查看: 4332|回复: 0
[NI驱动程序] NI PXI Platform Services 17.0 Driver Win32/64Eng PXI平台服务NI-PXIPS17.0下载
    2 小时前
    发表于 2020-9-3 22:15:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    PXI Platform Services用于支持NI PXI机箱和控制器,遵循PXI软件规范,并为其他NI产品提供系统服务。
    PXI Platform Services用于识别NI PXI和PXI Express机箱和模块,以及允许触发路由。 对于特定NI模块,使用完整的模块功能仍需要适用的硬件驱动程序。 NI PXI Platform Services已包含在NI仪器驱动程序中,但有些情况下,某些应用程序只需要PXI Platform Services软件,例如在没有安装其他NI PXI硬件驱动程序的情况下使用NI MXI产品或使用NI PXI或PXI Express机箱。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    PXIPS17.0.txt (282 Bytes, 下载次数: 0, 售价: 10 圆)
    文件大小: 500862910 字节 (477.66 MB)
    修改日期: 2019-06-25 03:11
    MD5: 3c962b55681ca789d5397d6a5438058d
    SHA1: 9737e0926fc8b01f2d63b62386ce3c38172a18c8
    SHA256: a91e2b4ebefadfa418d992f0885e9d5190901efbf6fd59f7801181572e7ce8fa
    CRC32: bc16ee43
    PXI Platform Services 17.0 Readme
    April 2017
    This file contains important information about PXI Platform Services, including enhancements and a partial list of bugs fixed for PXI Platform Services 17.0. Parts of this document are only relevant to a full installation and do not apply to a runtime-only installation.
    Release Notes
    Supported Interfaces
    PXI System Monitoring
    PXI Platform Services provides support for customers using NI PXI and PXI Express chassis and controllers.
    Release Notes
    If you are using PXI Platform Services 17.0 to upgrade a Windows system that serves as a host for one or more LabVIEW Real-Time Module targets, it is highly recommended that you also update your targets to leverage new features and improved performance.
    Note: You cannot use PXI Platform Services 17.0 to configure a LabVIEW RT target with a version of PXI Platform Services earlier than 2.0.
    PXI Platform Services supports PXI and PXI Express functionality. Visit ni.com/info and enter the Info Code pxipshw for a complete list of hardware that is compatible with PXI Platform Services.
    PXI Platform Services 17.0 supports the following platforms. For the most up to date information on compatibility with PXI Platform Services, visit ni.com/info and enter the Info Code pxipsos.
    • Windows 10 (32-bit and 64-bit)
    • Windows 8.11 (32-bit and 64-bit)
    • Windows 7 with SP12 or later (32-bit and 64-bit)
    • Windows Server 2008 R2 with SP22 or later (64-bit)
    Note: Some hardware may not support all operating systems listed above. Please consult your hardware documentation for more information.
    Note  In 2016, PXI Platform Services dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. PXI Platform Services will not install or run on an unsupported OS. You cannot deploy or distribute applications that use PXI Platform Services 17.0 to an unsupported OS. Additionally, after installing PXI Platform Services 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    PXI Platform Services supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by PXI Platform Services
    LabVIEW2014 SP1, 2015 SP1, 2016, 2017
    PXI System MonitoringNI PXI Chassis System Monitoring
    PXI Platform Services 3.2.1 was the first version to support the PXI-8250 module via the NI System Configuration API.
    Note: NI System Configuration 5.4 (or later) is required for LabVIEW API support.
    NI PXI Express Chassis System Monitoring
    PXI Platform Services 3.1 was the first version to support system monitoring via NI System Configuration API.
    NI PXI Express Remote Controllers may require a firmware update in order to take advantage of the system monitoring features. For more information, visit ni.com/info and enter the Info Code pximxisysmon.
    NI System Monitor Minimum Requirement
    If NI System Monitor is installed on your system, upgrading PXI Platform Services to version 3.1 or later also requires an upgrade of NI System Monitor to version 1.2 or later.
    The following items are the IDs and title of a subset of issues fixed in PXI Platform Services. This is not an exhaustive list of issues fixed in the current version of PXI Platform Services. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    • Version 17.0
    • Version 16.0
    • Version 15.1
    • Version 15.0.2
    • Version 15.0.1
    • Version 15.0
    • Version 14.1
    • Version 14.0
    • Version 4.0.1
    • Version 4.0
    • Version 3.2.3
    • Version 3.2.2
    • Version 3.2.1
    • Version 3.2
    • Version 3.1
    • Version 3.0.4
    • Version 3.0.3
    • Version 3.0.2
    • Version 3.0.1
    • Version 3.0
    • Version 2.5.6
    • Version 2.5.4
    • Version 2.5.3
    Enhancements and Bug Fixes in Version 17.0New Hardware Support
    Added support for new PXI hardware.
