查看: 3576|回复: 0
[NI驱动程序] NI-DCPower Driver 1.6.1 Win32/64Eng NI DC电源仪器驱动程序下载1.6.1
    2 小时前
    发表于 2020-10-16 23:55:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    1.6.1
    文件大小: 1476447778 字节 (1.38 GB)
    修改日期: 2011-10-28 06:40
    MD5: f9255f20948b834b31b58a56808529d7(官方正确)
    SHA1: 60ef8e7b9812b3e9acf4eec8f0b20b9189006e48
    SHA256: 476040e9995ea423152f6643e56fdb0838e04240590fef25e7fa0269e056d8fe
    CRC32: c5b7b861
    DCPower1.6.1.txt (261 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower Readme
    Version 1.6.1
    Thank you for using NI-DCPower. This file contains important information about NI-DCPower and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Uninstalling/Modifying NI-DCPower
    • Known Issues
    • Bug Fixes
    New Features in Version 1.6.1
    • Support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit)
    • Support removed for LabVIEW 8.5.1
    • Support for NI PXIe-4140/4141
    • Support for new signal routes added to the NI PXI-4132 (Source Complete event to Measure trigger) and the NI PXIe-4140/4141/4154 (Measure trigger to Source trigger, Source trigger to Measure trigger, and Source Complete event to Measure trigger)
    New Features in Version 1.5
    • Support for NI PXIe-4154
    • Support for channel-based sessions
    • Support for measure records
    • The NI PXI-4132 now supports streaming sequences, allowing the size of a sequence to be virtually unlimited.
    New Features in Version 1.4.1
    • Support for LabVIEW 2010 (32-bit and 64-bit)
    • Support removed for LabVIEW 8.2.1
    • Support for LabVIEW 2009 (64-bit)
    • Support for NI PXI-4132
    • Support for 64-bit user mode
    New Features in Version 1.3.1
    • Support for LabVIEW 2009 (32-bit)
    • Support removed for LabVIEW 7.1.1
    • Japanese localization for driver, LabVIEW application programming interface (API), and documentation
    • New behavior: Error and self-test message strings now return localized values in LabVIEW. User applications that check the value of these strings (or trap errors by comparing the error cluster) may experience a change in behavior.
    NI-DCPower 1.6.1 and later supports the following power supply and source-measure units (SMUs):
    • NI PXI-4110
    • NI PXI-4130
    • NI PXI-4132
    • NI PXIe-4140
    • NI PXIe-4141
    • NI PXIe-4154
    Note  MXI Express and MXI-4 are supported on Windows 7/Vista/XP, but MXI-3 is supported on only Windows XP.
    NI-DCPower 1.6.1 and later supports the following operating systems:
    • Windows XP Service Pack 2 (32-bit)
    Note  NI-DCPower 1.6.1 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-DCPower 1.4 or earlier.
    NI-DCPower 1.6.1 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System
    • RAM
      • Windows XP: 128 MB
      • Windows 7/Vista: 512 MB
    • Windows 7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM
      • Windows XP: 256 MB
      • Windows 7/Vista: 1 GB
    • If you are running your application on an RT target, 64 MB of memory or more is recommended.
    • LabVIEW 8.6.1, 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 (32-bit), or 2011 (64-bit)
    • LabVIEW Real-Time Module 8.6.1, 2009 SP1, 2010 SP1, or 2011
    • LabWindows™/CVI™ 8.5.1 or later
    • LabWindows/CVI Real-Time Module 9.0 or later
    Installed File Names and LocationsSoftware
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 7/Vista: Users\Public\Documents\National Instruments
      • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 7/Vista/XP
    NI-DCPower\Drivers\niDCPower
    NI-DCPower Function Panel\Drivers\niDCPower\niDCPower.fp
    NI-DCPower Examples\niDCPower\Examples
    NI-DCPower Header files\Include
    NI-DCPower Import Library files (32-bit)\Lib
    NI-DCPower Import Library files (64-bit)\Lib_x64
    NI-DCPower DLL (32-bit)\Bin
    Additional File Locations for Windows 7/Vista 64-bit
    ItemInstalled Location on Windows 7/Vista 64-bit
    NI-DCPower DLL (64-bit)\Bin
    Documentation is available at Start»All Programs»National Instruments»NI-DCPower»Documentation. The documentation set is composed of the following documents:
    • NI-DCPower Readme
    • NI DC Power Supplies and SMUs Getting Started Guide
      • Printed and PDF format. Contains hardware and software installation, MAX configuration, and signal connection information.
    • NI DC Power Supplies and SMUs Help
      • HTML help format. Contains power supply fundamentals, hardware device overview, programming information, LabVIEW reference, and C/CVI/VB reference sections.
    • NI DC Power Supplies and SMUs Specifications
      • Printed and PDF format. Lists specifications for NI DC Power Supplies and SMUs.
    • NI DC Power Supplies and SMUs Calibration Procedures
      • PDF format. Contains calibration instructions for NI DC Power Supplies and SMUs.
    • Maintain Forced-Air Cooling Note to Users
      • Printed format. Contains important cooling information for NI DC power supplies and SMUs.
    • Read Me First: Safety and Electromagnetic Compatibility
      • Printed format. Contains safety instructions and electromagnetic compatibility (EMC) information for the hardware it accompanies.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Examples
    Refer to Start»All Programs»National Instruments»NI-DCPower»Examples for the examples for the supported ADEs.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    • Launch the Control Panel by selecting Start»Settings.
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-DCPower 1.6.1 from the dialog box that appears.
    As part of the NI-DCPower installation, the following list of software was installed. To completely remove NI-DCPower from your system, you must remove all of these packages also.
    • NI IVI Compliance Package 4.4
    • NI Measurement & Automation Explorer 5.0
    • NI-DAQmx 9.1.7
    • NI-VISA 5.0
    • NI Spy 2.7.2
    You can access the software and documentation known issues list online. Refer to the NI-DCPower 1.6.1 Known Issues List web page on the National Instruments Web site for an up-to-date list of known issues in NI-DCPower 1.6.1.
    The following items are changes in NI-DCPower 1.6 from NI-DCPower 1.5.
    283254Warning 1073364993 is now returned instead of error -1074118605 if a measurement is taken while the device is performing a range change.
    The following items are changes in NI-DCPower 1.5 from NI-DCPower 1.4.
    217333The source delay attribute will be coerced to a minimum of 30μs on the NI PXI-4132.
    178242When handshaking on the NI PXI-4132 with other devices using the source trigger and measure complete event, the source trigger will no longer be missed.
    Using Microsoft Silverlight
    © 2007–2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-23 10:46
