查看: 3463|回复: 0
[NI驱动程序] NI-DCPower Driver 17.6.1f1 Win32/64Eng NI DC电源仪器驱动程序下载17.6.1f1
    2 小时前
    发表于 2020-10-18 23:08:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    17.6.1f1
    文件大小: 1924431752 字节 (1.79 GB)
    修改日期: 2018-03-06 05:51
    MD5: fd3d0e5f4cfeacab211fe37c56f0d7d4(官方正确)
    SHA1: db9d969e4af6be6dc6c30208e6e838668ec957fe
    SHA256: 4f7efe4c08d70212de535c42fde4d54c4f14c31797cf565a686ac683d80e75e1
    CRC32: 64c5f540
    DCPower17.6.1.txt (267 Bytes, 下载次数: 2, 售价: 10 圆)
    NI-DCPower 17.6.1 Readme
    January 2018
    This file contains important information about NI-DCPower, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    NI-DCPower is an NI instrument driver that communicates with all NI programmable power supplies and SMUs. NI-DCPower is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the power supply or SMU and includes an interactive soft front panel and examples.
    NI-DCPower 17.6.1 has the following requirements:
    Minimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DCPower 17.6.1 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-DCPower dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DCPower 17.6.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DCPower 17.6.1 to an unsupported OS. Additionally, after installing NI-DCPower 17.6.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Server 2003?.
    NI-DCPower 17.6.1 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-DCPower
    LabVIEW2014 SP1, 2015 SP1, 2016, 2017
    LabVIEW Real-Time Module32014 SP1, 2015 SP1, 2016, 2017
    LabVIEW NXG2.0
    LabWindows™/CVI™2013 and later
    LabWindows/CVI Real-Time Module32013 and later
    3No support for PXIe-4162/4163 source measure units.
    If you are using the NI-DCPower .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DCPower .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    • NI-DCPower 17.6.1 adds support for asymmetric compliance limits for PXIe-4135/4136/4137/4138/4139 and PXIe-414x source measure units.
    • NI-DCPower 17.6 adds support for the PXIe-4162 and PXIe-4163 source measure units.
    The following list details the hardware models supported in NI-DCPower 17.6.1:
    NI 411x, 413x, 414x, and 4154 Power Supplies and SMUs
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    NI 416x SMUs
    • PXIe-4162
    • PXIe-4163
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-DCPower 17.6.1.
    The following items are the IDs and titles of a subset of issues fixed in NI-DCPower. This is not an exhaustive list of issues fixed in the current version of NI-DCPower. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-DCPower 17.6.1 from NI-DCPower 17.6.
    672829Fixed an issue in which the PXIe-4162/4163 did not invalidate measurements taken during range changes.
    621134Fixed an issue in which memory leaked when configuring properties in the Running state.
    The following items are changes in NI-DCPower 17.1 from NI-DCPower 17.0.
    671016Fixed an issue in which the PXIe-4138 or PXIe-4139 failed to load upon system boot or device reset.
    647700Fixed an issue in which in rare cases, the PXI-4138 or PXIe-4139 failed to load due to a hardware error but the front panel LED did not reflect the presence of a hardware error.
    Refer to the NI DC Power Supplies and SMUs Help, accessible from Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Documentation, for information about NI-DCPower.
    You can access all the installed NI-DCPower examples at Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DCPower are located in the LabVIEW XXXX\examples\instr\niDCPower directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    • Click the Search tab to search all installed examples by keyword. For example, search for "DCPower" to locate all NI-DCPower examples.
    The following sections detail considerations for using LabVIEW NXG with NI-DCPower.
    LabVIEW NXG Hardware Support
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    NI 416x SMUs
    • PXIe-4162
    • PXIe-4163
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-DCPower no longer installs IVI Compliance Package. NI-DCPower supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD.
    © 2007–2018 National Instruments. All rights reserved.
    375374H-01
    GMT+8, 2026-4-23 10:49