    Fixed Issues
    589386Fixed issue where the Cable Location attribute may not refresh properly.
    565983Improved error messages for failed BIOS updates to PXI embedded controllers.
    590724Fixed an issue preventing a user from deleting a manually added PXI chassis while National Instruments is not the active PXI Resource Manager.
    Enhancements and Bug Fixes in Version 16.0New Hardware Support
    Fan control via NI System Configuration API
    PXI Platform Services 16.0 now installs a header file defining the attributes required to set a safe user fan speed through the NI System Configuration C API on supported PXIe chassis. For more details, visit ni.com/info and enter the Info Code pxisafeautofancontrol.
    Enhancements and Bug Fixes in Version 15.1New Hardware Support
    Fixed Issue: MAX Delay for Network-Capable Chassis
    374646: There was a short delay in MAX when viewing details for a chassis with a built-in Ethernet port.
    Enhancements and Bug Fixes in Version 15.0.2New Hardware Support
    Enhancements and Bug Fixes in Version 15.0.1New Hardware Support
    Added support for new PXI Express hardware.
    Enhancements and Bug Fixes in Version 15.0Self-Test for PXI Platform Hardware
    Self-test is available for PXI chassis and embedded and remote controllers; this feature can be accessed through MAX and NI System Configuration API. Self-test verifies basic hardware functionality.
    Geographic Aliases
    PXI controllers, MXI modules, and the PXI-8250 now provide an alias that conveys information about their location in a system (for example, PXI2Slot1). You can see this alias in the Devices and Interfaces section in MAX.
    New Chassis Attributes in MAX
    Hardware revision and PXI_CLK10 source information is now available for PXI chassis in MAX.
    Patch for PXIe-1085/PXIe-1078 Chassis
    PXI Platform Services 15.0 includes the PXIe-1085/PXIe-1078 patch that was released for PXI Platform Services 3.2.2 through 14.1. Visit ni.com/info and enter the Info Code pxipspatch_2015_en for more details about this patch.
    Fixed Issues: Improved MAX Stability
    378807, 440251, 507983, 520787, 520922: In some cases, there could be stability issues with PXI hardware in MAX.
    Fixed Issue: Duplicate Devices in MAX
    363174: MXI-4 and PXI-8360 devices were shown twice in Devices and Interfaces in MAX.
    Enhancements and Bug Fixes in Version 14.1New Hardware Support
    Fixed Issue: Could not create chassis item in Measurement & Automation Explorer (MAX)
    505008: When using the LabVIEW Real-Time Module with some older NI PXI controllers that are unable to automatically identify, the chassis could not be created in MAX.
    Enhancements and Bug Fixes in Version 14.0Driver Version Naming Changes
    PXI Platform Services versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: PXI Platform Services 14.0. For example, PXI Platform Services 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is PXI Platform Services 4.0.1. The first version released under the new numbering scheme is PXI Platform Services 14.0.
    Runtime Installer
    Starting with version 14.0, PXI Platform Services is available as a runtime installer. PXI Platform Services Runtime is a minimal installer which does not include configuration through Measurement & Automation Explorer (MAX). When building an installer using NI application development environments (ADEs) such as LabVIEW, you will now have the option of including this subset of PXI Platform Services in your distribution.
    System Monitor
    Support for System Monitor is deprecated in PXI Platform Services and will be removed in a future release. Monitoring capabilities are available through the NI System Configuration API. Customers using System Monitor should migrate their applications to NI System Configuration API.
    Fixed issue: Chassis not automatically identified in MAX
    441696: When using a PXI Express Chassis and controller under a heavy load, the chassis could sometimes fail to auto-identify in MAX.
    Enhancements and Bug Fixes in Version 4.0.1New Hardware Support
    Enhancements and Bug Fixes in Version 4.0PXI Specification Updates
    PXI Platform Services 4.0 adds support for the new PXI-9 specification, revision 1.0. This version also includes updates to meet the requirements of the following PXISA specification versions:
    • PXI-2 Software Specification, revision 2.4
    • PXI-4 Module Description, revision 1.1
    • PXI-6 PXI Express Software Specification, revision 1.2
    The PXI Express chassis description files now list the PXI specification compliance version. For more information on PXI specifications, go to pxisa.org.
