TA的每日心情 | 奋斗 2 小时前 |
签到天数: 3865 天 连续签到: 58 天 [LV.Master]2000FPS
NI PXI Platform Services 17.0 Driver Download Linux32/64Eng PXI平台服务NI-PXIPS17.0 for Linux下载
PXI Platform Services用于支持NI PXI机箱和控制器,遵循PXI软件规范,并为其他NI产品提供系统服务。
PXI Platform Services用于识别NI PXI和PXI Express机箱和模块,以及允许触发路由。 对于特定NI模块,使用完整的模块功能仍需要适用的硬件驱动程序。 NI PXI Platform Services已包含在NI仪器驱动程序中,但有些情况下,某些应用程序只需要PXI Platform Services软件,例如在没有安装其他NI PXI硬件驱动程序的情况下使用NI MXI产品或使用NI PXI或PXI Express机箱。
百度网盘下载(限速,请开会员或使用工具下载):
请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
NI官方下载地址(可能无法下载完成或地址无效):
PXIPS17.0 Linux.txt
(290 Bytes, 下载次数: 0, 售价: 10 圆)
文件大小: 17310375 字节 (16.51 MB)
修改日期: 2017-05-17 01:05
MD5: 1398d0ccca9e4b3019ab12a6902110d0
SHA1: 6b0c50c58bd0eb688370f1fb428cf5c3a90c2078
SHA256: 68c97c0199bf34b32d26f8fd1e6b39a467305b127252863b3da587da8d7edbae
CRC32: 0b62a367
PXI Platform Services for Linux/x86 64-bit, Version 17.0May 2017-----------------------------------------------------------------------------This file contains late breaking news about PXI Platform Services andsupersedes any information found in other documentation included in thedistribution. Refer to ni.com/linux for the most recent information aboutLinux support at National Instruments.----------------------------------------------------------------------------------------------Table of Contents-----------------System RequirementsSupported HardwareInstallationUninstallationDevice ConfigurationLinux LimitationsFAQsLegal Information-------------------System Requirements-------------------PXI Platform Services for Linux software for the Intel x86 64-bitarchitecture has been tested for the following distributions: openSUSE Leap 42.1 openSUSE Leap 42.2 Red Hat Enterprise Linux Desktop + Workstation 6.x Red Hat Enterprise Linux Desktop + Workstation 7.x Scientific Linux 6.x CentOS 7.xFor more information about supported Linux versions and distributions supportedby NI, refer to ni.com/linux.------------------Supported Hardware------------------PXI Platform Services supports NI PXI Express Chassis, PXI Chassis,Embedded Controllers, and Remote Controllers.------------Installation------------The installation process compiles a small amount of code to customizethe software to your Linux distribution. Before running the installer, youmust have the following compiler facilities installed from your Linuxdistribution CD or other Linux distribution medium:* The kernel source files that exactly correspond to the kernel version you are running* The GCC compiler and C++ support* The make utilityUse the software-install facility of your Linux distribution to verify that theabove-listed packages are present. You can then begin installation.Complete the following steps to install PXI Platform Services:1. Run the INSTALL script from this directory as root. The INSTALL scriptensures that all requirements are met and installs the PXI Platform Servicessoftware. The script uses rpm to install packages on the system.--------------Uninstallation--------------To uninstall PXI Platform Services, complete the following steps:1. Run the UNINSTALL script from this directory as root.--------------------Device Configuration--------------------PXI Platform Services for Linux is configured via the nipxiconfig utilityinstalled by the installation script into "/usr/bin/nipxiconfig". For a list ofcommands and other relevant information about the utility, consult the manpage ("man nipxiconfig").-----------------Linux Limitations-----------------Some features discussed in the PXI Platform Services documentation and helpare unavailable on Linux:PXI Platform Services does not provide the Measurement and Automation Explorer(MAX) graphical configuration utility that is available for other operatingsystems. Refer to DEVICE CONFIGURATION in the Installation section forinformation about configuring your device in Linux.----FAQs----Q1: What action needs to be taken if I upgrade/change my kernel?A1: Some action is required to make the existing PXI Platform Services installation work for the new kernel. After upgrading your kernel, run the updateNIDrivers utility as root. The utility is located in /usr/local/bin. Be sure to have sources for your new kernel properly installed on your system before running the utility. The utility rebuilds the driver using the new kernel sources and copies it to the appropriate location for the new kernel. For the changes to take place, you will be asked to reboot your machine after the utility completes.-----------------Legal Information---------------------------COPYRIGHT:----------(c) 1998-2017 National Instruments.All rights reserved.Under the copyright laws, this publication may not be reproduced or transmittedin any form, electronic or mechanical, including photocopying, recording,storing in an information retrieval system, or translating, in whole or inpart, without the prior written consent of National Instruments Corporation.NI respects the intellectual property of others, and we askour users to do the same. NI software is protected by copyright and otherintellectual property laws. Where NI software may be used to reproducesoftware or other materials belonging to others, you may use NI softwareonly to reproduce materials that you may reproduce in accordance with theterms of any applicable license or other legal restriction.U.S. Government Restricted RightsIf you are an agency, department, or other entity of the United StatesGovernment ("Government"), the use, duplication, reproduction, release,modification, disclosure or transfer of the technical data included in thismanual is governed by the Restricted Rights provisions under FederalAcquisition Regulation 52.227-14 for civilian agencies and Defense FederalAcquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 formilitary agencies.IVI Foundation Copyright NoticeContent from the IVI specifications reproduced with permission from the IVIFoundation.The IVI Foundation and its member companies make no warranty of any kind withregard to this material, including, but not limited to, the implied warrantiesof merchantability and fitness for a particular purpose. The IVI Foundation andits member companies shall not be liable for errors contained herein or forincidental or consequential damages in connection with the furnishing,performance, or use of this material.-----------TRADEMARKS:-----------Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks forinformation on NI trademarks. Other product and company namesmentioned herein are trademarks or trade names of their respective companies.--------PATENTS:--------For patents covering the NI products/technology, refer to theappropriate location: Help>>Patents in your software, the patents.txt file onyour media, or the NI Patent Notice at ni.com/patents. |
