查看: 3273|回复: 0
[NI驱动程序] NI-Sync 17.0 Driver Win32/64Eng NI PXI同步模块及实时控制器驱动程序下载May.2017
    2 小时前
    发表于 2020-9-3 00:10:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Sync用于支持用户使用PXI同步模块或任何运行实时操作系统的NI控制器。
    NI-Sync是一个NI仪器驱动程序,用于配置系统定时和同步,包括基于信号的同步和直接使用时钟。您还可以使用时间协议(如IEEE 1588标准,IEEE 802.1AS标准,IRIG或GPS)执行基于时间的同步,作为时间戳的时间参考或执行同步时钟和触发生成。NI-Sync支持PXI同步模块和实时PXI、CompactDAQ和CompactRIO控制器以及紧凑视觉系统和工业控制器。NI-Sync中还包括高级实用程序及范例,可帮助用户更轻松地创建应用程序。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    NI-Sync17.0.txt (248 Bytes, 下载次数: 0, 售价: 10 圆)
    文件大小: 1655676864 字节 (1.54 GB)
    修改日期: 2017-05-20 00:39
    MD5: 9282c4d81b949353698597908117dadb
    SHA1: 69a4e196a2102fc1dc343dcdae633bbdf7819ffc
    SHA256: 441fc9f8bc6dd3423d416e908e8bf244c2c1a1688cd02cfa7101168b7b7c13d3
    CRC32: 997fe0cc
    NI-Sync 17.0 Readme
    May 2017
    This file includes important information about NI-Sync, including supported operating systems, a partial list of bugs fixed for NI-Sync 17.0, and known issues.
    NI-Sync provides support for customers using NI timing and synchronization hardware modules.
    NI-Sync 17.0 supports the following operating systems:
    • Windows 7 SP1 x86, x64
    • Windows 8.1 SP1 x86, x64
    • Windows 10 SP1 x86, x64
    • Windows Server 2008 R2 (x64)
    • Windows Server 2012 R2 (x64)
    • NI Real-Time Phar Lap ETS
    Note  In 2016, NI-Sync dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Sync 17.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Sync 17.0 to an unsupported OS. Additionally, after installing NI-Sync 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-Sync supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by NI-Sync
    LabVIEW2014, 2015, 2016, 2017
    LabVIEW Real-Time Module2014, 2015, 2016, 2017
    LabWindows�/CVI�2012, 2013, 2015, 2017
    • The niSync Measure Frequency VI is now supported on PXI-668x modules.
    • Most modules' temperature, firmware revision, and hardware revision are now reported through System API.
    NI-Sync 17.0 supports the following devices:
    Signal-Based Modules
    • PXI-6651
    • PXI-6652
    • PXI-6653
    • PXIe-6672
    • PXIe-6674
    • PXIe-6674T
    Time-Based Modules
    • PCI-1588
    • PXI-6682
    • PXI-6682H
    • PXI-6683
    • PXI-6683H
    You can access the software and documentation known issues list online. For a list of known issues with NI-Sync 17.0, visit ni.com/info and enter the Info Code NISync170KnownIssues.
    The following items are the IDs and titles of a subset of issues fixed in the NI-Sync. This is not an exhaustive list of issues fixed in the current version of NI-Sync. For a complete list of bug fixes in NI-Sync, visit ni.com/info and enter the Info Code NISyncFixList. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    IDFixed IssueIssue DetailsFixed Version
    592326Windows 10 sometimes crashes following driver installation and upon the next reboot, or during installation.17.0
    439129Modifying the calibration password updates the calibration timestamp.Calibration passwords for all modules can now be modified outside a calibration session.17.0
    632346PLL Locked? property does not consistently update when lock is lost.The property now updates when the lock is lost.17.0
    Refer to the NI-Sync Help, accessible from Help»LabVIEW Help..., for information about using NI-Sync with LabVIEW.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-Sync are located in the \examples\instr\niSync directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • For signal-based examples that use clocks and triggers directly, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Signal-Based.
    • For time-based examples that use time references such as IEEE 1588-2008 or GPS as a basis for synchronization, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Time-Based.
    • For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Apps view or from within NI Launcher.
    The following sections detail considerations for using LabVIEW NXG with NI-Sync.
    LabVIEW NXG Hardware Support
    • PXI-6683
    • PXI-6683H
    • PXIe-6674T
    • PXIe-6672
    Installing NI-Sync 17.0 for LabVIEW NXG
    NI automates LabVIEW NXG installation using a package manager. Complete the following steps to install NI-Sync for LabVIEW NXG.
    • Visit ni.com/info and enter the info code NXGDownload to access the LabVIEW NXG download page.
    • Click Download LabVIEW NXG 1.0.
    • NI Package Manager installs, then automatically opens a download window.
    • Select LabVIEW NXG Suite and click the green Install button.
    • Select LabVIEW NXG 1.0 and NI-Sync.
    • Complete the installer instructions to download LabVIEW NXG 1.0 and NI-Sync.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    ©2003-2017 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help�Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    375085F-01
    GMT+8, 2026-4-23 10:36
