查看: 3917|回复: 0
[NI驱动程序] NI-DCPower Driver 1.8.6 Win32/64Eng NI DC电源仪器驱动程序下载1.8.6
    2 小时前
    发表于 2020-10-17 00:18:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    1.8.6
    文件名: DC-Power\NIDCPWR186.exe
    文件大小: 1651258144 字节 (1.54 GB)
    修改日期: 2013-10-19 00:25
    MD5: 9a535457ce4ca0d0ae7a2f4f792860f1(官方正确)
    SHA1: b9a70a81976bf6cd48b2659589e6ec51b9cba8a3
    SHA256: 7e81271293020490fc0ef32f0de2097030e2a31a848ffe134c369e927c33f961
    CRC32: 605fbbb4
    DCPower1.8.6.txt (263 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower Readme
    2013
    Version 1.8.6
    Thank you for using NI-DCPower. This file contains important information about NI-DCPower and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Updates and Notifications
    • Uninstalling/Modifying NI-DCPower
    • Known Issues
    • Bug Fixes
    • How to Use NI Software with Microsoft Windows 8
    • Important Information
    NI-DCPower 1.8.5 includes the following new features:
    • Support added for LabVIEW 2013 (32-bit) and LabVIEW 2013 (64-bit)
    • Support removed for LabVIEW 2009
    NI-DCPower 1.8 includes the following new features:
    • Support for the NI PXIe-4112/4113
    • Support for self-calibration of the NI PXI-4132
    NI-DCPower 1.7.5 includes the following new features:
    • Support for the NI PXIe-4144/4145
    • Support added for LabVIEW 2012 (32-bit) and LabVIEW 2012 (64-bit)
    • Support removed for LabVIEW 8.6.1
    NI-DCPower 1.7 includes the following new features:
    • Support for the NI PXIe-4142/4143
    • Support for NI-DCPower run-time custom installers built using National Instruments application development environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using NI DC Power Supplies and SMUs.
      Notes:
      • The run-time installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX).
      • The run-time installer does not support upgrading from NI-DCPower 1.6.x or earlier or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-DCPower Run-Time installer.
    NI-DCPower 1.6.2 improves multi-device performance on multi-core systems.
    NI-DCPower 1.6.1 includes the following new features:
    • Support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit)
    • Support removed for LabVIEW 8.5.1
    NI-DCPower 1.6 includes the following new features:
    • Support for NI PXIe-4140/4141
    • Support for new signal routes added to the NI PXI-4132 (Source Complete event to Measure trigger) and the NI PXIe-4140/4141/4154 (Measure trigger to Source trigger, Source trigger to Measure trigger, and Source Complete event to Measure trigger)
    NI-DCPower 1.8.6 and later supports the following power supply and source-measure units (SMUs):
    • NI PXI-4110
    • NI PXIe-4112
    • NI PXIe-4113
    • NI PXI-4130
    • NI PXI-4132
    • NI PXIe-4140
    • NI PXIe-4141
    • NI PXIe-4142
    • NI PXIe-4143
    • NI PXIe-4144
    • NI PXIe-4145
    • NI PXIe-4154
    Note  MXI Express and MXI-4 are supported on Windows 8/7/Vista/XP, but MXI-3 is supported on only Windows XP.
    Device-specific information about these modules is included in the NI DC Power Supplies and SMUs Help.
    NI-DCPower 1.8.6 and later supports the following operating systems:
    Note  NI-DCPower 1.8.6 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-DCPower 1.4 or earlier.
    NI-DCPower 1.8.6 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP Service Pack 3 (SP3): 128 MB
      • Windows 8/7/Vista: 512 MB
    • Windows 8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP SP3: 256 MB
      • Windows 8/7/Vista: 1 GB
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-DCPower. To add support for ADEs installed after installing NI-DCPower, modify your NI-DCPower installation or launch the NI-DCPower installer again.
    • 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), 2012 SP1 (64-bit), 2013 (32-bit), or 2013 (64-bit)
    • LabVIEW Real-Time Module 2010 SP1, 2011 SP1, 2012 SP1, or 2013
    • LabWindows™/CVI™ 2009 or later
    • LabWindows/CVI Real-Time Module 2010 or later
    • If you are running your application on an RT target, 128 MB of memory or more is required.
    Installed File Names and LocationsSoftware
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 8/7/Vista: Users\Public\Documents\National Instruments
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    NI-DCPower\Drivers\niDCPower
    NI-DCPower Function Panel\Drivers\niDCPower\niDCPower.fp
    NI-DCPower Examples\niDCPower\Examples
    NI-DCPower Header files\Include
    NI-DCPower Import Library files (32-bit)\Lib
    NI-DCPower Import Library files (64-bit)\Lib_x64
    NI-DCPower DLL (32-bit)\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-DCPower DLL (64-bit)\Bin
    Documentation is available at Start»All Programs»National Instruments»NI-DCPower»Documentation. The documentation set is composed of the following documents:
    • NI-DCPower Readme
    • NI DC Power Supplies and SMUs Getting Started Guide—Printed and PDF format. Contains hardware and software installation, MAX configuration, and signal connection information.
