查看: 3357|回复: 0
[NI驱动程序] NI-DCPower Driver 18.0 Win32/64Eng NI DC电源仪器驱动程序下载18.0
    2 小时前
    发表于 2020-10-18 23:10:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    18.0
    文件大小: 2009063025 字节 (1.87 GB)
    修改日期: 2018-05-01 23:55
    MD5: 390aad48c177df944a9759d1e5782bff(官方正确)
    SHA1: 4938999de5b04f5e52e467fa3b9dab8592b25dcc
    SHA256: 756a9e92a3d8afc42da9de4df9da96c0d2f2dec9abd5c227946da5a6f9a3542e
    CRC32: b2cdd590
    DCPower18.0.txt (263 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-DCPower 18.0 Readme
    March 2018
    This file contains important information about NI-DCPower, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    NI-DCPower is an NI instrument driver that communicates with all NI programmable power supplies and SMUs. NI-DCPower is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the power supply or SMU and includes an interactive soft front panel and examples.
    NI-DCPower 18.0 has the following requirements:
    Minimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DCPower 18.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-DCPower dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DCPower 18.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DCPower 18.0 to an unsupported OS. Additionally, after installing NI-DCPower 18.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-DCPower 18.0 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-DCPower
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW Real-Time Module32015, 2016, 2017, 2018
    LabVIEW NXG2.0, 2.1
    LabWindows™/CVI™2013 and later
    LabWindows/CVI Real-Time Module32013 and later
    3No support for PXIe-4162/4163 source measure units.
    If you are using the NI-DCPower .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DCPower .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    Installation InstructionsInstalling NI-DCPower 18.0 for LabVIEW
    You can install all of your LabVIEW products—including NI-DCPower 18.0—using the LabVIEW 2018 Platform media.
    Note
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/info and enter the Info Code exjq43 for more information and steps to resolve this issue.
    Installing NI-DCPower 18.0 for LabVIEW NXG
    • NI-DCPower 18.0 adds support for LabVIEW 2018 and LabVIEW NXG 2.1.
    • NI-DCPower 18.0 adds support for .NET Framework 4.0 and .NET Framework 4.5.
    The following list details the hardware models supported in NI-DCPower 18.0:
    NI 411x, 413x, 414x, and 4154 Power Supplies and SMUs
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    NI 416x SMUs
    • PXIe-4162
    • PXIe-4163
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-DCPower 18.0.
    The following items are the IDs and titles of a subset of issues fixed in NI-DCPower. This is not an exhaustive list of issues fixed in the current version of NI-DCPower. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-DCPower 17.6.1 from NI-DCPower 17.6.
    672829Fixed an issue in which the PXIe-4162/4163 did not invalidate measurements taken during range changes.
    621134Fixed an issue in which memory leaked when configuring properties in the Running state.
    The following items are changes in NI-DCPower 17.1 from NI-DCPower 17.0.
    671016Fixed an issue in which the PXIe-4138 or PXIe-4139 failed to load upon system boot or device reset.
    647700Fixed an issue in which in rare cases, the PXI-4138 or PXIe-4139 failed to load due to a hardware error but the front panel LED did not reflect the presence of a hardware error.
    Refer to the NI DC Power Supplies and SMUs Help, accessible from Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Documentation, for information about NI-DCPower.
    You can access all the installed NI-DCPower examples at Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DCPower are located in the LabVIEW XXXX\examples\instr\niDCPower directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    • Click the Search tab to search all installed examples by keyword. For example, search for "DCPower" to locate all NI-DCPower examples.
    The following sections detail considerations for using LabVIEW NXG with NI-DCPower.
    LabVIEW NXG Hardware Support
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    NI 416x SMUs
    • PXIe-4162
    • PXIe-4163
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-DCPower no longer installs IVI Compliance Package. NI-DCPower supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    © 2007–2018 National Instruments. All rights reserved.
    375374J-01
    GMT+8, 2026-4-23 10:50
