNET 1.1
    • New Features and Changes
    • Bug Fixes
    The XNET Software and Hardware Installation Guide included with the NI-XNET CD includes instructions for installing National Instruments hardware and software.
    The NI-XNET Hardware and Software Manual is the primary document for NI XNET products. This manual includes an introduction to CAN, FlexRay, and LIN, specifications for hardware, information about how to get started with application development, and a complete reference for all NI-XNET functions.
    The NI-XNET Hardware and Software Manual is in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at: www.adobe.com.
    Open the help from Start»All Programs»National Instruments»NI-XNET.
    Links to the NI-XNET Hardware and Software Manual are in the online help for each NI-XNET function within the National Instruments LabVIEW and LabWindows™/CVI™ development environments.
    Online help for the NI-XNET features within Measurement & Automation Explorer (MAX) is in the MAX Help Topics menu. The MAX Help Topics menu for NI-XNET also includes a link to the NI-XNET Hardware and Software Help.
    Back to Top
    Before installing the NI-XNET software, log on as Administrator or as a user with Administrator privileges. The NI-XNET software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-XNET software.
    • Insert the NI-XNET software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-XNET software CD.
    • The installation wizard guides you through the necessary steps to install the NI-XNET software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    Installing NI-XNET Silently
    You can programmatically control which features in the NI-XNET distribution to enable or disable for installation. You therefore can install a subset of the NI-XNET distribution silently. Refer to the template_spec.txt file in the Specfiles directory on the NI-XNET CD for more information about installing NI-XNET silently and selecting which features to install automatically.
    Back to Top
    You can install and run this version of the NI-XNET software on the following operating systems:
    • Windows XP (32-bit)
    The NI-XNET installer does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    Note:  National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. While most NI products work with Windows 7, NI has become aware of some compatibility issues regarding Windows 7. To learn how Windows 7 affects your use of NI products, visit ni.com/info and enter the info code windows7.
    Note:  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this may affect your use of Windows Server 2003 and what actions you may need to take, visit ni.com/info and enter the info code PAESupport.
    This version of the NI-XNET software supports the following National Instruments hardware products on Windows and LabVIEW RT:
    • NI PCI-8511 (Low-Speed/Fault-Tolerant CAN)
    • NI PCI-8512 (High-Speed CAN)
    • NI PCI-8513 (Software-Selectable HS/LS/SW CAN)
    • NI PCI-8516 (LIN)
    • NI PCI-8517 (FlexRay)
    • NI PXI-8511 (Low-Speed/Fault-Tolerant CAN)
    • NI PXI-8512 (High-Speed CAN)
    • NI PXI-8513 (Software-Selectable HS/LS/SW CAN)
    • NI PXI-8516 (LIN)
    • NI PXI-8517 (FlexRay)
    The NI-XNET software supports only National Instruments CAN, FlexRay, and LIN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    This version of the NI-XNET software supports the following development environments:
    • LabVIEW 8.5, 8.6, and LabVIEW 2009 (32-bit)
    • LabVIEW Real-Time (RT) 8.5, 8.6, and 2009
    • LabWindows/CVI 8.5 and higher
    • Microsoft Visual C/C++ 6.0
    Back to Top
    New Features and Changes as Compared to NI-XNET 1.0.
    The NI-XNET 1.1 release adds the following features:
    • New feature: Support for PCI-8516 and PXI-8516 (LIN bus interface).
    • New feature: Replay mode (CAN only. Refer to the Interface:Output Stream Timing, Interface:Output Stream List, and Interface:CAN:Output Stream List By ID properties.)
    • New feature: Cyclic frame spacing (CAN only. Refer to the Frame:CAN:Start Time Offset property.)
    • New feature: Frame level fault insertion (CAN only: Change the period during runtime. Refer to the Frame:CAN:Transmit Time property. CAN only: Skip N transmissions of a cyclic frame. Refer to the Frame:Skip N Cyclic Frames property.)
    • New feature: Frame reordering (CAN only. Refer to the Interface:CAN:Pending Transmit Order property.)
    • New feature: LabVIEW Real-Time support on desktop PC real-time systems.
    The NI-XNET 1.1 release changes the following behavior:
    • In the NI-XNET 1.0, you could connect one NI-XNET class to a different NI-XNET class (for example, you could wire an NI-XNET frame to a property node of an NI-XNET signal). This class mismatch in NI-XNET 1.0 usually was detected at runtime only. In LabVIEW 2009, NI-XNET 1.1 shows this as a broken wire at edit time.
    Back to Top
    The following items are the IDs and titles of a subset of issues fixed between NI-XNET 1.0 and NI-XNET 1.1. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-XNET.
    Bug IDFixed Issue
    195809NI-XNET Compatibility Library for NI-CAN: ncConfig/ncOpenObject/ncCloseObject functions leak memory and handles.
    194073NI-XNET Compatibility Library for NI-CAN: Notifications cannot be rearmed without disabling them first.
    192007Read timestamp function may return a timestamp that is off by about 7 minutes.
    181246NI-XNET Compatibility Library for NI-CAN: The nctInitialize function and the CAN Init VI do not use the baud rate of a currently running interface.
    180542NI-XNET Compatibility Library for NI-CAN: ncConfig called with same parameters on open of CAN objects returns an error.
    193647NI-XNET Compatibility Library for NI-CAN: Added code to avoid hanging ncCreateNotification() when attempting to disarm a pending notification.
    206461NI-XNET Compatibility Library for NI-CAN: Added code to avoid hanging ncCreateNotification() when attempting to close an object with a pending notification.
    186551Losing arbitration while in Single Shot Transmit mode may cause a session to stop sending frames.
    Back to Top
    Additional Programming TopicsNI-CAN Compatibility
    If you intend to use the NI-CAN API with your NI-XNET hardware, refer to the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual.
    Back to Top
    Copyright 2009–2010 National Instruments. All rights reserved.
    CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    GMT+8, 2026-4-23 11:01
