查看: 3604|回复: 0
[NI驱动程序] NI-Sync 19.1 Driver Win32/64Eng NI PXI同步模块及实时控制器驱动程序下载June.2019
    2 小时前
    发表于 2020-9-3 00:18:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Sync用于支持用户使用PXI同步模块或任何运行实时操作系统的NI控制器。
    NI-Sync是一个NI仪器驱动程序,用于配置系统定时和同步,包括基于信号的同步和直接使用时钟。您还可以使用时间协议(如IEEE 1588标准,IEEE 802.1AS标准,IRIG或GPS)执行基于时间的同步,作为时间戳的时间参考或执行同步时钟和触发生成。NI-Sync支持PXI同步模块和实时PXI、CompactDAQ和CompactRIO控制器以及紧凑视觉系统和工业控制器。NI-Sync中还包括高级实用程序及范例,可帮助用户更轻松地创建应用程序。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    NI-Sync19.1.txt (264 Bytes, 下载次数: 0, 售价: 10 圆)
    文件大小: 1692157952 字节 (1.58 GB)
    修改日期: 2019-06-17 13:05
    MD5: 82c4d65abf1b18bec6971d7255e530c9
    SHA1: 75f3b7c775484ffa9710f5786febad97b227d172
    SHA256: 7340e644f0317e5f3da48dabab753f8b909f7d7bdf45b025f54c3f35a5203613
    CRC32: 18718ebb
    NI-Sync 19.1 Readme
    June 2019
    This file includes important information about NI-Sync, including supported operating systems, a partial list of bugs fixed for NI-Sync 19.1, and known issues.
    NI-Sync Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-Sync provides support for customers using NI timing and synchronization hardware modules.
    NI-Sync 19.1 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21, 4, 5 (x64)
    • Windows Server 2008 R2 SP12, 4, 5 (x64)
    • NI Real-Time VxWorks
    • NI Real-Time Phar Lap ETS
    • Linux Real-Time (RT)3, 6, 7
    3 Certain features are unavailable on Linux RT targets. Refer to NI-Sync Limitations on Linux Desktop and NI Linux Real-Time for more information about target support and functionality.
    4 System Configuration does not support non-R2 versions of Windows Server.
    5 Support for Windows Server 2008 R2 and Windows Server 2012 R2 requires disabling Internet Explorer Enhanced Security Configuration (IE ESC). To learn how this affects your use of Windows Server 2008 R2 and Windows Server 2012 R2 and what actions you must take, visit ni.com/info and enter the Info Code MAXSupportIEESC
    6 IEEE 1588-2008 protocol instances on ARM-based targets running NI Linux Real-Time are configured to be "slave only" by default. For more information about this issue, visit ni.com/info and enter the InfoCode ARMTargetSlaveOnly.
    7 Monitoring and configuring of time-based synchronization on embedded Phar Lap and VxWorks targets is not supported in the NI-Sync API. Use the NI-TimeSync property node installed with NI-Sync for time-based synchronization on these targets.
    Note  In 2016, NI-Sync dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Sync 19.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Sync 19.1 to an unsupported OS. Additionally, after installing NI-Sync 19.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  Refer to NI-Sync Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    NI-Sync supports the following application software versions, including service packs.
    Versions Supported by NI-Sync
    LabVIEW2016 SP1, 2017 SP1, 2018, 2019
    LabVIEW Real-Time Module2016, 2017, 2018, 2019
    LabWindowsٯCVIټ/td>2012, 2013, 2015, 2017
    LabVIEW NXG3.0, 3.1
    NI-Sync 19.1 supports the following devices:
    Signal-Based Modules
    • PXI-6651
    • PXI-6652
    • PXI-6653
    • PXIe-6672
    • PXIe-6674
    • PXIe-6674T
    Time-Based Modules
    • PCI-1588
    • PXI-6682
    • PXI-6682H
    • PXI-6683
    • PXI-6683H
    Controller Support for Time-Based Synchronization
    The following embedded controller types support time-based synchronization with NI-Sync 19.1:
    • PXI(e)1
    • CompactRIO
    • CompactDAQ
    • Industrial Controller (IC)
    • Compact Vision Systems
    1 Time-based synchronization is fully supported on Phar Lap PXIe(e) controllers. Time-based synchronization is supported on NI Linux Real-Time PXIe controllers only if the system includes a PXI-6683 Series timing and synchronization module.
    New FeaturesNI-TimeSync Integration with NI-Sync
    In 2019, National Instruments no longer provides NI-TimeSync as a standalone download. Features previously provided by NI-TimeSync, including time references for synchronization, are now included in NI-Sync 19.1. Refer to the NI-Sync documentation for information on specific protocols and features.
    You can access the software and documentation known issues list online. For a list of known issues with NI-Sync 19.1, visit ni.com/info and enter the Info Code nisyncknownissues.
    For a complete list of bug fixes in NI-Sync, visit ni.com/info and enter the Info Code NISyncFixList. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    Refer to the NI-Sync Help, accessible from Help»LabVIEW Help..., for information about using NI-Sync with LabVIEW.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-Sync are located in the \examples\instr\niSync directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • For signal-based examples that use clocks and triggers directly, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Signal-Based.
    • For time-based examples that use time references such as IEEE 1588-2008 or GPS as a basis for synchronization, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Time-Based.
    The following sections detail considerations for using LabVIEW NXG 3.1 with NI-Sync 19.1.
    • Operating system—Only 64-bit operating systems are supported.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    • For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Apps view or from within NI Launcher.
    NI-Sync will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ©2003-2019 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Helpܐatents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    375085M-01
    GMT+8, 2026-4-23 10:49
