查看: 3072|回复: 0
[NI驱动程序] NI-DCPower Driver 1.1 Win32/64Eng NI DC电源仪器驱动程序下载1.1
    2 小时前
    发表于 2020-10-16 23:35:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    1.1
    文件大小: 562946291 字节 (536.87 MB)
    修改日期: 2010-04-25 04:00
    MD5: f8dd366ea9f11f962902c52fff6773e0(官方正确)
    SHA1: bdd566f96c095742a954c5b46bcab8b6caf1fa09
    SHA256: a8e93a1793089e7a532d02cd64164eba2419a36659e96ef1934478a447badc2f
    CRC32: 455bf346
    DCPower1.1.txt (260 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower Readme
    National Instruments™, NI™, ni.com™ and LabVIEW™ are trademarks of National Instruments Corporation. Product and company names mentioned herein are trademarks or trade names of their respective companies.
    © Copyright 2006 National Instruments Corporation. All rights reserved.
    Version 1.1
    Thank you for using NI-DCPower.
    This file contains important information about NI-DCPower and is organized into the following sections:
    • New Features in Version 1.1
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
    • Uninstalling/Modifying NI-DCPower
    • Examples
    • Known Issues
    • Changes by Release
    • LabVIEW Real-Time support
    • Device simulation support
    NI-DCPower 1.1 and later supports the following power supply:
    • NI PXI-4110
    System RequirementsMinimum System
    • Processor—Pentium 200 MHz or equivalent
    • RAM—64 MB
    • A screen resolution of 800×600 with 256 colors
    • Windows 2000/XP, with all available critical updates and service packs
    Recommended System
    • RAM—256 MB
    • A screen resolution of 1024×768
    • LabVIEW 7.1 or later
    • LabVIEW Real-Time Module 7.1.1 or later
    • LabWindows™/CVI™ 7.0 or later
    • LabWindows™/CVI™ Real-Time Module
    • Microsoft Visual Basic 6.0
    Installed File Names and LocationsSoftware
    ItemInstalled Location
    NI-DCPowerProgram Files\IVI\Drivers\niDCPower
    DocumentationProgram Files\IVI\Drivers\niDCPower\Documentation\
    NI-DCPower LabVIEW support\instr.lib\niDCPower
    NI-DCPower LabVIEW Examples\examples\instr\niDCPower
    NI-DCPower CVI 7.0 or later supportProgram Files\IVI\Drivers\niDCPower
    NI-DCPower CVI Examples\samples\niDCPower
    NI-DCPower VB ExamplesProgram Files\IVI\Drivers\niDCPower\Examples\VisualBasic
    NI-DCPower Test PanelProgram Files\IVI\Drivers\niDCPower
    LabVIEW Run-Time Engine 8.0Program Files\National Instruments\Shared\LabVIEW Run-Time\7.1
    NI-DAQmx 8.3Program Files\National Instruments\NI-DAQ
    IVI Compliance Package 2.5Program Files\National Instruments\IVI
    NI-VISA 4.0WINDOWS\system32
    Documentation is available at Start»All Programs»National Instruments»NI-DCPower»Documentation. The documentation set is composed of the following documents:
    • NI-DCPower Readme
    • NI DC Power Supplies Getting Started Guide
      Printed and PDF format. Includes hardware and software installation, MAX configuration, and signal connection information.
    • NI DC Power Supplies Help
      HTML help format. Includes power supply fundamentals, hardware device overview, programming information, LabVIEW reference, and C/CVI/VB reference sections.
    • NI PXI-4110 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4110 triple-output, programmable DC power supply.
    • NI PXI-4110 Calibration Procedure
      PDF format. Includes calibration instructions for the NI PXI-4110.
    • Maintain Forced-Air Cooling Note to Users
      Printed format. Includes important cooling information for NI DC power supplies.
    • Readme First: Safety and Radio-Frequency Interference
      Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies.
    For Windows 2000/XP, complete the following steps to uninstall or modify NI-DCPower:
    • Open the Control Panel from the Start»Control Panel Menu and select Add or Remove Programs.
    • Select National Instruments Software from the list provided and click Change or Remove.
    • Select NI-DCPower 1.1 from the list provided and choose Modify or Remove.
    Examples
    Refer to Start»All Programs»National Instrument»NI-DCPower»Examples for the examples for the supported ADEs.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    • Accessing the NI-DCPower API in LabVIEW 7.x
      • (LabVIEW 7.x) From the Functions palette, select All Functions»Instrument I/O»Instrument Drivers»NI-DCPower.
      • (LabVIEW 8.0 or later) From the Functions palette, select Measurement I/O»NI-DCPower.
    • SignalExpress 1.1.1 and the IVI Power Supply step
    The IVI Power Supply step does not support NI-DCPower in Signal Express 1.1.1. Use the native NI-DCPower Express step to access NI-DCPower from within SignalExpress 1.1.1.
    Changes by Release1.1 from 1.0
    • Support for LabView Real-Time and device simulation.
    GMT+8, 2026-4-23 10:50