    PXI Platform Services on Real-Time Systems
    When deploying software to your Real-Time system, PXI Platform Services is now visible in the Add/Remove Software tree in Measurement & Automation Explorer (MAX). If you have more than one version of PXI Platform Services 4.0 or later installed on your host, you may select which version of PXI Platform Services will be deployed to the target. For more information about deploying software to Real-Time targets, see the MAX Help, available on the Help menu in MAX.
    Fixed Issues in Measurement & Automation Explorer
    PXI Platform Services 4.0 fixes the following issues in MAX:
    • 37850: In some instances, NI PXI-8360 and PXI-MXI-4 devices may not be visible in MAX.
    • 393204: In some cases, there could be stability issues with PXI hardware in MAX.
    Enhancements and Bug Fixes in Version 3.2.3New Hardware Support
    Enhancements and Bug Fixes in Version 3.2.2New Hardware Support
    Added support for new PXI and PXI Express hardware.
    Removed Hardware Support
    PXI Platform Services will no longer provide support for the following hardware:
    • PXI-1002 chassis
    • PXI-1006 chassis
    • PXI-1010 chassis
    • PXI-1011 chassis
    • PXI-1020 chassis
    • PXI-1025 chassis
    • PXI-8150 controller
    • PXI-8150B controller
    • PXI-8170 controller
    • PXI-8174 controller
    • PXI-8175 controller
    • PXI-8176 controller
    • PXIe-8103 controller
    Enhancements and Bug Fixes in Version 3.2.1Windows 8 Fixes
    Minor updates to improve the Windows 8 user experience.
    Enhancements and Bug Fixes in Version 3.2Windows 8 Support
    PXI Platform Services 3.2 adds support for Windows 8 (32-bit and 64-bit).
    The following are known issues with Windows 8:
    • The fast startup capability introduced in Windows 8 may cause improper functioning of your hardware and device drivers. To properly initialize drivers, choose Restart or Shut Down when prompted at the end of the installation. To prevent future problems with installing or removing hardware, NI recommends disabling fast startup. Visit ni.com/info and enter the Info Code Win8FastStartup for more information.
    • Upgrading from a Windows 7 (or older) system is not supported
    NI PXI Express Remote Controller Firmware Updater
    PXI Platform Services has enabled the ability to update NI PXI Express Remote Controller Firmware. For more information, refer to the documentation of the specific firmware.
    Enhancements and Bug Fixes in Version 3.1NI PXI Express Chassis Monitoring
    Added support for monitoring NI PXI Express chassis via NI System Configuration API.
    LabVIEW Support
    Support for LabVIEW 8.6 and LabVIEW 2009 is discontinued in this release.
    Enhancements and Bug Fixes in Version 3.0.4New Hardware Support
    Enhancements and Bug Fixes in Version 3.0.3New Hardware Support
    Enhancements and Bug Fixes in Version 3.0.2New Hardware Support
    Enhancements and Bug Fixes in Version 3.0.1Fixed Issue: Addressed failure with RT Reboot of Hypervisor System
    313181 Fatal exception, Code:0xC0000005 error, detected when restarting RT side of a Hypervisor system.
    Enhancements and Bug Fixes in Version 3.0Updates to Measurement & Automation Explorer Graphical User Interface
    PXI Platform Services has updated the user interface for PXI Systems in Measurement & Automation Explorer. The following changes were made:
    • Better error detection.
    • Improved performance.
    • Identify bus as a chassis function replaced with Create New Chassis Wizard.
    • Updated help.
    • Controllers and MXI Modules now appear inside Slot View and Devices and Interfaces.
    • Majority of National Instruments PXI embedded controllers are now automatically identified.
    • MXI connectivity information is provided through Devices and Interfaces.
    • Removed redundant PXI System tree under Devices and Interfaces.
    LabVIEW Support
    Support for LabVIEW 8.5 is discontinued in this release.
    Enhancements and Bug Fixes in Version 2.5.6New Software Support
    PXI Platform Services 2.5.6 adds support for PXI Express systems on NI Real-Time Hypervisor.
    LabVIEW 8.2 Support
    Support for LabVIEW 8.2 is discontinued in this release.
    Enhancements and Bug Fixes in Version 2.5.4Windows 2000
    PXI Platform Services 2.5.4 removes support for Windows 2000.
    Windows Server Support
    PXI Platform Services 2.5.4 adds support for Windows Server 2003 R2 (32-bit only) and Windows Server 2008 R2.
    Enhancements and Bug Fixes in Version 2.5.3Windows 7 Support
    PXI Platform Services 2.5.3 adds support for Windows 7 x86 (32-bit) and Windows 7 x64 (64-bit).
    • For more information on silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX) and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 1998–2017 National Instruments. All rights reserved.
    374995D-01
    GMT+8, 2026-4-23 10:49