    • NI DC Power Supplies and SMUs Help—HTML help format. Contains power supply fundamentals, hardware device overview, programming information, LabVIEW reference, and C/CVI/VB reference sections.
    • NI DC Power Supplies and SMUs Specifications—Printed and PDF format. Lists specifications for NI DC Power Supplies and SMUs.
    • NI DC Power Supplies and SMUs Calibration Procedures—PDF format. Contains calibration instructions for NI DC Power Supplies and SMUs.
    • Maintain Forced-Air Cooling Note to Users—Printed format. Contains important cooling information for NI DC power supplies and SMUs.
    • Read Me First: Safety and Electromagnetic Compatibility—Printed format. Contains safety instructions and electromagnetic compatibility (EMC) information for the hardware it accompanies.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Examples
    Refer to Start»All Programs»National Instruments»NI-DCPower»Examples for the examples for the supported ADEs.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    NI-DCPower Updates and Notifications
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    Perform the following procedure to uninstall NI-DCPower 1.8.6:
    • Launch the Control Panel by selecting Start»Settings.
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-DCPower 1.8.6 from the dialog box that appears.
    For Windows 8, complete the following steps:
    • Click the Uninstall button.
    As part of the NI-DCPower installation, the following software is installed. To completely remove the NI-DCPower installation from your system, you must also remove all of the following packages.
    • NI-DCPower Run-Time 1.8.6
    • NI IVI Compliance Package 4.4
    • NI Measurement & Automation Explorer 5.4
    • NI-DAQmx 9.1.7
    • NI-VISA Runtime 5.0
    • NI Spy 2.7.2
    You can access the software and documentation known issues list online. Refer to the NI-DCPower 1.8 and 1.8.5 Known Issues List web page on the National Instruments Web site for an up-to-date list of known issues in NI-DCPower 1.8.6.
    The following items are changes in NI-DCPower 1.8 from NI-DCPower 1.7.5.
    286821Fixed an issue in which you must run LabWindows/CVI with elevated privileges to successfully launch the NI-DCPower Simultaneous Update example from LabWindows/CVI. NI has renamed this example to NI-DCPower Simultaneous Operation, and you no longer need to run LabWindows/CVI with elevated privileges to launch this example.
    371368Fixed an issue in which temperature changes degraded the output accuracy on the NI PXI-4132. You can now self-calibrate the NI PXI-4132 to maintain output accuracy.
    The following items are changes in NI-DCPower 1.7.5 from NI-DCPower 1.7.
    369565In a few rare cases, when users wrote to nonvolatile storage on the NI PXIe-4140/4141/4142/4143, calibration constants became invalid, causing the device to become unusable until its next external calibration. Now you can write to nonvolatile storage on the NI PXIe-4140/4141/4142/4143 without issue.
    The following items are changes in NI-DCPower 1.7 from NI-DCPower 1.6.3.
    352628The first measurement taken after opening a new session for the NI PXI-4132 no longer has the potential to be incorrect.
    347012Configuring the niDCPower Output Connected property to TRUE or the NIDCPOWER_ATTR_OUTPUT_CONNECTED attribute to VI_TRUE while in the Running state no longer incorrectly configures the NI PXI-4132 for remote sense.
    346464In SignalExpress, using the NI-DCPower Generate step while sweeping no longer sources only the first point in the sequence.
    346154LabVIEW code generated in SignalExpress from the NI-DCPower Generate step no longer returns an error when run while sweeping.
    342622,
    341027
    The performance of the NI PXIe-4140/4141 range change algorithm is improved.
    328629When configuring the device in the Committed state in Single Point source mode after a property or attribute is configured in the Running state, the incorrect previous property or attribute value is no longer retained.
    283258Previously, the Measure Record Length property or NIDCPOWER_ATTR_MEASURE_RECORD_LENGTH attribute permitted a measurement record to be composed of up to 231-1 measurements, but the driver and hardware would silently ignore a measurement record composed of more than 224 measurements. The driver now returns an error if you attempt to compose a measurement record of more than 224 measurements. This change in behavior may change how existing code is executed.
    318481The NI PXI-4132 output disabled current limit is now 2% of the current limit range, as intended.
    The following items are changes in NI-DCPower 1.6.3 from NI-DCPower 1.6.2.
    323968Aborting an operation no longer has the potential to cause transient output behavior on subsequent configurations of the NI PXI-4132 or NI PXIe-4140/4141.
    The following items are changes in NI-DCPower 1.6 from NI-DCPower 1.5.
    283254Warning 1073364993 is now returned instead of error -1074118605 if a measurement is taken while the device is performing a range change.
    The following items are changes in NI-DCPower 1.5 from NI-DCPower 1.4.
    217333The source delay attribute will be coerced to a minimum of 30μs on the NI PXI-4132.
    178242When handshaking on the NI PXI-4132 with other devices using the source trigger and measure complete event, the source trigger will no longer be missed.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI-DCPower Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments NI-DCPower will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-DCPower that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2007–2013 National Instruments. All rights reserved.
    GMT+8, 2026-4-23 10:49
