查看: 2913|回复: 0
[NI驱动程序] NI-DCPower Driver 17.1 Win32/64Eng NI DC电源仪器驱动程序下载17.1
    2 小时前
    发表于 2020-10-18 23:01:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    17.1
    文件大小: 1819438984 字节 (1.69 GB)
    修改日期: 2017-12-07 07:31
    MD5: 63ea02efa2632ae51c4f4377afa588ed(官方正确)
    SHA1: b18ca2efcf1cd29c161a838c455a8d51c2eef1bf
    SHA256: 77e925a941834aae6cc667d0ccd52ed823fe3bbe33de3ac08f8dacac5cb65cce
    CRC32: f99e974a
    DCPower17.1.txt (263 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower 17.1 Readme
    July 2017
    This file contains important information about NI-DCPower, including installation instructions, new features, a partial list of bugs fixed for NI-DCPower 17.1, and known issues.
    NI-DCPower is an NI instrument driver that communicates with all NI programmable power supplies and SMUs. NI-DCPower is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the power supply or SMU and includes an interactive soft front panel and examples.
    System RequirementsMinimum System Requirements
    Recommended System
    • RAM—Windows 10/8.1/8.0/7: 1 GB
    NI-DCPower supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-DCPower dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DCPower 17.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DCPower 17.1 to an unsupported OS. Additionally, after installing NI-DCPower 17.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-DCPower supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-DCPower
    LabVIEW2014 SP1 (32-bit), 2014 SP1 (64-bit), 2015 SP1 (32-bit), 2015 SP1 (64-bit), 2016 (32-bit), 2016 (64-bit), or 2017
    LabVIEW Real-Time Module2014 SP1, 2015 SP1, 2016, or 2017
    LabWindows™/CVI™2012 and later
    LabWindows/CVI Real-Time Module2012 and later
    If you are using the NI-DCPower .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DCPower .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    NI-DCPower 17.0:
    • Support for LabVIEW 2017 (32- and 64-bit)
    • Support for LabVIEW NXG 1.0
    NI-DCPower 16.0.1:
    • New NI-DCPower Soft Front Panel
    NI-DCPower 16.0:
    NI-DCPower 15.2:
    • Support for the PXIe-4135
    NI-DCPower 15.1:
    • Support for the PXIe-4136/4137
    • Support for advanced sequencing for PXIe-4140/4141/4142/4143/4144/4145 devices
    NI-DCPower 15.0:
    NI-DCPower 14.1:
    • Support for advanced sequencing for the NI PXIe-4138/4139
    • Support for debugging an NI-DCPower device while in use by another application, by monitoring or controlling the device in the NI-DCPower Soft Front Panel
    NI-DCPower 14.0:
    • Support for LabVIEW 2014 (32- and 64-bit)
    The following list details the hardware models supported in NI-DCPower 17.1.
    PXI Programmable Power Supply
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    PXI Source Measure Unit
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-DCPower 17.1.
    The following items are the IDs and titles of a subset of issues fixed in NI-DCPower. This is not an exhaustive list of issues fixed in the current version of NI-DCPower. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-DCPower 15.2 from NI-DCPower 15.1.
    522999Added support for monitoring SFP Debug Driver Sessions when sequencing.
    The following items are changes in NI-DCPower 14.1.2 from NI-DCPower 14.1.1.
    519695Fixed an issue in which NI-DCPower Self Calibrate could cause a voltage and current measurement offset on the PXIe-4138/4139.
    The following items are changes in NI-DCPower 14.1.1 from NI-DCPower 14.1.
    501023A hardware error in an NI-DCPower device no longer causes other devices in the system to fail to initialize properly.
    The following items are changes in NI-DCPower 14.1 from NI-DCPower 1.9.
    450955Running short sequences (three or fewer steps) or quickly aborting a sequence no longer occasionally returns an error.
    405305Fixed an issue with the PXIe-414x in which calling the niDCPower Configure Output Enabled VI after outputting a sequence of currents returned an error if you set nondefault current ranges. You can now set nondefault current ranges under these circumstances.
    Refer to the NI DC Power Supplies and SMUs Help, accessible from the Start menu under National Instruments and NI-DCPower Documentation, for information about NI-DCPower.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–DCPower examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–DCPower examples) and their descriptions:
    • Click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    • Click the Search tab to search all installed examples by keyword. For example, search for "DCPower" to locate all NI-DCPower examples.
    You can also access all the installed NI–DCPower examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-DCPower»Examples .
    Examples also are available online that demonstrate NI-DCPower functionality. Refer to ni.com/examples for these examples and for more information.
    NI-DCPower no longer installs IVI Compliance Package. NI-DCPower supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD.
    The following sections detail considerations for using LabVIEW NXG with NI-DCPower.
    LabVIEW NXG Hardware Support
    411x, 4113x, 414x, and 4154 Devices
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    Installing NI-DCPower for LabVIEW NXG
    NI automates LabVIEW NXG installation using a package manager. Complete the following steps to install NI-DCPower for LabVIEW NXG.
    • Visit ni.com/info and enter the info code NXGDownload to access the LabVIEW NXG download page.
    • Click Download LabVIEW NXG 1.0.
    • NI Package Manager installs, then automatically opens a download window.
    • Select LabVIEW NXG Suite and click the green Install button.
    • Select LabVIEW NXG 1.0 and NI-DCPower.
    • Complete the installer instructions to download LabVIEW NXG 1.0 and NI-DCPower.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 2007–2017 National Instruments. All rights reserved.
    375374E-01
    GMT+8, 2026-4-23 10:49
